Lahey Fortran TO Intel Fortran
Javier_C_3
I'm finishing my PhD in Geotechincal Engineering, in the Polytechnic University of Catalonia.
I've implemented Fortran Code within Plaxis environtment (User Soil Defined Model). To create the necessaries dynamic libraries .dll, I've been using Intel Fortran Compiler (32/64) and LF95.
Intel Fortran (32/64) compiles the principal part of the code, and Lahey compiles an additional part of the code that let me use Plaxis Interface introducing input parameters.
I've using next make orders (which I've adapted from the original ones) for compiling the code and create the .dll:
IFORT32 (ifcomp.bat)
echo !DEC$ ATTRIBUTES DLLExport, StdCall, reference :: User_Mod
ifort @comp_rel  UsrMod.f90 UsrAddDF.f90 usrlib.f90 okmsgivf.f90 /dll /exe:example_ivf
IFORT64 (ifcomp64.bat)
REM compile 64-bit DLL: make sure you're in a 64-bit development environment
copy impivf impexp
ifort /static  UsrMod.f90 usrlib.f90 okmsgivf.f90 /dll /exe:example_ivf64
LF95 (lfcomp.bat)
echo       DLL_Export User_Mod
lf95 -c usrlib.f90
lib /out:lfusrlib.lib usrlib.ob
lf95 -c -ml winapi okmsglah.f90
lf95 -win -dll  UsrMod.f90 Usr_Add.f90 okmsglah.obj -lib lfusrlib.lib -ml bd -out:example_lah.dll
I've been able to compile the code of the constitutive code that I've developed in PLAXIS, introduce the model parameters, calculate and analyze the results. But now, LF95 trial license has expired (>30 days), and Lahey doesn't offer me any Student Version at a reasonable price.
That's why I'd like to ask you how to change LF95 make orders to Intel Fortran. I've tried all it was in my hand, but I'm not an expert developer (can manage well numerical models, but get lost with compiler orders -except basic ones-).
Thank you very much.
mecej4
The requirements for the Fortran DLL are on page 174 of the Plaxis documentation http://www.plaxis.nl/files/files/2D-3-Material-Models.pdf .
You need to add the DEC$ directive given on the same page to your Fortran source code, and use the compiler command listed on the same page.
 Mentioning the Lahey compiler in this context is an unnecessary distraction.
Javier_C_3
Thak you for your answer.
The structure of the compiler orders that I've written in the previous message is the same as the one you could find in Plaxis USRMOD example in their web (they use both compilers):"example_ivf.dll" and "example_ivf64.dll" are created with Intel Compiler and "example_lah.dll" with Lahey Compiler. "example_ivf.dll" and "example_ivf64.dll" are correct.
I've tried many times to change the directives of lfcomp.bat (the one that creates "example_lah.dll") to Intel directives, but I failed (Plaxis didn't work). That's why I asked.
echo       DLL_Export User_Mod        ==>  echo !DEC$ ATTRIBUTES DLLExport, StdCall, reference :: User_Mod
lf95 -c usrlib.f90                                ==>   ¿?¿? (userlib.f90 have no DEC of DLL_Export directive)
lib /out:lfusrlib.lib usrlib.obj                 ==> ¿?¿?
lf95 -c -ml winapi okmsglah.f90           ==> ¿?¿?  (there is an equivalent code with DEC directives,
okmsgivf.f90)
lf95 -win -dll  UsrMod.f90 Usr_Add.f90 okmsglah.obj -lib lfusrlib.lib -ml bd -out:example_lah.dll   ==> If I write any of the following orders, it doesn'st work:
ifort /winapp UsrMod.f90  dfusrlib.lib /dll   (not work)
ifort /winapp UsrMod.f90  usrlib.lib /dll   (not work)
ifort /winapp UsrMod.f90  usrlib.90 /dll   (not work)
ifort /winapp UsrMod.f90 UsrAddDF.f90 usrlib.lib /dll   (not work)
ifort /winapp UsrMod.f90 UsrAddDF.f90 okmsgivf.f90 usrlib.lib /dll   (not work)
ifort /winapp UsrMod.f90 UsrAddDF.f90 okmsgivf.f90 usrlib.f90 /dll   (not work)
ifort /winapp UsrMod.f90 UsrAddDF.f90 usrlib.f90 /dll /exe:example_lah  (not work)
ifort @comp_rel UsrMod.f90 UsrAddDF.f90 usrlib.f90 /dll /exe:example_lah  (not work)
Comp_rel include: /real_size:64
/fpconstant
/optimize:4
/static
/assume:noaccuracy_sensitive
/assume:byterecl
/assume:buffered_io
/notraceback
/debug:none
/check:none
/heap-arrays:1
/fpp
/recursive
ifort @comp_rel UsrMod.f90 UTsrAddDF.f90 okmsgivf.f90 usrlib.lib /dll /exe:example_lah  (not work)
Etc...
