Internal compiler error with IFX
Francesco_F
I get the **Internal compiler error: internal abort** with IFX, while IFORT worked fine.
Here is an example code:
line 168 and 169 should be almost equivalent, but the first is fine, the second gives the compiler error.
MODULE myMODULE
    IMPLICIT NONE
    PRIVATE :: myPrivateLocSubroutine1,myPrivateLocSubroutine2
    PUBLIC :: publicSubroutine
    type , PUBLIC:: ARR_PROC_POINTER
       procedure(myProcedure_int), pointer,nopass :: myFunc
    end type ARR_PROC_POINTER
    ABSTRACT INTERFACE
        SUBROUTINE myProcedure_int(myArray,myInteger,myReal)
            IMPLICIT NONE
            REAL :: myArray(myInteger)
            INTEGER :: myInteger
            REAL :: myReal
        END SUBROUTINE myProcedure_int
    END INTERFACE
    INTERFACE publicSubroutine
        MODULE PROCEDURE publicSubroutine
    END INTERFACE
    PUBLIC
    TYPE, public :: tJustASmallerType
        REAL :: myReal
        INTEGER :: myInt
        REAL, ALLOCATABLE :: myArray(:)
        procedure(myProcedure_int),pointer,nopass :: myFunc
        contains
    END TYPE tJustASmallerType
    interface tJustASmallerType
        module procedure ConstructorJustASmallerType
    end interface tJustASmallerType
    TYPE, public :: tJustALargerType
        REAL :: myReal
        INTEGER :: myInt
        contains
    END TYPE tJustALargerType
    interface tJustALargerType
        module procedure ConstructorJustALargerType
    end interface tJustALargerType
    CONTAINS
    function ConstructorJustASmallerType(myArray,myInt,myReal) Result(this)
        IMPLICIT NONE
            type(tJustASmallerType) :: this
            INTEGER :: myInt
            REAL :: myReal
            ALLOCATE(this%myArray(myInt))
            this%myFunc => myPrivateLocSubroutine1
            this%myArray = myArray
            this%myInt = myInt
            this%myReal = myReal
    END FUNCTION ConstructorJustASmallerType
    function ConstructorJustALargerType(locFunc,myArray,myInt,myReal) Result(this)
        IMPLICIT NONE
            type(tJustALargerType), pointer :: this
            INTERFACE
                SUBROUTINE locFunc(locarray,locint,locreal)
                    IMPLICIT NONE
                    REAL        :: locarray(locint),locreal
                    INTEGER     :: locint
                END SUBROUTINE locFunc
            END INTERFACE
            INTEGER :: myInt
            REAL :: myReal
            this%myFunc => locFunc
            this%myInt = myInt
    END FUNCTION ConstructorJustALargerType
    SUBROUTINE myPrivateLocSubroutine1(myArray,myInt,myReal)
        IMPLICIT NONE
        INTEGER :: myInt
        REAL :: myReal
        REAL :: myArray(myInt)
        INTEGER :: i
        DO i =1,myInt
            myArray(myInt+1-i) = i*myReal
        ENDDO
    END SUBROUTINE myPrivateLocSubroutine1
    SUBROUTINE myPrivateLocSubroutine2(myArray,myInt,myReal)
        IMPLICIT NONE
        INTEGER :: myInt
        REAL :: myReal
        INTEGER :: i
        DO i =1,myInt
            myArray(i) = i*myReal
        ENDDO
    END SUBROUTINE myPrivateLocSubroutine2
    SUBROUTINE publicSubroutine(myArray,myInt,myReal)
        IMPLICIT NONE
        INTEGER :: myInt
        REAL :: myReal
        INTEGER :: i
        DO i =1,myInt
        ENDDO
    END SUBROUTINE publicSubroutine
END MODULE myMODULE
SUBROUTINE Init(myInt,myReal)
        USE myMODULE
        IMPLICIT NONE
        INTEGER, INTENT(IN) :: myInt
        REAL   , INTENT(IN) :: myReal
        TYPE(tJustASmallerType) :: JustASmallerType
        TYPE(tJustALargerType)  :: JustALargerType
        integer :: i
        ALLOCATE(myArray(myInt))
        DO i = 1, myInt
        ENDDO
        JustASmallerType = tJustASmallerType(myArray,myInt,myReal)
        JustALargerType = tJustALargerType(publicSubroutine, JustASmallerType%myArray,JustASmallerType%myInt,JustASmallerType%myReal) ! works!
        JustALargerType = tJustALargerType(JustASmallerType%myFunc, JustASmallerType%myArray,JustASmallerType%myInt,JustASmallerType%myReal) ! this line causes **internal compiler error:internal abort** only with IFX, while iFort works fine.
END SUBROUTINE Init
 thanks in advance for the support
mecej4
Which version of IFX did you use? The 2024.1.0 version of IFX on Windows compiled your code into an object file with /Od, /O1 or /O2, with no error messages.
mecej4
Francesco_F
Today I installed the IFX 2024, and it works. The 2023 was the one failing... thanks!
