29563 Discussions
Is a mismatch in proc_language_binding_spec (e.g., bind(C)) between procedure pointer object and the target allowed?
FortranFan
Is the following simple code snippet standard-conforming?  The code compiles with no errors or warnings with the latest Intel Fortran 16.0 compiler, update 1.  Note the missing proc_language_binding_spec of bind(C) on the procedure target which, to me, appears like a difference in characteristics of the object and the target.  Is this something a coder can expect from the compiler to get flagged as an error?
module m
   implicit none
   abstract interface
      subroutine Ifoo() bind(C)
      end subroutine Ifoo
   end interface
   procedure(Ifoo), pointer :: foo => subfoo
contains
   subroutine subfoo()  !.. Note the missing proc_language_binding_spec of bind(C)
   end subroutine subfoo
end module m
Listed below is an extract from Fortran 2008 standard document (WD 1539-1 J3/10-007r1 dated 2010-11-24):
7.2.2.4 Procedure pointer assignment
3 If the pointer object has an explicit interface, its characteristics shall
  be the same as the pointer target except that the pointer target may be
  pure even if the pointer object is not pure and the pointer target may be an
  elemental intrinsic procedure even if the pointer object is not elemental.
One of the "characteristics of procedures" is "whether it has the BIND attribute" (12.3.1), so no, this code is nonconforming. The standard doesn't require a compiler to diagnose it, but a good one should.
However,I'd sure like to know which ifort you managed to get this to compile with, as we don't yet support pointer initialization to anything but NULL():
U607837.f90(13): error #6592: This symbol must be a defined parameter, an enumer
ator, or an argument of an inquiry function that evaluates to a compile-time con
stant.   [SUBFOO]
U607837.f90(13): error #6973: This is not a valid initialization expression.   [
SUBFOO]
When I compile this with an internal copy of our next major release, it complains:
U607837.f90(13): error #8178: The procedure pointer and the procedure target mus
t have matching arguments.
Not the best error message (I will let the developers know about this), but an error nonetheless. I get the same error if I use pointer assignment in 16.0. But I poked more at this and see that even if I do add the BIND(C) to subfoo I still get this error, so something else is wrong.
Ah, turns out this is more interesting... The error message above is unrelated to the BIND mismatch and happens when the procedure has no arguments. This was previously reported as DPD200378606. When I modified the source to account for that, ifort indeed doesn't detect the mismatch in BIND, so I escalated that as DPD200381358.
FortranFan
Steve Lionel (Intel) wrote:
.. However,I'd sure like to know which ifort you managed to get this to compile with, as we don't yet support pointer initialization to anything but NULL(): .. .. But I poked more at this and see that even if I do add the BIND(C) to subfoo I still get this error, so something else is wrong.
Steve,
Thanks much for reviewing this.  Sorry I got a bit confused in keeping code and the compiler version consistent while being eager to put together a small reproducer.  For Intel compiler, the snippet should be as follows, a variant of the one in the original post:
module m
   use, intrinsic :: iso_c_binding, only : c_int
   implicit none
   abstract interface
      subroutine Ifoo( i ) bind(C)
         import :: c_int
         integer(c_int), value :: i
      end subroutine Ifoo
   end interface
contains
   subroutine subfoo( i ) bind(C)
   subroutine bar()
      foo => subfoo
   end subroutine bar
end module m
Compiling with Intel(R) Visual Fortran Compiler 16.0.1.146 [Intel(R) 64]...
m.f90
m - 0 error(s), 0 warning(s)
Strange things is if the dummy argument i is removed, then the compiler gives error #8178.  So as you indicated, something is not quite right.  Perhaps you can discuss with developers and make sense out of the several scenarios.
Yes, see my later reply. I constructed an example just like your later one and saw the issues.
This has been fixed for a major release later this year.