Thank You
mecej4
I don't understand what the problem is.
Apparently, you have Intel Fortran and you are able to produce with it DLLs that Plaxis can use correctly? And, you used to have Lahey F95 and you were able to use it (until the trial license expired) to produce DLLs which also worked correctly with Plaxis? If so, what is holding you back from creating IFort-compatible versions of the sources that you used with LF95?
What do you mean by "not work" and "it doesn't work"? Failure to compile, failure to link, rejection of DLL by Plaxis? In any case, you should show us the details of the attempted commands and the error messages that you received.
Note that you have not shown any source code. Plaxis is a big commercial package and I am not going to be able to do anything that requires having Plaxis or Delphi. If you post the files UsrMod.f90, UTsrAddDF.f90, okmsgivf.f90 and usrlib.f90, we can help with building an IFort DLL with them.
Javier_C_3
The problem is that I don't know how to "translate" the make file (and some lines in the code) from LF95 to Intel.
I'm sure that it's possible to work only with Intel, but the files that Plaxis provides as an example of User Defined Soil Model (http://kb.plaxis.nl/models/plaxis-user-defined-soil-models) uses both compilers, and, as I'm not a professional developer, I've followed this structure.
Example Plaxis file uses:
- INTEL to create two .dll:  example_ivf.dll (compiled with IA-32) and example_ivf64.dll (compiled with IA-64)
- LF95: to create one .dll: example_lah.dll
I changed ".for" => ".f90", and adapted makefiles. With that, I implemented a very simple model, and after finishing compilation, I put this 3 files in Plaxis folder and all worked well.
In order to use LF95 or Intel Compiler, it's necessary to change one line of the code of  USRMOD.f90 (see below).
After that, I started the implementation of an elastoplastic model which already exist in Plaxis (hardening soil). I'm copying below the code of this one.
When I finish its validation (making comparations with Plaxis Hardening Soil Model), I will implement my model code (which tries to improve the elastic part of that one).
I don't have any problem to copy here the code, but it has more than 15.000 lines, so I'm going to copy the main files and some subroutines (if you need more information, please, tell me).
The code I'm attaching works perfectly once compiled with INTEL and LF95 (example_ivf.dll with IA-32, example_ivf64.dll with IA-64, and example_lah.dll with LF95).
It uses the libraries provided by Plaxis, and Plaxis structure for subrotuines. As well, it has some errors from a physical point of view which I've already correct but not implemented yet (in any case, they're not important for our propose here).
I compiled this code with next make files (which I executed from the respectives compiler consoles):
IFCOMP.BAT:
COMP_REL:
/real_size:64
/fpconstant
/optimize:4
/static
/assume:byterecl
/assume:buffered_io
/notraceback
/debug:none
/check:none
/heap-arrays:1
/fpp
/recursive
IFCOMP64.BAT:
copy impivf impexp
IMPIVF:
: User_Mod
LFCOMP.BAT:
lf95 -c usrlib.f90
CODE:
USRMOD.F90 (TO USE WITH INTEL OR LF95)
_____________________________________________________________________________________________________
      Subroutine User_Mod ( IDTask, iMod, IsUndr, &
                           iStep, iTer, iEl, Int, &
                           X, Y, Z, &
                           Time0, dTime, &
                           Props, Sig0, Swp0, StVar0, &
                           dEps, D, BulkW, &
                           Sig, Swp, StVar, ipl, &
                           nStat, NonSym, iStrsDep, iTimeDep,iTang, &
                           iPrjDir, iPrjLen, iAbort )
      Implicit Double Precision (A-H, O-Z)
      Dimension Props(*), Sig0(*), StVar0(*), dEps(*), D(6,6), &
                Sig(*), StVar(*), iPrjDir(*)
      Character*255 PrjDir, Dbg_Name
      Data iounit / 0 /
      Save iounit
      ! La siguiente linea debe utilizarse para la compilación del DLL
      !NEXT TWO LINES MUST BE ACTIVATE OR DESACTIVATE DEPENDING ON THE COMPILER USED:
      !DEC$ ATTRIBUTES DLLExport, StdCall, Reference :: User_Mod  ! activate with Intel IA-32/64
      !DLL_Export User_Mod                                        !activate with LF95
      ! Posibilidad de debugging
      If (iounit.Eq.0) Then
        PrjDir=' '
        Do i=1,iPrjLen
          PrjDir(i:i) = Char(iPrjDir(i))
        End Do
        Dbg_Name=PrjDir(:iPrjLen)//'udsmex'
        nErr=0
    1   Continue
          Open(Unit= 1, File= Dbg_Name, iostat=ios)
          If (ios.Eq.0) Close(Unit=1, Status='delete', iostat=ios)
          If (ios.Ne.0) Then
            ! in case of error try ...udsmex1 or udsmex2 or ..
