29649 Discussions
Issue with loop for allocatable array in private (openmp)
Danny_L_
Dear community,
​I am encountering a weird problem involving OpenMP. This simple code snippet
integer :: elem_no
integer :: no_nod_elem
real(dp), allocatable, dimension(:) :: fiss_den
!$OMP PARALLEL DO &
!$OMP& DEFAULT(none) &
!$OMP& SHARED(mesh) &
!$OMP& PRIVATE(no_nod_elem,fiss_den)
do elem_no=1,mesh%no_active_elem
  no_nod_elem = 5
  allocate(fiss_den(no_nod_elem)) ! X
  fiss_den = 0.0_dp
  deallocate(fiss_den)
enddo
!$OMP END PARALLEL DO
fails with the message that fiss_den is already allocated (on line marked X).
Mesh is a complex data_type with the entry no_active_elem an integer. If I replace mesh%no_active_elem by some new integer variable that was set to the correct value, then it does work (at least running on single thread). So something fishy going on. Are there any restrictions I am not aware of?
Any ideas why this would happen? I have seen similar questions posted before, but I believe these issues were fixed in previous versions (I am using 17.0.4 on linux).
Thanks for any pointers you might have.
Danny.
Ferdinand_T_
New Contributor II
Hi Danny,
I encountered a lot of similar errors on using Fortran-2003 features (e.g. polymorphic types) with openMP in the past. In your code, the problem seems to be related to the "mesh" -type. Maybe it helps if you provided the declaration of that object?
I tested the following code and it worked fine (Ubuntu 14.0.4, ifort 17.0.4, openMP 3.0 11/2015, compiled with -qopenmp -fpp):
program p
	type :: mesh_type
		integer :: no_active_elem = 10
	end type
	type(mesh_type) :: mesh
	integer, parameter :: dp = kind(0d0)
	real(kind=dp), allocatable, dimension(:) :: fiss_den
	integer :: elem_no
	print *, _OPENMP
	!$OMP PARALLEL DO &
	  no_nod_elem = 5
	enddo
end program
Ferdinand
Danny_L_
Hello Ferdinand,
Yes indeed it seems to come from the mesh variable. I can use the workaround I mentioned by first copying into another integer variable but I'd rather have it working as is. Here is the mesh declaration for completeness.
  type fem_mesh
    integer :: dimen
    integer :: no_vertices
    integer :: no_elem
    integer :: old_no_active_elem
    logical, allocatable, dimension(:) :: list_of_elems_tobe_refined
    type(elem_id), allocatable, dimension(:) :: active_elem_list
    type(elem_id), allocatable, dimension(:) :: elem_list
    type(elem_id), allocatable, dimension(:) :: old_active_elem_list
    type(elem_list), pointer :: elem_list_head => null()
    type(elem_list), pointer :: elem_list_ptr => null()
    type(face_list), pointer :: face_list_head => null()
    type(face_list), pointer :: face_list_ptr => null()
    type(vertex_list), pointer :: vertex_list_head => null()
    type(vertex_list), pointer :: vertex_list_tail => null()
    type(vertex_list), pointer :: vertex_list_ptr => null()
  end type fem_mesh
I will see if I can reconstruct a self-contained example that actually uses mesh which is of type fem_mesh.
Cheers,
Danny.
TimP
Note that currently supported ifort linux releases are 17.0.5 and 18.0.  I'm trying to find my way around the updated ism schemes.
jimdempseyatthecove
Make the unallocated array FIRSTPRIVATE, not PRIVATE. First private copies in the current state of the private variable/array ... including an unallocated array descriptor.
Jim Dempsey
Danny_L_
Thank you all for your comments. They are much appreciated !
The FIRSTPRIVATE construct did it. Not sure if I find it all logical, but I will not forget this construct when I encounter this again.  Still am puzzled that the behaviour depends on the way the last index of the loop is written. Apparently internally, there is a slight difference how it is handled.
Thanks again,
Danny Lathouwers.
