29640 Discussions
Is DeleteFile an Intel-specific procedure?
Arjen_Markus
we just ran into a strange problem: introducing a routine "DeleteFile" in a module
causes the compiler to complain that that name conflicts with a name in the encompassing scoping
unit. There is however no other routine or variable name like that in the entire program.
There is also no documentation of such a routine and we are not - as far as I can tell -
using any Intel specificmodule (could DeleteFile be the name of a Windows system function?)
At the point where this routine is used, we get the complaint that afunction isused as a
routine.
But in a small program, just defining a module andasubroutine by that name, the problem
does not occur.
We are using Intel Fortran 11.1.
We can easily change this name, that is no problem. I amsimply surprised that this occurs.
Arjen
anthonyrichards
New Contributor III
According to http://msdn.microsoft.com/en-us/library/windows/desktop/aa363915%28v=vs.85%29.aspx,
DeleteFile exists in kernel32.lib
So maybe there is a clash when you USE KERNEL32 (included in USE IFWIN I think)
Arjen_Markus
Bingo!
Somewhere deep down there is a use of kernel32 and user32 - I looked for IFWIN and IFPORT.
Thanks, that clears that question.
Arjen
