Interop C and Fortran problem
zmi007
I cannot figure out, why I am not able to pass len argument correctly into c function from fortran (gfortran + gcc handle this code without any obvious problem)
simple C function
#include <stdint.h>
#include <stddef.h>
#include <stdio.h>
int32_t test (char* key, size_t len)
  int32_t hash = 666;
  printf("c key %s\n", key);
  printf("c len %u\n", len); // expected 2
  printf("c hash = %u\n", hash);
  return hash;
Fortran program
!Module interface_module
module interface_module
   implicit none
   interface
      function test(key, length) result(hash) bind(c, name="test")
         use iso_c_binding
         character(kind=c_char),dimension(*) :: key
         integer(c_size_t), value :: length
         integer(c_int32_t) :: hash
      end function test
   end interface
   abstract interface
      function function_hash_template(key, length)
         use iso_c_binding
         integer(c_int32_t) :: function_hash_template
      end function function_hash_template
   end interface
contains
   function test_wrap(text) result(hash)
      use iso_fortran_env
      implicit none
      character(len=*),intent(in) :: text
      integer(int32) :: hash
      procedure(function_hash_template), pointer :: fun
      fun => test
      hash = int(hash_wrap(text, fun), int32)
   end function test_wrap
   !Function
   function  hash_wrap(text, fun) result(hash)
      use iso_c_binding
      implicit none
      character (len=*), target, intent(in) :: text
      character(kind=c_char), dimension(len_trim(text)+1) :: text_c
      integer(c_size_t) :: length
      text_c = f_to_c_string(text) ! convert to c string for compatibility
      length = len_trim(text) + 1
      write(*,*) "hash_wrap, length = ", length
      hash = fun(text_c,length)
   end function hash_wrap
   pure function f_to_c_string (f_string) result (c_string)
      use, intrinsic :: iso_c_binding, only: c_char, c_null_char
      implicit none
      character(len=*), intent(in) :: f_string
      character(len=1,kind=c_char), dimension(len_trim(f_string)+1) :: c_string
      integer :: n, i
      n = len_trim(f_string)
      do i = 1, n
         c_string(i) = f_string(i:i)
      end do
      c_string(n + 1) = c_null_char
   end function f_to_c_string
end module interface_module
!Main program test_main
program    test_main
   use interface_module
   implicit none
   write(*,*) test_wrap("1")
end program test_main
Instead of expected len = 2 I am getting always some uninitialized random len value in c function
./test_size_t_ifort_f.x
 hash_wrap, length =                      2
c key 1
c len 2977349904
c hash = 666
         666
ifort --version
ifort (IFORT) 16.0.2 20160204
Hmm. I will take a look at this in the morning. At first glance I think the problem is you're missing bind(C) on function_hash_template. This will change the way length is passed.
zmi007
Thank you, Steve.
bind(c) solves it indeed, I was a bit confused by the "abstract interface" of the function.
Glad to hear it, though your saying gcc/gfortran accepted this suggests a bug in gfortran. Actually, the original code would have "worked" in some earlier versions of ifort as we had a bug in how we interpreted the VALUE attribute for non-bind(C) routines. We made the correct (standard-conforming) behavior the default in version 16.
TimP
my gcc does warn about the discrepancy between %u and size_t (when -Wall is set, same for Intel C, which also warns about %u and int32_t).  %zu and %d are accepted without warning, but the thing still hangs at run time when using gfortran.
For reference, here's the main issue at hand.
The Fortran standard specifies different behavior for the VALUE attribute depending on whether the procedure being declared is "interoperable" (has BIND(C)) or not. Note that this is NOT our !DEC$ ATTRIBUTES VALUE extension.
For an interoperable procedure, VALUE means pass-by-value. The actual words in the standard are "interoperable with the corresponding formal parameter of the type" (and not of a pointer type.)
For a non-interoperable procedure, one without BIND(C), VALUE causes a writable, temporary copy of the argument to be passed by reference. So in zmi007's case, the call through the procedure pointer, defined with an interface that did not have BIND(C), caused the address of a copy of "length" to be passed. The C routine interpreted the address as the length itself, which was wrong. Adding BIND(C) to the procedure pointer's interface corrects this.
When ifort first implemented the F2003 C interoperability features we got this wrong, and always treated the Fortran standard VALUE attribute the same as !DEC$ ATTRIBUTES VALUE. In version 15 we added -assume std_value to specify the standard behavior for non-interoperable procedures, and in version 16 turned this on by default. Most of the time, VALUE is used in conjunction with BIND(C) so we didn't see a lot of issues with this change, but there were some.
zmi007
Thnx Steve for explanation. Yes, I will try to start a talk about it in gfortran bugzilla. Tim, just ignore warnings, I tried to create minimal working example from the code and didn't manage to do it clean enough obviously. Originally, I use there int64, int32 integers and uint32_t in C and some collection of trafo/shifting routines for different integers kinds. My task is to implement hash functions library in fortran and I needed to compare fortran hashes with hashes from c functions in order to verify my implementation. That is the background of this code.
