29627 Discussions
Issue with ALLOCATE(..., SOURCE=...) and polymorphic array slices
thomas_boehme
New Contributor II
I experience unexpected behavior when allocating a polymorphic array from a part of another polymorphic array. I have added a fully working program demonstrating the problem.
In both cases, I would have expected to get a TargetItems array with 5 elements. But in the first case, I get an array with 10 elements, i.e. the full size of the SourceItems array.
I have seen this behavior with the latest IVF 17.0.0.109 as well as several previous versions.
Another issue: In the debugger (using IVF 17 and VS 2015 Update 3), all arrays are shown as undefined even after the allocate...
Thomas
  program AllocateSourceIssueWithArraySlice
   implicit none
    type :: baseType
      integer aValue
    end type
      class (baseType), ALLOCATABLE :: SourceItems(:)
      class (baseType), ALLOCATABLE :: TargetItems(:)
      ALLOCATE( baseType::SourceItems(10))
      print *, 'Allocating with arrayslice in SOURCE= statement'
      ALLOCATE( TargetItems, SOURCE=SourceItems(1:5) )
      print *, 'Size SourceItems (expected 10): ', SIZE(SourceItems)
      print *, 'Size TargetItems (expected 5):  ', SIZE(TargetItems)
      DEALLOCATE(TargetItems)
      print *, 'Allocating with arrayslice via assosciate construct'
      ASSOCIATE (Source => SourceItems(1:5))
      ALLOCATE( TargetItems, SOURCE=Source )
      END ASSOCIATE
      end program
Thanks - escalated as issue DPD200414141. Interesting that if the source array is not polymorphic, it works correctly.
The fix for this might not make Update 1, but if not, definitely Update 2.
thomas_boehme
New Contributor II
Thanks for the update on this issue.
Steve, in my original post I also mentioned that I am unable to see the variables in the above program in the debugger (VS2015 Update 3/IVF 17). Is that something specific to my installation or do have this issue as well?
The debugger issue is unrelated - the debugger still has problems with polymorphic variables. I will check with our debugger folk to make sure they're aware of this (DPD200414790).
