29655 Discussions
Internal compiler error when using derived data type
bbur
I recently moved a code from ifc2017 to the most recent ifc2022 version.
I was able to fix some compatibility issues related to the Fortran2018 standard. However the last issue encountered seems to be out of scope. Here is a minimal example that leads to the error:
Module ModuleList
    implicit none
    type list(n)
        integer,len :: n
        integer :: items(n)
    end type list
    contains
        subroutine somefunction( n, myList)
            integer,intent(in) :: n
            type(list(n)) :: myList
        end subroutine somefunction
end Module ModuleList
subroutine somefunction2(n)
    use ModuleList
    implicit none
    integer, intent(in) :: n
end subroutine somefunction2
program main
end program main
Is it purely a compiler related issue, or, the code is not correctly written but the error is not caught properly? Unfortunately, my knowledges in Fortran and the use of derived data type are quite limited. The code is compiling fine with ifc2017.
Barbara_P_Intel
This ICE is fixed in the latest compiler release, ifort 2021.9.0 and ifx 2023.1.0. Both compilers are included in oneAPI HPC Toolkit 2023.1.
Please check it out!
Steve_Lionel
Your code is fine - the compiler is in error. I tried the newer ifx compiler, and it was also unhappy (not an ICE, but a complaint of unimplemented feature.) NAG Fortran compiles it without issue (other than remarking on unused variables.)
Arjen_Markus
gfortran 10.2.0 also accepts it ;).
Barbara_P_Intel
I filed a bug report, CMPLRIL0-34715, on this ICE.
Thanks for the tip that it used to compile ok. It first starts failing with 19.1.0.
bbur
@Steve_Lionel @Arjen_Markus
Thanks for the tests. Haven't thought about switching the compiler.
@Barbara_P_Intel
Thanks for the report. Is there a way to follow it up?
Barbara_P_Intel
@bbur I'll track the fix and post here when the fix is available.
bbur
OK, Thanks. I will wait for the fix to validate this topic.
bbur
Any news about this topic ? Is a fix available ?
Barbara_P_Intel
No resolution yet.
Barbara_P_Intel
bbur
Hello Barbara,
I checked the recent fix and I confirm that everything is working fine now.
Thank you !
I will close this issue.