            nErr=nErr+1
            dbg_name=PrjDir(:iPrjLen)//'udsmex'//char(48+nErr)
            If (nErr.Lt.10) Goto 1
          End If
        Open(Unit= 1, File=Dbg_Name, blocksize=4096)
        Write(1,*)'File 1 opened'
        iounit = 1
!        Call WriVec(-1,'Props',Props,14)
      End If
!      Call WriIvl(-1, 'iounit',iounit )
!      Call WriIvl(-1, 'IDTask',IDTask )
      Select Case (iMod)
        Case (1)
          Call MyModel1( IDTask, iMod, IsUndr, iStep, iTer, iEl, Int, &
                        X, Y, Z, Time0, dTime, &
                        dEps, D, BulkW, Sig, Swp, StVar, ipl, &
                        nStat, NonSym, iStrsDep, iTimeDep, iTang, &
                        iAbort )
!        Case (2)
!          Call MyModel3( IDTask, ....
        Case Default
          Write(1,*) 'invalid model number in UsrMod', iMod
          Write(1,*) 'IDTask: ',IDTask
          Stop 'invalid model number in UsrMod'
          iAbort=1
          Return
      End Select ! iMod
      If (IDTask .EQ. 5 .AND. iel+int .EQ. 2) Then
        Write(1,*)'nStat   : ',nStat
        Write(1,*)'NonSym  : ',NonSym
        Write(1,*)'StrsDep : ',iStrsDep
        Write(1,*)'TimeDep : ',iTimeDep
        Write(1,*)'Tangent : ',iTang
      End If
      If (IDTask .EQ. 3 .AND. iel+int .EQ. 2) Then
        Write(1,*)'IDTask: ', IDTask,'iStep: ', iStep, 'iTer :', iTer
        Call Flush(1)
      End If
!      Call WriIvl(-1, 'IDTask end',IDTask )
      Return
      End ! User_Mod
      include 'Matriz6.f90'
      include 'Matriz3.f90'
      include 'mymodel1.f90'
      include 'HS_plast.f90'
      include 'MC_plast.f90'
      include 'TRAC_plast.f90'
      include 'CAP_plast.f90'
      include 'HS_CAP_plast.f90'
      include 'MC_CAP_plast.f90'
      include 'HS_TRAC_plast.f90'
      include 'MC_TRAC_plast.f90'
USR_ADD.F90  (TO USE WITH LF95)
! Subroutines in this file:
! Exported:
!  Subroutine GetModelCount( nMod )
!  Subroutine GetModelName ( iMod , ModelName )
!  Subroutine GetParamCount( iMod , nParam )
!  Subroutine GetParamName ( iMod , iParam, ParamName )
!  Subroutine GetParamUnit ( iMod , iParam, Units )
!  Subroutine GetStateVarCount( iMod , nVar )
!  Subroutine GetStateVarName ( iMod , iVar, Name )
!  Subroutine GetStateVarUnit ( iMod , iVar, Unit )
! Local:
!  Subroutine GetParamAndUnit( iMod , iParam, ParamName, Units )
!  Subroutine GetStateVarNameAndUnit( iMod , iVar, Name, Unit )
      Subroutine GetModelCount(nMod)
      ! Return the maximum model number (iMod) in this DLL
      Integer (Kind=4) nMod
      Dll_Export GetModelCount
      nMod = 1 ! Maximum model number (iMod) in current DLL
      Return
      End ! GetModelCount
      Subroutine GetModelName( iMod , ModelName )
      ! Return the name of the different models
      Integer  iMod
      Character (Len= * ) ModelName
      Character (Len=255) tName
      DLL_Export GetModelName
      Select Case (iMod)
        Case (1)
          tName = 'HS'
        Case Default
          tName = 'not in DLL'
      End Select
      LT = Len_Trim(tName)
      ModelName= Char(lt) // tName(1:Lt)
      Return
      End ! GetModelName
      ! Return the number of parameters of the different models
      DLL_Export GetParamCount
      Select Case (iMod)
        Case ( 1 )
          nParam = 14
        Case Default
          nParam = 0
      End Select
      Return
      End ! GetParamCount
      Subroutine GetParamName( iMod , iParam, ParamName )
