29657 Discussions
Issue with the associate construct and a constructor
Jeremie_V_
Dear,
With ifort 2021.4.0 (and not with ifort 2017), I got a seg fault with the following code, when initializing a DT defined using the associate construct, and through a constructor:
```fortran
associate(parvar=>sparse%pardisovar)
 ...some code...
 parvar=pardiso_variable(maxfct=1,mnum=1,mtype=-2,solver=0,msglvl=1) !seg fault on this line
 !solution for ifort 2021.4
 ! sparse%pardisovar=pardiso_variable(maxfct=1,mnum=1,mtype=-2,solver=0,msglvl=1) !no problem with this line
 ...some code...
end associate
with `pardiso_variable` defined in another module as follows:
```fortran
type::pardiso_variable
!Default Pardiso variables
integer(kind=int32)::idum(1)
real(kind=wp)::ddum(1)
integer(kind=int32)::maxfct
integer(kind=int32)::mnum
integer(kind=int32)::mtype
integer(kind=int32)::msglvl
integer(kind=int32)::phase
integer(kind=int32)::solver
integer(kind=int32),allocatable::iparm(:)
type(MKL_PARDISO_HANDLE),allocatable::pt(:)
contains
final::reset_pardiso_variable
end type
interface pardiso_variable
module procedure constructor_pardiso_variable
end interface
contains
...some code...
Do I miss something? Or is it an issue with the compiler?
In advance thank you for your answer.
