Internal compiler error when using matmul
haas__anthony
Our code uses large arrays and the matmul intrinsic. Recently, when compiling with -check all, I got an internal compiler error. I have stripped down the problem to a simple program (see attached). I am not sure if the problem is due to a very "bad use" of matmul but I thought I would look for advice on the problem. When compiling the attached program, with
ifort MatMulTest.F90 -traceback -check all,noarg_temp_created -o MatMulTest.x
I get the following error:
/tmp/ifortLOaq88.i90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for MatMulTest.F90 (code 1)
Anthony
Juergen_R_R
Valued Contributor II
I cannot reproduce this, it all works with v11, v13, v15, v16, v17, v18, v19.0 and v19.1 of the Intel Compiler with the options shown by you. Which version do you have?
haas__anthony
anthony@lina:~/Desktop$ source ~/Desktop/Intel-compiler-source.dat
anthony@lina:~/Desktop$ more MatMulTest.F90
! ifort MatMulTest.F90 -traceback -check all,noarg_temp_created -o MatMulTest.x
  Program testMatmul
    real*8 :: array(2,2,2,2,2,2,2)
    real*8 :: vec(2,2,2,2,2), sol(2,2,2,2,2)
    vec(1,:,:,:,:) = 1.0
    vec(2,:,:,:,:) = 2.0
    array = 1.0
    sol(1:2,1,1,1,1) = matmul( array(1,1,1,1,1:2,1:2,1), vec(1:2,2,2,2,2) )
  end program testMatmul
anthony@lina:~/Desktop$ ifort MatMulTest.F90 -traceback -check all,noarg_temp_created -o MatMulTest.x
/tmp/ifortUBw9TP.i90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
anthony@lina:~/Desktop$ which ifort
/opt/intel/compilers_and_libraries_2019.1.144/linux/bin/intel64/ifort
Anthony
Juergen_R_R
I think I did not have the traceback option.  An ICE is always a compiler error, so please report it to the Online Support Center.
haas__anthony
Hey Juergen,
Thanks for your email. Could you please give me a link to the Online Support Center, not sure who I need to contact.
Anthony
Juergen_R_R