      ! Return the parameters name of the different models
      Character (Len=255) ParamName, Units
      DLL_Export GetParamName
      Call GetParamAndUnit(iMod,iParam,ParamName,Units)
      Return
      End
      Subroutine GetParamUnit( iMod , iParam, Units )
      ! Return the units of the different parameters of the different models
      DLL_Export GetParamUnit
      Return
      End
      ! Return the parameters name and units of the different models
      ! Units: use F for force unit
      !            L for length unit
      !            T for time unit
      Character (Len=255) ParamName, Units, tName
      Select Case (iMod)
        Case (1)
          ! ModName = 'EL'
          Select Case (iParam)
            Case (1)
              ParamName = 'G'          ; Units     = 'F/L^2#'
            Case (2)
              ParamName = 'nu'         ; Units     = '-'
            Case (3)
              ParamName = 'E50_ref'    ; Units     = 'F/L^2#'
            Case (4)
              ParamName = 'Eoed_ref'   ; Units     = 'F/L^2#'
            Case (5)
              ParamName = 'Eur_ref'    ; Units     = 'F/L^2#'
            Case (6)
              ParamName = 'm'          ; Units     = '-'
            Case (7)
              ParamName = 'c'          ; Units     = 'F/L^2#'
            Case (8)
              ParamName = 'phi'        ; Units     = 'deg'
            Case (9)
              ParamName = 'psi'        ; Units     = 'deg'
            Case (10)
              ParamName = 'nu_ur'      ; Units     = '-'
            Case (11)
              ParamName = 'p_ref'      ; Units     = 'F/L^2#'
            Case (12)
              ParamName = 'K0_nc'      ; Units     = '-'
            Case (13)
              ParamName = 'R_f'        ; Units     = '-'
            Case (14)
              ParamName = 'sitma_tracc'; Units     = 'F/L^2#'
            Case Default
              ParamName = '???'     ; Units     = '???'
          End Select
        Case Default
          ! model not in DLL
          ParamName = ' N/A '        ; Units     = ' N/A '
      End Select
      tName    = ParamName
      ParamName= Char(lt) // tName(1:Lt)
      tName = Units
      Units = Char(lt) // tName(1:Lt)
      Return
      End ! GetParamAndUnit
      ! Return the number of state variables of the different models
      Dll_export GetStateVarCount
      	Select Case (iMod)
        Case (1)
          nVar = 2
        Case Default
          nVar = 0
      End Select
      Return
      End
      Subroutine GetStateVarName( iMod , iVar, Name )
      ! Return the name of the different state variables
      ! of the different models
      Character (Len=255) Name, Unit
      Dll_export GetStateVarName
        Call GetStateVarNameAndUnit( iMod , iVar, Name, Unit )
      End
      Subroutine GetStateVarUnit( iMod , iVar, Unit )
      ! Return the units of the different state variables of the different models
      Dll_export GetStateVarUnit
      End
      ! Return the name and unit of the different state variables of the different models
      Character (Len=255) Name, Unit, tName
      	Select Case (iMod)
        Case (1)
          Select Case (iVar)
            Case (1)
              Name = 'gamma_p'         ; Unit = '-'
            Case (2)
              Name = 'p_p'             ; Unit = 'F/L^2#'
            Case Default
              Name='N/A'              ; Unit = '?'
