29650 Discussions
Invalid Specifier Problem on Windows
cainlord
When building my executable I run into the following error message:
winwrite.f90(22) : Error: A * specifier is invalid at this point in the control list.
write(UNIT=post_file,*) "K= :", k
I have built this same file correctly on our sun-based system. I am running Compaq Visual Fortran Optimizing Compiler Version 6.6 (Update A). Here is a simple source version:
module winwrite_mod
implicit none
save
integer, parameter :: post_file = 952
end module winwrite_mod
program winwrite
use winwrite_mod
implicit none
integer :: k
character(len=3) :: junk_string
k = 3
junk_string = "foo"
open(UNIT=post_file,FILE=junk_string,ACTION="WRITE",STATUS="REPLACE")
close(unit=post_file)
end program winwrite
james1
You are using a formal argument name for UNIT in the WRITE statement, then expecting the format to be accepted positionally. Your write statement should be either:
WRITE(UNIT=post_file,FMT=*)
or
WRITE(post_file,*)
James
To expand on James' correct response - in Fortran, once you use a keyword argument name (or I/O control list keyword), you must use keywords for all subsequent arguments. It seems that Sun has an extension which your program took advantage of, but Visual Fortran doesn't support that.
Consider that if you had this:
WRITE (ERR=300,*) X
Is the * the UNIT or the FMT?
Steve
