Internal Compiler Error
kramer__walter
I get an internal compiler error if I use the diagnostics compiler option combination: /Qvec-report2 /Qopt-report file:"Release\ErrorCode1.optim"
If I would use /Qvec-report1 instead of  /Qvec-report2, or skip /Qopt-report file:"Release\ErrorCode1.optim" the internal compiler error is not triggered.
Is there also a coding error (see attached files)?
I use Intel(R) Visual Fortran Compiler XE 13.1.1.171 [IA-32]
Walter Kramer
Thanks, we'll take a look.
TimP
In premier issue 695018, the 64-bit counterpart of compiler 13 update 3 introduced internal error when /arch and /Qopt-report are used together.
I escalated this as DPD200243042. Curiously, unlike Tim's case, I get the error with the 32-bit compiler only, not 64-bit.
I expect this problem to be fixed in Update 4.
