29607 Discussions
Internal compiler error with MOD statement and /standard-semantics
Jacob_Williams
New Contributor III
FYI: The following code generates an internal compiler error (latest version of the compiler: 2011 Update 11), but only when I use the /standard-semantics flag.  It is caused when passing an allocatable array as the first argument of the MOD function (see test2 subroutine), while the second argument is a scalar.  The static array version (test1) compiles fine.
[fortran]program test
	implicit none
	call test1()
	call test2()
contains
	subroutine test1		!this one compiles file
	implicit none
	integer,dimension(2) :: a, b
	a = 4
	b = mod(a, 2)
	write(*,*) b
	end subroutine test1
	subroutine test2		!this one causes an internal compiler error
	implicit none
	integer,dimension(:),allocatable :: a, b
	allocate(a(2))
	allocate(b(2))
	a = 4
	b = mod(a, 2)
	write(*,*) b
	end subroutine test2
end program test
[/fortran]
Thanks, we'll take a look.
TimP
It looks like the problem was corrected in the 13.0 beta compiler, so should be OK in the next release.  standard-semantics changes the list-directed formatting; maybe that's what you intended.
It's the /assume:realloc_lhs part of /standard-semantics that is the problem here.  It isn't specifically the MOD but rather the assignment of the MOD expression to the allocatable array.  Tim is right that this is fixed in the 13.0 compiler, due out in a couple of weeks.  You could add /assume:norealloc_lhs to work around this for now.
