29625 Discussions
Issue with FileNotFoundError when calling Fortran DLL in Python related to dgesv
411390
Dear Intel Fortran Community,
I hope this message finds you well. I am currently working with Intel Fortran and Python, and I have encountered an issue that I am hoping you might be able to help me with.
After compiling a Fortran code using the command:
ifx /dll /libs:static /Qmkl sample.f90
I attempt to call resulting 'sample.dll' via 'ctypes.CDLL' in Python, but I receive the following error:
FileNotFoundError : Could not find module '{sample.dll's folder path}' (or one of its dependencies). Try using the full path with constructor syntax.
The file path to 'sample.dll' is correct, and it exists on the system. I have verified that there are no errors in the code or the compilation, but the call from Python does not work, and I have been unable to resolve the issue.
Here is a snippet of the Fortran code I am working with, which includes a call to the 'dgesv' routine for solving linear systems:
module sample
    use ISO_C_binding
    implicit none
    contains
    subroutine solve_linear_system(imax, jmax, matA, matB, info, matX) bind(C, name = "solve_linear_system")
        !DEC$ ATTRIBUTES DLLEXPORT :: solve_linear_system
        integer(c_int), intent(in) :: imax
        integer(c_int), intent(in) :: jmax
        real(c_double), intent(in) :: matA(imax, imax)
        real(c_double), intent(in) :: matB(imax, jmax)
        integer(c_int), intent(out) :: info
        real(c_double), intent(out) :: matX(imax, jmax)
        integer(c_int) :: ipiv(imax)
        external dgesv
        call dgesv(imax, jmax, matA, imax, ipiv, matB, imax, info)
        matX = matB
    end subroutine solve_linear_system
end module sample
To resolve this issue, I have tried adding environment variables with dependent DLL folders and experimented with different compile options such as /Qmkl-ilp64, but to no avail.
Any insights or suggestions would be greatly appreciated. Thank you very much for your time and assistance.
Fengrui
If the path to sample.dll is correct, it might be the dependencies not in the Python environment. Could you please try linking to oneMKL through Single Dynamic Libray?
Thank you for your reply.
I tried the following compile command.
ifx /dll /libs:static /Qmkl /I"%MKLROOT%\include" sample.f90 /link mkl_rt.lib
 The output was as follows:
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.0.4 Build 20241205
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.38.33133.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:sample.dll
-dll
-implib:sample.lib
"-libpath:C:\Program Files (x86)\Intel\oneAPI\mkl\latest\lib"
mkl_rt.lib
sample.obj
   ライブラリ sample.lib とオブジェクト sample.exp を作成中
However, since the error was not resolved, I tried the following:
  1. Rechecking if "call dgesv" was the cause
    I commented out the line "call dgesv" in the sample Fortran code, and the error was resolved.
  2. Checking the dependent DLL files with the "dumpbin /dependents" command.
Microsoft (R) COFF/PE Dumper Version 14.38.33133.0
Dump of file sample.dll
File Type: DLL
  Image has the following dependencies:
    mkl_rt.2.dll
    KERNEL32.dll
  Summary
        3000 .data
        2000 .pdata
       1A000 .rdata
        1000 .reloc
       26000 .text
        1000 .trace
        2000 _RDATA​​
      3.Verifying whether the dependent DLL files (mkl_rt.2.dll and KERNEL32.dll) are being loaded correctly with Dependency Walker.
Despite these efforts, the issue persists. I would appreciate any insights or suggestions on how to resolve this issue.
jimdempseyatthecove
Your compiler output indicates that it is linking mkil_rt.lib
whereas the dependency indicates that it is looking for mkl_rt.2.dll
There may be an issue what the .lib is looking for.
Jim Dempsey
Ruqiu_C_Intel
Have you tested oneMKL example(for example, C:\Program Files (x86)\Intel\oneAPI\mkl\latest\share\doc\mkl\examples\examples_core_f.zip\f\lapack\source\dgesvx.f) alone to verify your oneAPI environment is fine?
I copied and pasted the file C:\Program Files (x86)\Intel\oneAPI\mkl\latest\share\doc\mkl\examples\examples_core_f.zip\f\lapack\source\dgesvx.f into my working folder, complied it into an exe file, and ran it.
C:%WorkingFolder%>ifx /Qmkl /o dgesvx.exe dgesvx.f
-out:dgesvx.exe
-subsystem:console
dgesvx.obj
C:%WorkingFolder%>dgesvx.exe
 DGESV Example Program Results
 Solution
  -0.80  -0.39   0.96
  -0.70  -0.55   0.22
   0.59   0.84   1.90
   1.32  -0.10   5.36
   0.57   0.11   4.04
 Details of LU factorization
   8.23   1.08   9.04   2.14  -6.87
   0.83  -6.94  -7.92   6.55  -3.99
   0.69  -0.67 -14.18   7.24  -5.19
   0.73   0.75   0.02 -13.82  14.19
  -0.26   0.44  -0.59  -0.34  -3.43
 Pivot indices
      5      5      3      4      5
Can I consider this as a correct verification of my oneAPI environment?
Ruqiu_C_Intel
It shows oneMKL is fine for Fortran from the test.
Let's wait Fortran community provides more comments here.
