Internal Compiler Error
OP1
New Contributor III
The following code produces an ICE with IVF 10.1.3885.2005. This may have been fixed in newer releases, but I cannot test if it's still there - maybe it's worth checking.
If you comment the EXIT statement the ICE disappears.
Olivier
[fortran]PROGRAM MAIN
IMPLICIT NONE
LOGICAL :: KEEP_GOING
INTEGER :: I,IMAX,J,JMAX,STATUS
KEEP_GOING = .TRUE.
IMAX = 10
JMAX = 10
DO I=1,IMAX
    !$OMP PARALLEL NUM_THREADS(4) DEFAULT(SHARED) PRIVATE(J,STATUS)
    !$OMP DO
    DO J=1,JMAX
        IF (KEEP_GOING) THEN
            STATUS = I+J
            IF (STATUS>10) THEN
               !$OMP CRITICAL (LOCK)
                   KEEP_GOING = .FALSE.
               !$OMP END CRITICAL (LOCK)
            END IF
        ELSE
            EXIT
        END IF
    END DO
    !$OMP END DO NOWAIT
    !$OMP END PARALLEL
    IF (.NOT.KEEP_GOING) EXIT
END DO
END PROGRAM MAIN[/fortran]
Current version says:
t.f90(23): error #7566: A RETURN or EXIT statement is not legal in a DO loop associated with a parallel directive.
EXIT
No ICE.