          End Select
        Case Default
      End Select
      tName    = Name
      Name     = Char(lt) // tName(1:Lt)
      tName    = Unit
      Unit     = Char(lt) // tName(1:Lt)
      Return
      End
USRADDDF.F90  (TO USE WITH INTEL)
! Exported:
! Local:
!DEC$ ATTRIBUTES DLLExport, StdCall, reference ::  GetModelCount
      Return
      End ! GetModelCount
      Integer  iMod
!DEC$ ATTRIBUTES DLLExport, StdCall, reference ::  GetModelName
      Select Case (iMod)
        Case (1)
          tName = 'HS'
        Case Default
      End Select
      Return
      End ! GetModelName
!DEC$ ATTRIBUTES DLLExport, StdCall, reference ::  GetParamCount
      Select Case (iMod)
        Case ( 1 )
          nParam = 14
        Case Default
          nParam = 0
      End Select
      Return
      End ! GetParamCount
!DEC$ ATTRIBUTES DLLExport, StdCall, reference ::  GetParamName
      Return
      End
!DEC$ ATTRIBUTES DLLExport, StdCall, reference ::  GetParamUnit
      Return
      End
      !            L for length unit
      !            T for time unit
      Select Case (iMod)
        Case (1)
          ! ModName = 'HS'
            Case (1)
            Case (2)
            Case (3)
            Case (4)
            Case (5)
            Case (6)
            Case (7)
            Case (8)
            Case (9)
            Case (10)
            Case (11)
            Case (12)
            Case (13)
            Case (14)
            Case Default
          End Select
        Case Default
          ! model not in DLL
      End Select
      tName    = ParamName
      tName = Units
      Return
!DEC$ ATTRIBUTES dllexport, stdcall, reference :: GetStateVarCount
      	Select Case (iMod)
        Case (1)
          nVar = 2
        Case Default
          nVar = 0
      End Select
      Return
      End
      ! Return the name of the different state variables of the different models
!DEC$ ATTRIBUTES dllexport, stdcall, reference :: GetStateVarName
      End
!DEC$ ATTRIBUTES dllexport, stdcall, reference :: GetStateVarUnit
      End
      	Select Case (iMod)
        Case (1)
          Select Case (iVar)
            Case (1)
            Case (2)
            Case Default
          End Select
        Case Default
      End Select
      tName    = Name
      tName    = Unit
      Return
      End
OKMSGIVF.F90  (TO USE WITH INTEL)
      Subroutine OK_MessageBox(t)
      use dfwin
      use dfwinty
      integer (kind=Int_Ptr_Kind()) hWnd
      character*(*) t
      character(len=256) :: msg, title
!  Display a messagebox with an OK button
!  Note that all strings must be null terminated for C's sake
      msg    = Trim(t)  // char(0)
      title = 'UDSM_Example' // char(0)
      hWnd = 0
      iret = MessageBox( hWnd, &
                        msg, &
                        title, &
                        MB_OK )
      Return
      End
OKMSGLAH.F90  (TO USE WITH LF95)
      dll_import MessageBoxA
      integer :: MessageBoxA
      Integer is3DF
!  Some (not all) Message box flags. The C header file winuser.h
!  contains a complete list of flags. Winuser.h is not provided
!  in the LF95 distribution.
      integer, parameter :: MB_OK                   = 0
      integer            :: iret
      character(len=*)   :: t
      title = 'UDSM_example' // char(0)
      iret = MessageBoxA(val(0),&
                        val(pointer(msg)), &
                        val(pointer(title)), &
                        val(MB_OK))
      Return
      End
USRLIB.F90  (SUBROUTINES; LIBRARY)
Subroutine MZEROR(R,K)
!C
!C***********************************************************************
!C
!C     Function: To make a real array R with dimension K to zero
!C
!C
      Implicit Double Precision (A-H,O-Z)
      Dimension R(*)
      Do J=1,K
        R(J) = 0.0D0
      End Do
      Return
      End
      Subroutine MZEROI(I,K)
!C
!C
!C     Function: To make an integre array I with Dimension K to zero
!C
!C
      Dimension I(*)
      Do J=1,K
        I(J)=0
      End Do
      Return
      End
      Subroutine SETRVAL(R,K,V)
!C
!C
!C     Function: To fill a real array R with Dimension K with value V
!C
!C
      Dimension R(*)
      Do J=1,K
        R(J)=V
      End Do
      Return
      End
      Subroutine SETIVAL(I,K,IV)
!C
!C
!C     Function: To fill an integer array I with Dimension K with value IV
!C
!C
      Dimension I(*)
      Do J=1,K
        I(J)=IV
      End Do
      Return
      End
      Subroutine COPYIVEC(I1,I2,K)
!C
!C
!C     Function: To copy an integer array I1 with Dimension K to I2
!C
!C
      Dimension I1(*),I2(*)
      Do  J=1,K
        I2(J)=I1(J)
      End Do
      Return
      End
      Subroutine COPYRVEC(R1,R2,K)
!C
!C
!C     Function: To copy a Double array R1 with Dimension K to R2
!C
!C
      Dimension R1(*),R2(*)
      Do J=1,K
        R2(J)=R1(J)
      End Do
      Return
      End
      Logical Function IS0ARR(A,N)
!C
!C    Function :  To check whether a real array contains only zero values.
