Interface with Defined Type
mattsdad
In Fortran v 10.1, I would like to create a module with a defined type and declare a set of subroutine interfaces that have anargument of the declared type. I cannot "use" the module in the interface declaration, and I get an unrecognized type error if I leave it out.
MODULEX
TYPE X_t
INTEGER :: XXX
END TYPE X_t
INTERFACE
SUBROUTINE XX(Obj)
! USE X
TYPE(X_t), INTENT(INOUT) :: Obj
END SUBROUTINE
END INTERFACE
END MODULE X
How do Imake the type visible in the interface?
OP1
New Contributor III
Quoting - mattsdad
MODULEX
TYPE X_t
INTEGER :: XXX
END TYPE X_t
INTERFACE
SUBROUTINE XX(Obj)
! USE X
END SUBROUTINE
END INTERFACE
END MODULE X
I believe you should remove "USE X" and instead type: "IMPORT :: X_t". This will make the type X_t visible from within the interface block.
Hope this helps!
Olivier
