29487 Discussions
LINK : fatal error LNK2023: bad DLL or entry point 'msobj80.dll'
Richard_Rivas
Ihave just installed Intel Fortran. Then I wrote a very simple program and tried to run it. However, when linking, the Studio Developer gave me the following error: LINK : fatal error LNK2023: bad DLL or entry point 'msobj80.dll'. That library is not inside of any of the installed folders. Please advise.
Richard
TimP
Did you check the previous voluminous postings on this subject? You must have seen them when you put your subject in the search box. The most common reason seemed to be use of VS2005 while neglecting to apply SP1. I suppose there may be limited time left to get the SP1 before VS2005 support lapses. If none of the reasons discussed previously are applicable, some specifics of your case will be needed.
Richard_Rivas
I have Microsoft Visual Studio 2008 Version 9 and Intel Visual Fortran Compiler 11.1
IDZ_A_Intel
Look on your disk for a copy of msobj80.dll that is NOT under a "amd64" folder. Copy it to C:\Program Files\Microsoft Visual Studio 9.0\Common\IDE
Richard_Rivas
I looked it up, but it is not in any folder of my disk. Where can I download it from? Why wasn't it copied automaticallyby the instalation program?
Richard
IDZ_A_Intel
It is automatically installed, but for some odd reason it doesn't always end up in the right place. I suggest doing a "repair" on Visual Studio (start in Add or Remove Programs, select Visual Studio, Change, Repair.) If that doesn't help let me know.
Richard_Rivas
I repaired the Visual Studio, but the problem still continues:
That library is not in any folder of my hard disk.
Please advise