!C                When an array contains only zero's is might not need to be
!C                written to the XXX file.
!C                exit Function when first non-zero value occured or when
!C                all elements are checked and are zero.
!C
!C    Input:  A : array to be checked
!C            N : number of elements in array that should be checked
!C
!!C    Output : .TRUE.  when all elements are 0
!C             .FALSE. when at least one element is not zero
!C
!C    Called by :  Subroutine TOBXX
!C
!C
      Dimension A(*)
      Is0Arr=.False.
      Do I=1,N
        If ( A(I) .Ne. 0 ) Return
      End Do
      Is0Arr=.True.
      Return
      End
      Logical Function IS0IARR(IARR,N)
!C
!C    Function :  To check whether a integer array contains only zero values.
!C                Similar to IS0ARR
!C
!C    Input:  IARR : array to be checked
!C
!C
!C
!C
      Dimension IARR(*)
      Is0IArr=.False.
      Do I=1,N
        If ( IARR(I) .Ne. 0 ) Return
      End Do
      Is0IArr=.True.
      Return
      End
      Subroutine MulVec(V,F,K)
!C
!C     Function: To multiply a real vector V with dimension K by F
!!C
!C
      IMPLICIT DOUBLE PRECISION (A-H,O-Z)
      DIMENSION V(*)
      Do J=1,K
        V(J)=F*V(J)
      End Do
      Return
      End     ! Subroutine Mulvec
      Subroutine MatVec(xMat,IM,Vec,N,VecR)
!!C***********************************************************************
!C
!C     Calculate VecR = xMat*Vec
!!C
!C I   xMat  : (Square) Matrix (IM,*)
!C I   Vec   : Vector
!C I   N     : Number of rows/colums
!C O   VecR  : Resulting vector
!C
      Dimension xMat(IM,*),Vec(*),VecR(*)
      Do I=1,N
        X=0
        Do J=1,N
          X=X+xMat(I,J)*Vec(J)
        End Do
        VecR(I)=X
      End Do
      Return
      End    ! Subroutine MatVec
      Subroutine AddVec(Vec1,Vec2,R1,R2,N,VecR)
!C
!C     Calculate VecR() = R1*Vec1()+R2*Vec2()
!C
!C I   Vec1,
!C I   Vec2  : Vectors
!C I   R1,R2 : Multipliers
!C
      Dimension Vec1(*),Vec2(*),VecR(*)
      Do I=1,N
        X=R1*Vec1(I)+R2*Vec2(I)
        VecR(I)=X
      End Do
      Return
      End    ! Subroutine AddVec
!C
      Subroutine DInProd(A,B,N,RES)
!C
!C     Returns the Inproduct of two vectors
!C
!C I   A,B  : Two vectors
!C I   N    : Used length of vectors
      Dimension A(*),B(*)
      X = 0
      Do I=1,N
        X = X + A(I)*B(I)
      End Do
      RES = X
      Return
      End     ! Function DInProd
!C
      Subroutine MatMat(xMat1,Id1,xMat2,Id2,nR1,nC2,nC1,xMatR,IdR)
!!C
!C     Calculate xMatR = xMat1*xMat2
!C
!C I   xMat1 : Matrix (Id1,*)
!C I   xMat2 : Matrix (Id2,*)
!C I   nR1   : Number of rows in resulting matrix    (= No rows in xMat1)
!C I   nC2   : Number of columns in resulting matrix (= No cols in xMat2)
!C I   nC1   : Number of columns in matrix xMat1
!C             = Number  rows    in matrix xMat2
!C O   xMatR : Resulting matrix (IdR,*)
!C
      Dimension xMat1(Id1,*),xMat2(Id2,*),xMatR(IdR,*)
      Do I=1,nR1
        Do J=1,nC2
          X=0
          Do K=1,nC1
            X=X+xMat1(I,K)*xMat2(K,J)
          End Do
          xMatR(I,J)=X
        End Do
      End Do
      Return
      End     ! Subroutine MatMat
      Subroutine MatMatSq(n, xMat1, xMat2, xMatR)
!C
!C     Calculate xMatR = xMat1*xMat2 for square matrices, size n
!C
!C I   n     : Dimension of matrices
