29657 Discussions
Internal compiler error in inheritance problem
pwl_b
I have noticed that the following code causes compiler error in ifort12.1.0 20110811, while it works with gfortran4.6.1 20110422. The code seems, to me, to be a proper Fortran 2003. The strange thing is that if you uncomment the four lines in program test it starts to work. Also either, removing the statement private from class_b, or removing the contents of type :: a (the logical variable), has the same positive effect.
[fortran]module class_a
  type :: a
     logical :: initialized = .false.
  end type a
end module class_a
module class_b
  use class_a
  private
  type, public, extends(a) :: b
  end type b
end module class_b
module class_c
  use class_b
  type, extends(b) :: c
     logical :: test_result = .false.
  end type c
end module class_c
program test
  ! use class_initializable
  ! use class_trigger
  use class_c
  ! type(initializable) :: i
  ! type(trigger) :: t
  type(c) :: t
  t = c()
end program test
[/fortran]
Thanks - I can reproduce this in Update 6. It does seem to build in Update 5 so you may want to revert to that until it gets fixed. I will report this to the developers. Issue ID is DPD200174088.
pwl_b
Thank you for your answer, I will keep track of this issue. Is it possible to download Update 5 with a noncommercial licence? If yes, where can I get it?
Sure. Just log in to the Intel Registration Center - register your serial number if not already registered. You can then use the version dropdown on the compiler download page to select an earlier version.
This problem has been fixed for a release later this year. Use internal issue ID DPD200176665 for tracking.
