29541 Discussions
Issue with !$OMP ATOMIC UPDATE CAPTURE
OP1
New Contributor III
The following code (compiled on Windows with ifx 2026.0.0 and using the compiler option \Qopenmp) freezes after the first WRITE statement, usually after a small number of iterations on the loop index I. I can't figure out what is wrong here, and I am inclined to report this as a bug.
This is a showstopper for us, thus any alternative to the pattern shown here would be very much appreciated!
PROGRAM OMP_ATOMIC_TEST
USE OMP_LIB
IMPLICIT NONE
INTEGER :: I, ERROR
INTEGER, SAVE :: ERROR_LOCAL, ERROR_TEMP
!$OMP THREADPRIVATE(ERROR_LOCAL, ERROR_TEMP)
CALL OMP_SET_NUM_THREADS(10)
DO I = 1, 20 ! The purpose of this loop is to demonstrate the issue, it is unrelated
             ! to the following PARALLEL region. The code will freeze for some value
             ! of I, after having issued the first WRITE statement, and inside the
             ! ATOMIC UPDATE CAPTURE region.
    !$OMP PARALLEL
        IF (OMP_GET_THREAD_NUM() == 1) THEN
            WRITE(*, *) 'Begin ATOMIC CAPTURE region ', I
                ERROR_TEMP = ERROR ! Capture
                ERROR      = 1     ! Update
            !$OMP END ATOMIC
            ERROR_LOCAL = ERROR_TEMP
            WRITE(*, *) 'End ATOMIC CAPTURE region'
        END IF
    !$OMP END PARALLEL
END DO
END PROGRAM OMP_ATOMIC_TEST
