29391 Discussions
Intrinsic `transfer` with a provided size: (un)expected behavior?
Jeremie_V_
Dear,
Here is a small Fortran program to reproduce the reason of my question:
```fortran
program test
use iso_fortran_env, only: int32, int16
implicit none
integer(int32), parameter :: m1 = int(z'776BF593', int32)
integer(int16), parameter :: m116(2) = transfer( m1, 0_int16, 2 )
print*, 'Should ', transfer(m116, 0_int32), ' be equal to ', m1, '?'
write(*,'(b32.32)')     m1
write(*,'(2(b16.16))') m116
end program
Based on the Intel documentation of the intrinsic `transfer` that mentions "...Otherwise, the result contains the bit pattern contained in source", I was expecting that the `m116` defined as `m116(2) = transfer(m1, 0_int16, 2)` would have the same bit pattern as `m1`. However, this is not the case for the last bit (sign bit?).
Is the application of `transfer` on this last bit processor-dependent, as `m1` and `m116` are `integer`?
In advance thank you.
* OS: Fedora 34
* Compiler: ifort (IFORT) 2021.4.0 20210910
Labels (2)
Devorah_H_Intel
Thank you for your report. This issue has been escalated to compiler engineering.
wclodius
FWIW on my machine M116 differs from m1 in more than the first bit. The two elements of m116 have the same value [-2669,-2669] while gfortran gives [-2669,  30571]. It appears that m116(2) = transfer( m1, 0_int16, 2 ), instead of transferring all 32 bits to m116, is just replicating the first 16 bits twice. For transfer, I would expect something similar to a C type cast of a 32 bit integer to a pair of overlaid 16 bit integers, which is what I get from gfortran.
Jeremie_V_
Following the meassage of @wclodius , I had a closer look, and indeed, more than 1 bit changed.
Here are the result for ifort 2021.4.0:
m116 -2669 -2669
-174852717 should be equal to 2003563923 ?
01110111011010111111010110010011
11110101100100111111010110010011
I can reproduce this behaviour with `ifx 2021.4.0` and `ifort 17.0.0`
Jeremie_V_
This seems to be a bug when `transfer` is used with `parameter`, because when used without `parameter`, the back-transfer returns the original result.
program test
implicit none
integer(int16) :: m216(2)
print*,'m116 ',m116
m216 = transfer( m1, 0_int16, 2 )
print*,'m216 ',m216
print*,transfer(m116, 0_int32), ' should be equal to ', m1,'?'
print*,transfer(m216, 0_int32), ' should be equal to ', m1,'?'
write(*,'(b32.32)')m1
write(*,'(2(b16.16))')m116
write(*,'(2(b16.16))')m216
end program
output:
m116 -2669 -2669
m216 -2669 30571
2003563923 should be equal to 2003563923 ?
11110101100100110111011101101011
Devorah_H_Intel
Jeremie_V_
Thank you.
