29392 Discussions
LINK : fatal error LNK1104: cannot open file 'user32.lib'
Omun_Kwon
I am using VS 2010 with visual fortran compiler XE 12.0.2.154 on windows 7 64 bit system.
I have an error after sucessful compilation. "LINK : fatal error LNK1104: cannot open file 'user32.lib'"/
It is just a simple Quick Win application for a test.
Is there any suggestion?
Thx,
mecej4
Were you able to build similar programs on earlier occasions with the same compiler installation?
Do you have Visual C or a Windows SDK installed? Does the IDE know (usually through project settings) where to look for user32.lib?
In VS2010, select Tools > Options > Intel Visual Fortran > Compilers. Under Platform, select Win32 if you are building 32-bit apps or x64 for 64-bit apps. Click the Reset All button, then Ok. Does this solve the problem?
Omun_Kwon
Yes. I have installed V C and not sure Windows SDK. There is no problem on Visual C.
Thx
Omun_Kwon
I have followed the procedure, but it didn't work.
Do you have a folder C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\Lib (remove the "(x86)" if on a 32-bit system) with a user32.lib in it? This folder should also contain an x64 subfolder.
Go back into Tools > Options > Intel Visual Fortran > Compilers. Click on the ... button next to Libraries. Copy the contents and paste into a reply here. Now change Platform to x64 and do the same thing.
Omun_Kwon
Your suggestion works for me.
Thx,
Adding that path to the "Library files" list works? Make sure that if you are doing 64-bit development that you update the x64 list and use the x64 subfolder.
