29380 Discussions
Is fstack-protector-all supported on MIC?
Mark_M_4
I'm debugging a crash in my Fortran code, and would like to try stack protection.
Is fstack-protector-all supported on the MIC platform?  When I build with -mic -fstack-protector-all the executable crashes because it can't find the libssp.so.0 library.  Is a MIC version of that library supposed to be included with my compiler?  I'm using ifort 14.0.2.
Thank you for your help.
TimP
I suppose you may require -mmic -g -fstack-protector-all.
On my installation, 'locate libssp | grep k1om'  shows me /opt/mpss/3.2.3/sysroots/k1om-mpss-linux/usr/lib64/.debug/libssp.so on host but it is not mounted nor copied by default to coprocessor.  I stopped trying to update mpss due to the age of my system.
It's normal to require boosting the stack limit e.g. 'ulimit -s unlimited' on the coprocessor when running a normal (large) number of threads, unless it is possible to reduce the individual thread stack limit from the default 4M.  I suspect that the optimization of number of threads per MPI process vs. number of ranks may be limited by this (e.g. 6 ranks of 30 threads each with OMP_STACK_SIZE=9m will still require "unlimited" stack).
I don't know whether the stack-protector option has been used successfully on MIC.  Without it, stack overflow may break an application without throwing a segfault as you would expect on host.
pbkenned1
Let me investigate and I'll get back to you.
Patrick
TimP
pbkenned1
I believe -fstack-protector-all should be supported for MIC, but I can't produce a dependency on libssp.so with my own example:
[U539581]$ ifort -g -fstack-protector-all -mmic getTypeBoundPtKB.f90 -o getTypeBoundPtKB.f90-mic.x
[U539581]$
[mic0 pbkenned]# ./getTypeBoundPtKB.f90-mic.x
 subArray =          99          99          99          99
[mic0 pbkenned]#
Can you please:
1) Attach a test case
2) Indicate your exact compile command line
3) Repeat 2), but add -dryrun, capture the output, and attach.
4) Indicate what version of MPSS you are using
Patrick
Mark_M_4
Thank you, I used locate to find the k10m version of libssp.  The MIC executable ran successfully.
pbkenned1
If you're satisfied with copying libssp to the card, then we'll consider this case closed.
Patrick
