Interoperable global data in submodule error
rudi-gaelzer
Using (ifort -V):
ntel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.222 Build 20180410
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
The following code:
module bind_mod
implicit none
interface
   module function do_nothing()
   real :: do_nothing
   end function do_nothing
end interface
end module bind_mod
submodule(bind_mod) bind_smod
use, intrinsic :: iso_c_binding, only: c_int
implicit none
integer(c_int), bind(c) :: nts
contains
   real :: do_nothing
   return
end submodule bind_smod
Generates the following error message:
ifort -c tes_bind_smod.f90
tes_bind_smod.f90(13): error #8067: If any bind-entity in a bind-stmt is an entity-name, the bind-stmt shall appear in the specification part of a module.   [NTS]
tes_bind_smod.f90(15): error #6645: The name of the module procedure conflicts with a name in the encompassing scoping unit.   [DO_NOTHING]
tes_bind_smod.f90(15): warning #6178: The return value of this FUNCTION has not been defined.   [DO_NOTHING]
compilation aborted for tes_bind_smod.f90 (code 1)
The same module/submodule are compiled with gfortran without errors and I think that's correct; I don't think the code violates the standard.
FortranFan
I think the code is non-conforming and so is gfortran.
Constraint C519 in the current Fortran standard requires a variable with BIND attribute to be in the specification part of a module.
(Edit: change C818 to C519 since Fortran 2008 is still the official standard.)
rudi-gaelzer
Constraint C818 in the current Fortran standard requires a variable with BIND attribute to be in the specification part of a module.
OK, thanks.  Found in ISO/IEC 1539-1 of F2018.  The same rule is in C518 of J3/10-007r1 of F2008.
Do you think it's worth to mention this in comp.lang.fortran?
FortranFan
rudi-gaelzer wrote:
.. The same rule is in C518 of J3/10-007r1 of F2008.
Re: gfortran, you may want to submit the issue at the GCC reporting site - if you don't have an account there or can't get one easily, posting the issue at comp.lang.fortran may help some GCC volunteer to pick it up.
(Edit: removed my erroneous comment about the constraint being C818 in both Fortran 2008 and (Committee Draft) Fortran 2018 standard documents.)
rudi-gaelzer
FortranFan wrote:
Note it's the same named constraint - C818 - in both documents you mention, surprisingly!
Errmm... are we talking the same thing here?  In WD 1539-1 (version 2010-11-24), C818 reads:
C818
(R830) A do-term-shared-stmt shall not be an arithmetic-if-stmt, cycle-stmt, end-function-stmt, end-
program-stmt, end-mp-subprogram-stmt, end-subroutine-stmt, error-stop-stmt, exit-stmt, goto-stmt, return-
stmt, or stop-stmt.
BTW, it's C519 that refers to module.  C518 is:
C518 An entity with the BIND attribute shall be a common block, variable, type, or procedure.
C519 A variable with the BIND attribute shall be declared in the specification part of a module.
Anyway, thanks again.  Will post this at comp.lang.fortran
FortranFan
rudi-gaelzer wrote:
.. Errmm... are we talking the same thing here?  ..
My bad.. I had 16-007r1 (an early draft of Fortran 2018) document open and mistakenly thinking it was 10-007r1 toward Fortran 2008.
