29393 Discussions
Issues with User-Defined Derived-Type I/O
han190
I asked a question on the Fortran Discourse and get suggestions that I should probably repost it here. Here is the link to the original post: https://fortran-lang.discourse.group/t/issues-with-user-defined-derived-type-i-o/6016/1
(The original post)
The question is pretty long so I would really appreciate it if you can read it through. Let’s say I have two modules module_a and module_b, each containing a derived type a_type and b_type. Also, I used the User-Defined Derived-Type I/O (UDDTIO) for each type, so there exists a write(formatted) for each module. The minimal code that generates error is shown below (io.f90),
module module_a
  implicit none
  public :: a_type
  public :: write(formatted)
  private
  type :: a_type
    integer :: value
  end type a_type
  interface write(formatted)
    module procedure :: write_formatted_a
  end interface write(formatted)
contains
  subroutine write_formatted_a(self, unit, iotype, v_list, iostat, iomsg)
    class(a_type), intent(in) :: self
    integer, intent(in) :: unit
    character(*), intent(in) :: iotype
    integer, intent(in) :: v_list (:)
    integer, intent(out) :: iostat
    character(*), intent(inout) :: iomsg
    if (iotype == 'DT') then
      write (unit, fmt="(i0)", iostat=iostat, iomsg=iomsg) self%value
    end if
  end subroutine write_formatted_a
end module module_a
module module_b
  implicit none
  public :: b_type
  private
  type :: b_type
    integer :: value
  end type b_type
    module procedure :: write_formatted_b
contains
  subroutine write_formatted_b(self, unit, iotype, v_list, iostat, iomsg)
    class(b_type), intent(in) :: self
    end if
  end subroutine write_formatted_b
end module module_b
program main
  use module_a
  use module_b
  implicit none
  type(a_type) :: a = a_type(1)
  type(b_type) :: b = b_type(2)
  print "(a, dt)", "A = ", a
  print "(a, dt)", "B = ", b
end program main
gfortran compiles and runs the code with no complains
> gfortran io.f90
> ./a.out
A = 1
B = 2
but intel compiler tells me
> ifx io.f90
io.f90: error #8638: The type/rank signature for arguments
of this specific subroutine is identical to another specific subroutine
that shares the same defined I/O.   [MODULE_A^WRITE_FORMATTED_A]
that shares the same defined I/O.   [MODULE_B^WRITE_FORMATTED_B]
compilation aborted for io.f90 (code 1)
Is this complain standard-compliant? write_formatted_a clearly has a different argument with write_formatted_b.
Labels (2)
Steve_Lionel
Your code is fine, and NAG Fortran also likes it. It baffles me that the Intel compiler is even comparing the two routines, given that they are UDIO procedures for distinct types.
han190
Thanks for the confirmation! Given my limited understanding of the compiler, it seems I will have to wait for the Intel developers to provide a bug fix.
Barbara_P_Intel
Thank you for reporting this with a small reproducer!
I filed a bug report, CMPLRLLVM-48883. We will let you know when it's fixed.
han190
Thank you, I am looking forward to a bug-fix release!
Barbara_P_Intel
That is correct. Updated compilers are released regularly. I don't know when this particular issue will be fixed and available. When I know, I'll post it.
Barbara_P_Intel
The incorrect error message that you reported is fixed in the Fortran compilers that were released last week. Please give them a try!
