29376 Discussions
Is having a RETURN statement inside a BLOCK construct legal?
OP1
New Contributor III
Is the following code legal Fortran 2008? I have two compilers that differ in opinion here:
BLOCK
    RETURN
END BLOCK
Yes, it is.
8.1.2.2 Execution of a block
2 Execution of the block is completed when
 • the last executable construct in the sequence is executed,
 • a branch (8.2) within the block that has a branch target outside the block occurs,
 • a RETURN statement within the block is executed,
 • an EXIT statement within the block that belongs to the block or an outer construct is executed, or
 • a CYCLE statement within the block that belongs to an outer construct is executed.
OP1
New Contributor III
Thanks Steve for the clarification.
