Internal Compiler Error (11.1.051)
Dustin
In an attempt to compile a large program with largematrices usingversion 11.1.051 (64-bit), I received the following error message:
fortcom: Fatal: There has been an internal compiler error (C00000FD).
compilation aborted for astap.for (code 1)
I can compile and run smaller versions of the same program, so I wonder if I've encountered a compiler limitation?
Please advise.
Dustin
An internal compiler error is almost always a compiler bug. Are you willing to provide us the source and the compile options you used so that we can investigate it?
Dustin
Okay,what is the best way to get you the file?
Dustin
Quoting - Dustin
Nevermind, I noticed the sticky with instructions.
Here are the files. They are compiled as follows:
ifort astap.for /fpe:0 /names:lowercase /iface:cref /module:C:PROGRA~1CULLIM~1SINDAF~1lib /MT /libs:dll /iface:mixed_str_len_arg /include:C:PROGRA~1CULLIM~1SINDAF~1lib /assume:byterecl /extend_source:132 /O3 /list /traceback /INCREMENTAL:NO
David_J_2
I'm sure you will need the module file as a minimum to compile this so I have uploaded it here. If you need the libraries too just ask. But you won't be able to run the resulting executable without doing a lot more.
Dave
Dustin
Thanks, Dave. Sorry to jump the gun, but I got a little impatient. Plus, I wanted to get to know the Intel folks.
I'll need the source for the module(s) - thanks. Feel free to ZIP them if they're big.
David_J_2
I have attached the source for the module. But I'm really curious as to why you need it? It isn't every used outside of building the library. Is it the source of the problem? Seems it took almost 3 hours on my machine to compile the source before it failed with the internal compiler failure.
Dave
Sometimes there is an issue with the .mod and we need to see the source that created it. Thanks for providing it. I'll let you know what we find.
David_J_2
Steve,
Just so you know, we have submitted a bug report that deals with ALLOCATION/DEALLOCATION across compiler versions. Maybe that is why you wanted this source, but the variables are allocated in the main routine.
I still haven't gotten a fix date for that problem. But we have a work-around, we just haven't implemented it yet.
Dave
Thanks - I know about that issue. Unfortunately, it's one we won't be able to provide a solution for other than not mixing allocations across 11.0 (and earlier) with 11.1 (and later).
What is this ASTAP program? It looks to be automatically generated. It may be that it's just too complex a single program unit for the 32-bit compiler. To be honest, I doubt optimization will help since it's very simple in nature (lots of calls.)
David_J_2
Steve,
The code is generated programatically. This is being compiled for 64 bit machines in this case. What do we need to do to get past the compiler failure. Are you going to look for the failure in the compiler?
Dave
Yes, I will certainly look (or ask the developers to look) for the failure. If I can find a workaround, I'll let you know.
David_J_2
Thanks! I haven't been able to get very far with working around this one.
cgerdb
Hi! Steve,
I am new to this forum. I notice you are an expert here. I got the same internal comiler error as well with Visual Fortran 11.1.051 inside Visual Studio 2008 in 64bit XP. Let me give you a very simple example here:
[cpp]      program Console1
      implicit none
      CHARACTER*10 FNAME
      DATA FNAME /'ABCDEFG'/
      INTEGER I, J
       DO J=1,LEN(FNAME)
!         IF (J.NE.3) THEN
         IF (FNAME(J:J).NE.' ') THEN
           I=I+1
         ENDIF
       ENDDO
      end program Console1
[/cpp]
The compiler is OK with the commented IF line, but give error for the next IF line. However, compiling the code in a console window with ifort is fine with both IF lines.
I cannot understand this. Please help!
cgerdb, I see you started a new thread - I replied to you there.
It is important to understand that "Internal compiler error" is a generic message with many, many possible causes.
Dave,
What I can tell is that the compiler is simply running out of virtual memory. It takes longer on a 64-bit system, but it does eventually happen. I've asked the developers to look into it, but may not be able to provide a workaround. That is one enormous subroutine!
David_J_2
Dave,
Yes but even breaking it down into smaller pieces still results in the same error. I chopped it down to about 50000 lines each and it still fails. There aren't that many variables involved, so it is very puzzling why the compiler fails. And the fact that it takes 3 hours to fail seems to suggest there is a compiler bug involved. I've compiled much larger sources without this many problems. Seems like a solvable problem. I also turned off optimization, so that shouldn't be an issue. Anyway we are still hoping for some resolution on this.
Dave
cgerdb
I solved my Internal Compiler Error with an inspiration from Steve. It may work for you too. Try these:
1) Click "Prject" menu and then "your_project_properties" item;
2) Click "Fortran" and then "Run-time";
3) Set "Chech Array and String Bounds" to "no";
4) Build.
Dave's problem is different and can be seen even with no compiler options. As I said, an internal compiler error message can have many possible causes. You cannot assume that one case is like another.
Dave, thanks for the additional information.
David_J_2
Steve,
Is this related to DPD200140603? Any chance 11.1.054 fixes this? Do we need to submit a report to premier support to make sure we get an answer on this?
Dave
