Issues with Running ifort
Shibin_M_
HI,
After installation of Parallel Studio XE 2016 Update 1, I am getting some issues while running ifort. Please provide some pointers
This is the error message:
Error: A license for Comp-FL is not available (-76,61026,2).
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /home/shm82/intel/compilers_and_libraries_2016.1.150/linux/bin/intel64/../../Licenses
**  3.  /home/shm82/Licenses
**  4.  /opt/intel/licenses
**  5.  /Users/Shared/Library/Application Support/Intel/Licenses
**  6.  /home/shm82/intel/compilers_and_libraries_2016.1.150/linux/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
mecej4
Did you have an Intel compiler installation working before you installed the latest one? If so, you should have some license files in /opt/intel/licenses. If not, or you are doing an evaluation, you would have obtained a license file or a serial number during installation of PS 2016 U1.
Please note that there is a separate forum for handling license issues: https://software.intel.com/en-us/forums/intel-software-development-products-download-registration-licensing . You can use that forum to obtain support, or you can contact Intel Premier Support if you have a subscription.
Please do the following.
  • set or export (depending on your shell) the environment variable INTEL_LMD_DEBUG and give it a value of ~/lmd.log
  • Try another compile
  • Use "Send author a message" on my reply to send me a private message. Attach the lmd.log file from your home folder and the .lic file on your system (from any of the folders mentioned in the error message). You'll probably have to tar the two and attach the tar file.
