This builds further on the code shown in the topic https://software.intel.com/en-us/forums/topic/536578. The use of the derived type in a program results in an internal compiler error:
MODULE m USE, INTRINSIC :: ISO_FORTRAN_ENV, ONLY : I4 => INT32, SP => REAL32, DP => REAL64 IMPLICIT NONE !.. PRIVATE !.. PUBLIC :: I4, SP, DP TYPE, PUBLIC :: t(k,n) PRIVATE INTEGER(I4), KIND :: k = SP INTEGER(I4), LEN :: n = 1 REAL(k) :: m_X(n) CONTAINS PRIVATE PROCEDURE, PASS(This) :: GetX_SP PROCEDURE, PASS(This) :: GetX_DP PROCEDURE, PASS(This) :: SetX_SP PROCEDURE, PASS(This) :: SetX_DP GENERIC, PUBLIC :: X => GetX_SP, GetX_DP GENERIC, PUBLIC :: SetX => SetX_SP, SetX_DP END TYPE t CONTAINS PURE FUNCTION GetX_SP(This) RESULT(RetVal) CLASS(t(SP,*)), INTENT(IN) :: This !.. Function result REAL(SP), ALLOCATABLE :: RetVal(:) RetVal = This%m_X RETURN END FUNCTION GetX_SP PURE FUNCTION GetX_DP(This) RESULT(RetVal) CLASS(t(DP,*)), INTENT(IN) :: This !.. Function result REAL(DP), ALLOCATABLE :: RetVal(:) RetVal = This%m_X RETURN END FUNCTION GetX_DP PURE SUBROUTINE SetX_SP(This, Arr) CLASS(t(SP,*)), INTENT(INOUT) :: This REAL(SP), INTENT(IN) :: Arr(:) IF (SIZE(Arr) == This%n) THEN This%m_X = Arr END IF RETURN END SUBROUTINE SetX_SP PURE SUBROUTINE SetX_DP(This, Arr) CLASS(t(DP,*)), INTENT(INOUT) :: This REAL(DP), INTENT(IN) :: Arr(:) IF (SIZE(Arr) == This%n) THEN This%m_X = Arr END IF RETURN END SUBROUTINE SetX_DP END MODULE m PROGRAM p USE m, ONLY : I4, DP, t IMPLICIT NONE !.. Local variables TYPE(t(DP,5)) :: foo REAL(DP) :: x(5) PRINT *, " Test #74: PDT" PRINT *, " foo%k = ", foo%k PRINT *, " foo%n = ", foo%n x = -1.0_dp CALL foo%SetX(x) PRINT *, " foo%x = ", foo%X() !.. STOP END PROGRAM p
1>------ Build started: Project: TestFor, Configuration: Debug Win32 ------ 1>Unlock PDB file 1>Compiling resources... 1>TestFor.rc 1>Microsoft (R) Windows (R) Resource Compiler Version 6.3.9600.17298 1>Copyright (C) Microsoft Corporation. All rights reserved. 1>Compiling with Intel(R) Visual Fortran Compiler XE 15.0.1.148 [IA-32]... 1>TestMod.f90 1>C:\..\TestMod.f90(56): warning #7026: Non-standard extension. [T#4&*] 1>C:\..\TestMod.f90(69): warning #7026: Non-standard extension. [T#8&*] 1>TestFor.f90 1>fortcom: Fatal: There has been an internal compiler error (C0000005). 1>compilation aborted for C:\..\TestFor.f90 (code 1) 1> 1>Build log written to "file://C:\..\Debug\Win32\TestForBuildLog.htm" 1>TestFor - 1 error(s), 2 warning(s) ========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Thanks - we'll check it out.
This looks to be the same as https://software.intel.com/en-us/forums/topic/535467 . Escalated as issue DPD200363307.
This has been fixed in our sources. I expect the fix to appear in Update 2, planned for February.
Steve,
The code in the original post compiles fine now, but it generates run-time exception (as shown below) if /check:bounds compiler option is specified. Any idea why?
Test #74: PDT foo%k = 8 foo%n = 5 forrtl: severe (408): fort: (2): Subscript #1 of the array M_X has value 1 which is greater than the upper bound of 0 Image PC Routine Line Source TestFor32.exe 01284C54 Unknown Unknown Unknown TestFor32.exe 012819F4 _M_mp_SETX_DP 73 TestMod.f90 TestFor32.exe 01281DA9 _MAIN__ 17 TestFor.f90 TestFor32.exe 012EEA62 Unknown Unknown Unknown TestFor32.exe 012EF27A Unknown Unknown Unknown TestFor32.exe 012EF3CD Unknown Unknown Unknown kernel32.dll 76D9338A Unknown Unknown Unknown ntdll.dll 7795BF32 Unknown Unknown Unknown ntdll.dll 7795BF05 Unknown Unknown Unknown Press any key to continue . . .
Possibly connected with https://software.intel.com/en-us/forums/topic/536334 and https://software.intel.com/en-us/forums/topic/536564?
Very likely. I added your case to the report of that problem and asked the developers for an update.
