Internal compiler error - Update 6
lklawrie
I'm getting an internal compiler error in one of my modules in Update 6. This is not (as far as I can tell) an unusually complicated module. I have others that are much more complicated -- I'm hesitating..
It seems to be compiling okay in debug mode.
Anyway, is there anyway to track down what it doesn't like in this module? It's a complicated development and will be hard to extract into a project that the premier support people can use.
Linda
lklawrie
FYI, I disabled optimization on that particular module and the rest compiled.
Linda
Can you supply us that source and the sources for any modules and include files it needs?
lklawrie
I spent a goodly amount of time trying to create a project that could illustrate, but it compiles that module fine.
Linda
lklawrie
I'm going to reply to this thread.
Now have this one compiling if I turn on only "O1" (Minimize Size) option.
But a different module failed when I made a 64 bit EXE last week. (There, too, I just turned off optimization).
I have some other options turned on in my project:
/assume:protect_parens /Qprec-div /Qprec-sqrt /Qimf-precision:high /Qimf-arch-consistency:true
(plus assorted others). Including, now, /fpe3 because we have a c library that seems to need it to not crash on some input files.
Any ideas? Short of giving the entire project to premier support.
/fpe3 is the default, so it seems odd you need to use it.
At this point I suggest giving Premier Support the project and let us play with it.
lklawrie
/fpe3 is not for this problem -- it's for a library that is part of the project but is written in c and I can't get any developer to play with it. (original developer is not currently available).
was a side comment.
Linda
lklawrie
Issue 646678 posted for this.
Linda
