29362 Discussions
Internal compiler error in Intel Fortran Composer XE 2013 SP1
Jacob_Williams
New Contributor III
The following project generates an ICE:
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
when compiling the Release configuration (the Debug configuration compiles fine). Note that the code is just a stripped down version of a subroutine where I removed all the code that didn't trigger the problem.  The actual routine here doesn't really do anyting.  The error occurs at compile time.  I'm using Visual Studio 2010 and the latest Intel Fortran compiler (2013_sp1.0.103) on Windows 7.
Thanks, we'll take a look.
I reproduced this and escalated it to developers as issue ID DPD200248781. I will keep you informed here of any progress,
Jacob_Williams
New Contributor III
This problem appears to be fixed in 2013 SP1 Update 1 (14.0.1.139).
Interesting - I didn't see anything from the developers on this but perhaps it got fixed based on a different problem report. Thanks for verifying.
Jacob_Williams
New Contributor III
Actually, forgot what I just said (I got my bug reports mixed up).  For this one, the Release build still has the ICE in the latest version of the compiler.
It seems to work ok in 14.0.4 and later.
