29285 Discussions
**Internal compiler error: segmentation violation with INTERFACE BLOCK
butette
Any reason why this should produce a compiler segmentation. I have 2 files junk1_mod.F90 and Interfaces_mod.F90.
So I compile
ifort -c junk1_mod.F90 <--- no problem here
when I compile Interfaces_mod.F90
ifort -c Interfaces_mod.F90
/tmp/ifortVR4J0A.i90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for Interfaces_mod.F90 (code 1)
???? The odd part is the message went away if I just take out the type bound procedure definition junksub ni junk1_mod.F90.
Now if I just include the interface block inside another routine, that seems to be OK as well, but that would be a pain.
I have tried this on other compiler like xlf2003 w/o any problem.
This occurs even with either the latest 11.1 compiler or the 12.0 beta compiler.
=== file junk1_mod.F90
module junk1_mod
type :: junktype
integer :: i
contains
procedure junksub
end type junktype
contains
subroutine junksub(this,i)
class(junktype) :: this
integer :: i
end subroutine junksub
end module junk1_mod
=== file Interfaces_mod.F90
module Interfaces_mod
INTERFACE
subroutine test( junk )
use junk1_mod
type(junktype) :: junkin
end subroutine test
END INTERFACE
end module Interfaces_mod
John4
Valued Contributor I
As a workaround, you could put an import statement inside the interface block, and move the use statement outside the interface block:
[fortran]module Interfaces_mod
    use junk1_mod
    INTERFACE
            import
        end subroutine test
    END INTERFACE
[/fortran]
The nearly universal answer to an internal compiler error is "it's a compiler bug". Thanks - we'll take a look at this.
Thanks for the nice test case. I have escalated this as issue DPD200161456. When I get any news about it, I will reply here.
butette
Thank you Steve... in the meantime I will try to find a way to work around this problem.
John4
    use junk1_mod
    INTERFACE
            import
        end subroutine test
    END INTERFACE
[/fortran]
butette
Thanks John... that seems to work. Although since my real code is a lot more involved with lots of routines in the interface blocks and lots of modules to be included, it would be a little messy, but I may just have to do that or redesign the code to use all TPB and not have this issues at all.
This was fixed in version 12 Update 1.