!C I   xMat1 : Matrix (n,*)
!C I   xMat2 : Matrix (n,*)
!C O   xMatR : Resulting matrix (n,*)
!C
      Dimension xMat1(n,*),xMat2(n,*),xMatR(n,*)
      Do I=1,n
        Do J=1,n
          X=0
          Do K=1,n
          End Do
          xMatR(I,J)=X
        End Do
      End Do
      Return
      End     ! Subroutine MatMatSq
      Subroutine WriVal ( io, C , V )
!C
!!C Write (Double) value to file unit io (when io>0)
!C
!C
      Character C*(*)
      If (io.Le.0) Return
      Write(io,*) C,V
    1 Format( A,3x, 1x,1p,e12.5)
      Return
      End
      Subroutine WriIVl ( io, C , I )
!C
!C Write (integer) value to file unit io (when io>0)
!C
      Character C*(*)
      If (io.Le.0) Return
      Write(io,*) C,I
    1 Format( A,3x, 1x,I6)
      Return
      End
      Subroutine WriIVc ( io, C , iV , n )
!C
!C Write (integer) vector to file unit io (when io>0)
!C
      Character C*(*)
      Dimension iV(*)
      If (io.Le.0) Return
      Write(io,*) C
      Write(io,1) (iv(i),i=1,n)
    1 Format( ( 2(3x,5i4) ) )
      Return
      End
      Subroutine WriVec ( io, C , V , n )
!C
!C Write (Double) vector to file unit io (when io>0)
!C 6 values per line
      Character C*(*)
      Dimension V(*)
      If (io.Le.0) Return
      If (Len_Trim(C).Le.6) Then
        Write(io,2) C,( V(i),i=1,n)
      Else
        Write(io,*) C
        Write(io,1) ( V(i),i=1,n)
      End If
    1 Format( ( 2(1x, 3(1x,1p,e10.3) ) ) )
    2 Format( A, ( T7, 2(1x, 3(1x,1p,e10.3) ) ) )
      Return
      End
      Subroutine WriVec5( io, C , V , n )
!C
!C 5 values per line
      Character C*(*)
      Dimension V(*)
      If (io.Le.0) Return
      Write(io,*) C
    1 Format( 5(1x,1p,e12.5) )
      Return
      End
      Subroutine WriMat ( io, C , V , nd, nr, nc )
!C
!C Write (Double) matrix to file unit io (when io>0)
      Character C*(*)
      Dimension V(nd,*)
      If (io.Le.0) Return
      Write(io,*) C
      Do j=1,nr
        Write(io,1) j,( V(j,i),i=1,nc)
      End Do
    1 Format(i4, (  T7,2(1x, 3(1x,1p,e10.3) ) ) )
      Return
      End
      Subroutine MatInvPiv(Aorig,B,N)
      Dimension Aorig(n,*), B(n,*),A(:,:)
      Allocatable :: A
      Allocate ( A(n,n) ) ! No error checking !!
      Call CopyRVec(AOrig, A, n*n )
      Call MZeroR(B,n*n)
      Do i=1,n
        B(i,i) = 1d0
      End Do
      Do I=1,n
        T=A(I,I)
        iPiv=i
        Do j=i+1,n
          If ( Abs(A(j,i)) .Gt. Abs(A(iPiv,i))  ) iPiv=j
        End Do
        If (iPiv.Ne.i) Then
          Do j=1,n
            x         = A( i  ,j)
            A( i  ,j) = A(iPiv,j)
            A(iPiv,j) = x
            x         = B( i  ,j)
            B( i  ,j) = B(iPiv,j)
            B(iPiv,j) = x
          End Do
          T=A(I,I)
        End If
        Do J=1,n
          A(I,J)=A(I,J)/T
          B(I,J)=B(I,J)/T
        End Do
        Do K=1,n
          If (K.Ne.I) Then
            T=A(K,I)
            Do J=1,n
              A(K,J)=A(K,J)-T*A(I,J)
              B(K,J)=B(K,J)-T*B(I,J)
            End Do
          End If
        End Do
      End Do
      DeAllocate ( A  )
      Return
      End ! MatinvPiv
      Subroutine PrnSig(IOpt,S,xN1,xN2,xN3,S1,S2,S3,P,Q)
      Dimension S(*),xN1(*),xN2(*),xN3(*)
      If (iOpt.Eq.1) Then
        Call Eig_3(0,S,xN1,xN2,xN3,S1,S2,S3,P,Q) ! with Eigenvectors
      Else
