29390 Discussions
LINK : fatal error LNK1181: cannot open input file
Robert_Walker
Because this service is linked to your current license, if the license is under another user there may need to be a changeover. If you have difficulty using Intel Premier Support, please submit your request to the Intel Software Network Forums:
http://software.intel.com/en-us/forums/
These are interactive, public forums monitored by Intel software experts. Intel support personnel have the ability to start private threads if you need to share information not for public view, like e-mail addresses or serial numbers for your software. Forum posts are responded to promptly.
I hope this information is helpful.
Gina H.
Intel Software Network Support
http://www.intel.com/software
email: ISN.support@intel.com
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
A representative of Intel may subsequently contact you (via email) in order to obtain your feedback on the quality of the support you received. If you do not wish to participate, simply delete the survey email.
<===== Received from bob.walker@manitowoc.com on 2009-10-05-16.40.45.000000 ======>
Subject : LINK : fatal error LNK1181: cannot open input file Email : bob.walker@manitowoc.com IP Address : 63.161.140.6 Message : My J:\bobw\fortran\P051New1\Debug\BuildLog.htm shows "\Fortran_toolbox\F90SQL\Bin\f90SQL.lib"
]. It appears that the pointer for f90SQL.lib is missing C:. Where or how is this default pointer set for f90SQL.lib?
Our programmer passed away so I'm in need a lot of help.
IMPORTANT NOTE IF YOU REPLY TO THIS EMAIL: Please perform a reply with history so that the following identifier "[THREAD_ID:47676578]" is seen in your response email. This will ensure that your reply is delivered to the proper support team at Intel and will reduce the time it takes to receive a response. Thank you.
Robert,
I gather that your question is about getting F90SQL.LIB? F90SQL is not part of the Intel Visual Fortran product. It was a product of Canaima Software, which is no longer in business. However, with their permission we have a copy of it that can be used with Intel Visual Fortran. You can find it here.
Robert_Walker
Robert,
No that is not my problem. I have F90SQL.lib and I set Project Property library to J:bobwfortranP051New1f90SQL.lib which the linker has no problem with. The problem is that the last entry in RSP1.rsp is "Fortran_toolboxF90SQLBinf90SQL.lib" which is not a valid location. I can not find what is causing that entry to be there. If it had C: as part of the entry I could just locate F90SQL.lib there. It appears to be a bad default lib location.
Robert, I don't see any new text from you in your reply. Be sure to type below the gray quote box, or uncheck the "Quote this reply" box.
Robert_Walker
Please attach the .vfproj file from your project to a reply here.
Robert_Walker
You have a version of F90SQL.LIB added as a "source file" in the project. This is the one that can't be found, In the Solution Explorer, look for the entry for F90SQL.LIB, select it and press the Delete key.
Robert_Walker
I did not know the .vfproj file was a text type file that could be edited. You asked for the right information that showed me what was causing the error. Our programmer had everything on his harddrive which I moved to a server after he passed away so the ..'s went to the wrong location for the lib file.
Thanks for your help
rjw
Well, yes, you CAN edit the .vfproj file but you shouldn't in most cases and I don't recommend it in general. You can remove the inappropriate entry in Visual Studio. In the Solution Explorer pane, under Source Files, you would have found a line for F90SQL.LIB that you could highlight and delete.
