Internal compiler error
Ulrich_M_
The following code leads to an internal compiler error with Intel(R) Visual Fortran Compiler 19.1.3.311 [Intel(R) 64]
program test
	implicit none
	integer, parameter :: n=10
	real	:: x(n)
	integer :: inds(n),i
	inds=[(i,i=1,10)]
	x=0
	x(inds(nint(.15*n):))=x(inds(nint(.15*n):))+1
end program test
mecej4
The ICE also occurs with 2021.3.0 on Windows (ifort as well as ifx). Here is a work around:
i = nint(.15*n)
x(inds(i:))=x(inds(i:))+1
Barbara_P_Intel
@Ulrich_M_  Thanks for reporting this ICE.
@mecej4  Thanks for the workaround!
I filed a bug report, CMPLRIL0-34036, against both ifort and ifx. I'll let you know its progress to a fix.
Barbara_P_Intel
I just checked this issue with the latest ifort release 2021.6.0. The ICE you reported is gone.
This version of ifort is part of oneAPI 2022.2 that was recently released.
