29429 Discussions
Is it a bug of Intel Fortran Compiler 11?
haifeng2009
[sectionBody]
I am developing a complicated CFD code. During the development, I found that the codes generated by
Intel Fortran 10 and 11 produced different results, and the code from 11 seems obvious wrong. This puzzled
me for some time. Recently, I was able to reproduce the problem in the following simple code.
The expected output from the code is
1. 1. 1. 1. 1. 1. 1. 1.
-2. -2. -2. -2. -2. -2. -2. -2.
-3. -3. -3. -3. -3. -3. -3. -3.
However, the output with compiler 11 is
-1. -1. -1. -1. -1. -1. -1. -1.
3. 3. 3. 3. 3. 3. 3. 3.
The problem occurs for win32 and x64 with or without optimization. Is it a bug of the compiler or a bug of our coding.
The compiler I have the problem is 11.0.3451.2005.
Haifeng
module sd_data_mod
    type mydattype
        real,pointer    :: fld(:,:,:,:)
    end type mydattype
    type(mydattype)     :: mt
end module sd_data_mod
program main
    use sd_data_mod
    allocate(mt%fld(2,2,2,3))
    mt%fld(:,:,:,1) = 1
    mt%fld(:,:,:,2) = 2
    mt%fld(:,:,:,3) = 3
    call view(mt%fld(:,:,:,2:3),2)
    write(*,'(100f4.0)') mt%fld(:,:,:,1)
    write(*,'(100f4.0)') mt%fld(:,:,:,2)
    write(*,'(100f4.0)') mt%fld(:,:,:,3)
! expected correct output are:
!   1.  1.  1.  1.  1.  1.  1.  1.
!  -2. -2. -2. -2. -2. -2. -2. -2.
!  -3. -3. -3. -3. -3. -3. -3. -3.
end program main
subroutine view(fld,ns)
    use sd_data_mod
    integer     :: ns
    real        :: fld(2,2,2,ns)
    fld = -fld
end subroutine view[/sectionBody]
TimP
With 11.1.046 32-bit I have your expected result. with all options I can think of.
11.0.3451.2005 is not the compiler version - that's the Visual Studio integration version. Please download and install 11.1.046 and try your program again.
haifeng2009
Thenhere is the compiler version I am using: 11.0.061.
haifeng2009
Quoting - tim18
With w_cprof_p_11.1.046, I have the right result. It seems that this is a compiler bug in the old version, and It has been fixed in the current version. Thanks.
abhimodak
Hi
Which version has this "bug"?
Abhi
haifeng2009
Quoting - abhimodak
Hi
Abhi
I am using w_cprof_p_11.0.061 which gives the error. So at least this version has the problem, and maybe other versions before and after this vresion.
Haifeng
