LIB file visual studio question
Brian_Murphy
New Contributor II
For adding both C++ and fortran LIB's to a fortran project, what is the difference between:
Configuration Properties/Linker/Input/Additional Dependencies
and
Configuration Properties/Linker/Input/Add Module to Assembly
I have projects using the first, and other projects using the second, and looks like for the same thing.
Steve_Lionel
Steve_Lionel
The second option is for an entirely different thing - it isn't for LIBs. See https://docs.microsoft.com/en-us/cpp/build/reference/assemblymodule-add-a-msil-module-to-the-assembly?view=vs-2019
Brian_Murphy
New Contributor II
Thanks, Steve.  I don't know where the /ASSEMBLYMODULE stuff came from, but it's been in there for many years.  I have removed them in the project I'm working on right now.  The application builds ok without it, but now I'm having trouble with stack corruption probably brought on by other changes I've made.
