29646 Discussions
Internal error when using a derived type decleared as a parameter
Olsen__Oystein
The following example generates an internal error. The internal error happens when I use a derived type that is declared as a parameter and in contains a generic binding. The offending statement is on line 76, while line 27 describes a work around.
I am using intel fortran 14.0.1 on openSUSE 12.3
[fortran]
MODULE HS2Kinds
USE ISO_FORTRAN_ENV, ONLY: INT32
USE ISO_FORTRAN_ENV, ONLY: REAL32, REAL64, REAL128
INTEGER, PARAMETER :: I4B = INT32
INTEGER, PARAMETER :: SP = REAL32
INTEGER, PARAMETER :: DP = REAL64
INTEGER, PARAMETER :: QP = REAL128
END MODULE HS2Kinds
MODULE HS2Frame
USE HS2Kinds
IMPLICIT NONE
PRIVATE
PUBLIC :: HSFrame, ITRF, ICRF
TYPE HSFrame
INTEGER(I4B), PRIVATE :: val = -1
CONTAINS
GENERIC :: toFrame => toFrameq, toFramed, toFrames
PROCEDURE, PASS :: toFrameq
PROCEDURE, PASS :: toFramed
PROCEDURE, PASS :: toFrames
END TYPE HSFrame
TYPE(HSFrame), PARAMETER :: ITRF = HSFrame(3)
TYPE(HSFrame), PARAMETER :: ICRF = HSFrame(12)
!ICE: No ICE with these two statements instead of those above.
!TYPE(HSFrame) :: ITRF = HSFrame(3)
!TYPE(HSFrame) :: ICRF = HSFrame(12)
CONTAINS
SUBROUTINE toFrameq(this, frm, r)
USE HS2Kinds, ONLY: XP => QP
CLASS(HSFrame), INTENT(IN) :: this, frm
REAL(XP), INTENT(INOUT) :: r(3)
! Dummy code
IF (this%val == 12 .AND. frm%val == 12) THEN
r = -1.0_XP
ELSE
r = REAL(frm%val, XP)
END IF
RETURN
END SUBROUTINE toFrameq
SUBROUTINE toFramed(this, frm, r)
USE HS2Kinds, ONLY: XP => DP
! Dummy code
r = -1.0_XP
ELSE
END IF
RETURN
END SUBROUTINE toFramed
SUBROUTINE toFrames(this, frm, r)
USE HS2Kinds, ONLY: XP => SP
! Dummy code
r = -1.0_XP
ELSE
END IF
RETURN
END SUBROUTINE toFrames
END MODULE HS2Frame
PROGRAM test
USE HS2Kinds
USE HS2Frame, ONLY: ITRF, ICRF
REAL(DP) :: r(3)
CALL ICRF%toFramed(ITRF, r)
!ICE: Internal error
CALL ICRF%toFrame(ITRF, r)
END PROGRAM test
[/fortran]
Kevin_D_Intel
Thank you for reporting this and for the convenient reproducer. I reproduced this with our latest CXE 2013 SP1 Update 1 also.
(Updated 11/8/2013): Steve escalated to Development.
Issue ID is DPD200249703.
This has been fixed for a release later this year.
FortranFan
Steve,
Will it be possible to provide a target release version info along with such notifications?  Something like, "The fix is targeted for release in compiler version X due later this year" where X can be compiler 14, Update 3 (if there is such a thing), or XE 2015 (aka compiler 15?), etc.
I understand this may be difficult, but it will be very useful for us users if we know the target version.  Otherwise, we have to loop back with future release and see if the fix has been made it in there.
If I say "release", I mean a major version release with a number higher than the current one. I'm not supposed to talk about what that number is before the product is released, especially as version numbers are really marketing things, but there will be only one major release this year so whatever it is called later this year, that will be it. But you can probably guess. (It won't be a "SP")
If I say "update", I mean an update to the current version, and I can usually give a timeframe for that.
FortranFan
Subtle and cool!  Thanks much for the explanation, I understand better.
