Internal compiler error
Ernst_A__Meese
For lack of a better place to report an internal compiler error: The code below make ifort version 14.0.1 20131010 under OS X 10.9 crash. MODULE classAbstract IMPLICIT NONE TYPE, ABSTRACT :: TAbstract ! No data - merely a placeholder CONTAINS PROCEDURE(assignAbstract), DEFERRED, PASS(this) :: assign GENERIC :: ASSIGNMENT(=) => assign !< Commenting out this line make the code compile END TYPE TAbstract ABSTRACT INTERFACE SUBROUTINE assignAbstract( that, this ) IMPORT :: TAbstract CLASS(TAbstract), INTENT(in) :: this CLASS(TAbstract), ALLOCATABLE, INTENT(out) :: that END SUBROUTINE assignAbstract END INTERFACE END MODULE classAbstract MODULE classExtended USE classAbstract IMPLICIT NONE TYPE, EXTENDS(TAbstract) :: TExtended REAL :: foo CONTAINS PROCEDURE, PRIVATE, PASS(this) :: assign => assignExtended GENERIC :: ASSIGNMENT(=) => assign END TYPE TExtended CONTAINS SUBROUTINE assignExtended( that, this ) ! CLASS(TExtended), INTENT(in) :: this CLASS(TAbstract), ALLOCATABLE, INTENT(out) :: that SELECT TYPE( that ) TYPE IS (TExtended) that = this END SELECT END SUBROUTINE assignExtended END MODULE classExtended PROGRAM testit USE classAbstract USE classExtended IMPLICIT NONE CLASS(TAbstract), ALLOCATABLE :: isotherm ALLOCATE( TExtended :: isotherm ) isotherm = TExtended( 3.14 ) END PROGRAM testit
Ron_Green
I do not know why you would think there is a better place to report a bug - this forum is IDEAL for reporting bugs!  :)
I have opened a bug report against the compiler.  Thank you for sending this to us.  I will update this thread as we learn more about this bug.
ron
