29542 Discusiones
Issue with OpenMP and automatic lhs allocation of string variable
OP1
Nuevo Colaborador III
29 Vistas
I believe that the code shown below (built with ifx 2026.0.0 on Windows 11) is standard-compliant; however, it crashes with the message: "forrtl: severe (153): allocatable array or pointer is not allocated".
PROGRAM P
IMPLICIT NONE (TYPE, EXTERNAL)
CHARACTER(LEN = :), ALLOCATABLE :: S
S = '' ! The code will work if this line is commented out.
!$OMP PARALLEL PRIVATE(S)
    S = 'Hi!'
    WRITE(*, *) S
!$OMP END PARALLEL
END PROGRAM P
Similar codes, where the allocatable variable is an integer array, do not exhibit the same behavior. It seems the bug is limited to the automatic lhs allocation of S on line 8.
0 kudos
1 Responder
JohnNichols
Colaborador Distinguido I
18 Vistas
It runs on latest ONEAPI, but throws the errors and then performs ok
You cannot debug it, it sticks on line 6.
PROGRAM P
CHARACTER(:), ALLOCATABLE :: S
!S = 'A' ! The code will work if this line is commented out.
    S = 'Hi!'
    WRITE(*, *) S
!$OMP END PARALLEL
END PROGRAM P
  But this runs, remove the null assignment of S, why do you need it, as you note?  The standard Intel note does not have LEN =
Responder
