29640 Discussions
LINK - error with kernel32.lib after upgrading
Michael_Schaefer
after upgrading to 6.6b from 6.1 I get the following error:
LINK : fatal error LNK1181: "kernel32.lib" could not be open
I could solve this by adding a library path to
"C:ProgrammeMicrosoft Visual StudioDF98LIB,C:ProgrammeMicrosoft Visual StudioVC98LIB" ,
An enviroment variable LIB with "C:ProgrammeMicrosoft Visual StudioDF98LIB,C:ProgrammeMicrosoft Visual StudioVC98LIB" is already defined.
What could be the reason for this problem?
Kind Regards
Michael Schaefer
Jugoslav_Dujic
Valued Contributor II
When compiling from IDE, environment variable is not used, but the settings in Tools/Options/Directories.
Before you attempt to fix it manually, run "Per user setup" from CVF program group; it is supposed to fix it.
Jugoslav
Michael_Schaefer
Solve the problem.
Thank you very much, Jugoslav!
Michael
