29651 Discussions
LNK2001 error with a simple function
Ibrahim_K_
Friends:
I build a small working prototype of a call from (Vuisual) C++ to Intel fortran. Then I tried to put in to my own project (which is very large). I am getting he symbol mismatch error:
"LNK2001 unresolved external symbol _SHOW
I inserted the following line in my .cpp file calling the function SHOW:
extern "C" float SHOW(int* in, float* out);
or
extern "C" {
and then I created a static fortran library (which build succesfully) containing:
    function SHOW(IN,OUT) BIND(C)
    use,intrinsic::ISO_C_BINDING
    IMPLICIT NONE
    REAL(C_FLOAT) :: SHOW
    INTEGER(C_INT) :: IN
    REAL(C_FLOAT) :: OUT
    WRITE(*,90) IN
90  FORMAT(/," from FORTRAN: in value = ",I4)
    OUT=199.0
    SHOW=1999.0;
    end function SHOW
then I pointed the linker to see my generated library in the correct directory. I checked the dependencies between CPP and Fortran. I am still getting the error. My VS 2017 settings must be OK as my prototype project builds.
Any ideas how I should go about isolating this problem.
I. Konuk
gib
New Contributor II
Fortran is case-insensitive, so the function name 'SHOW' appears as 'show'.  Change the C++ code to this:
#include <stdio.h>
extern "C" float show(int* in, float* out);
int main(void)
	int in = 123;
	float out;
	show(&in, &out);
	printf("out: %f\n",out);
	return(0);
I tested this simply by creating a .obj file from the Fortran code:
ifort -c show.f90
then linking this to main.cpp:
cl -c main.cpp show.obj
Your library should behave the same way.
gib
New Contributor II
#include <stdio.h>
int main(void)
	int in = 123;
	float out;
	show(&in, &out);
	return(0);
ifort -c show.f90
FortranFan
gib wrote:
Fortran is case-insensitive, so the function name 'SHOW' appears as 'show'.  Change the C++ code to this: ..
Or another option will be to use the Fortran standard-supported NAME parameter with BIND:
extern "C" {
function SHOW(IN,OUT) bind(C, name="SHOW")
Ibrahim_K_
Thank you very much my friend. That was it! I should have paid attention. Inspecting the .OBJ file shows what you indicated.
By the way, I like your second suggestion too to make sure that I do not fell into a similar trap again by explicitly declaring a case sensitive name.
Cheers.
I. Konuk