        Call Eig_3a(0,S,S1,S2,S3,P,Q) ! no Eigenvectors
      End If
      Return
      End
      Subroutine Eig_3(iOpt,St,xN1,xN2,xN3,S1,S2,S3,P,Q)
      Dimension St(6),A(3,3),V(3,3), &
               xN1(3),xN2(3),xN3(3)
      ! Get Eigenvalues/Eigenvectors for 3*3 matrix
      ! Wim Bomhof 15/11/'01
      ! PGB : adaption to Principal stress calculation
      ! Applied on principal stresses, directions
      ! Stress vector St(): XX, YY, ZZ, XY, YZ, ZX
      A(1,1) = St(1) ! xx
      A(1,2) = St(4) ! xy = yx
      A(1,3) = St(6) ! zx = xz
      A(2,1) = St(4) ! xy = yx
      A(2,2) = St(2) ! yy
      A(2,3) = St(5) ! zy = yz
      A(3,1) = St(6) ! zx = xz
      A(3,2) = St(5) ! zy = yz
      A(3,3) = St(3) ! zz
      ! Set V to unity matrix
      V(1,1) = 1
      V(2,1) = 0
      V(3,1) = 0
      V(1,2) = 0
      V(2,2) = 1
      V(3,2) = 0
      V(1,3) = 0
      V(2,3) = 0
      V(3,3) = 1
      abs_max_s=0.0
      Do i=1,3
        Do j=1,3
          if (abs(a(i,j)) .Gt. abs_max_s) abs_max_s=abs(a(i,j))
        End Do
      End Do
      Tol = 1d-20 * abs_max_s
      it = 0
      itmax = 50
      Do While ( it.Lt.itMax .And. &
                abs(a(1,2))+abs(a(2,3))+abs(a(1,3)) .Gt. Tol )
        it=it+1
        Do k=1,3
          If (k .Eq. 1) Then
            ip=1
            iq=2
          Else If (k .Eq.2) Then
            ip=2
            iq=3
          Else
            ip=1
            iq=3
          End If
          If (a(ip,iq) .Ne. 0.0) Then
            tau=(a(iq,iq)-a(ip,ip))/(2.0*a(ip,iq))
            If (tau .Ge.0.0) Then
              sign_tau=1.0
            Else
              sign_tau=-1.0
            End If
            t=sign_tau/(abs(tau)+sqrt(1.0+tau*tau))
            c=1.0/sqrt(1.0+t*t)
            s=t*c
            a1p=c*a(1,ip)-s*a(1,iq)
            a2p=c*a(2,ip)-s*a(2,iq)
            a3p=c*a(3,ip)-s*a(3,iq)
            a(1,iq)=s*a(1,ip)+c*a(1,iq)
            a(2,iq)=s*a(2,ip)+c*a(2,iq)
            a(3,iq)=s*a(3,ip)+c*a(3,iq)
            a(1,ip)=a1p
            a(2,ip)=a2p
            a(3,ip)=a3p
            v1p=c*v(1,ip)-s*v(1,iq)
            v2p=c*v(2,ip)-s*v(2,iq)
            v3p=c*v(3,ip)-s*v(3,iq)
            v(1,iq)=s*v(1,ip)+c*v(1,iq)
            v(2,iq)=s*v(2,ip)+c*v(2,iq)
            v(3,iq)=s*v(3,ip)+c*v(3,iq)
            v(1,ip)=v1p
            v(2,ip)=v2p
            v(3,ip)=v3p
            ap1=c*a(ip,1)-s*a(iq,1)
            ap2=c*a(ip,2)-s*a(iq,2)
            ap3=c*a(ip,3)-s*a(iq,3)
            a(iq,1)=s*a(ip,1)+c*a(iq,1)
            a(iq,2)=s*a(ip,2)+c*a(iq,2)
            a(iq,3)=s*a(ip,3)+c*a(iq,3)
            a(ip,1)=ap1
            a(ip,2)=ap2
            a(ip,3)=ap3
          End If ! a(ip,iq)<>0
        End Do ! k
      End Do ! While
      ! principal values on diagonal of a
      S1 = a(1,1)
      S2 = a(2,2)
      S3 = a(3,3)
      ! Derived invariants
      P = (S1+S2+S3)/3
      Q = Sqrt( ( (S1-S2)**2 + (S2-S3)**2 + (S3-S1)**2 ) / 2 )
      ! Sort eigenvalues S1 <= S2 <= S3
      is1 = 1
      is2 = 2
      is3 = 3
      if (s1.Gt.s2) Then
        t   = s2
        s2  = s1
        s1  = t
        it  = is2
        is2 = is1
        is1 = it
      End If
      if (s2.Gt.s3) Then
        t   = s3
        s3  = s2
        s2  = t
        it  = is3
        is3 = is2
        is2 = it
      End If
      if (s1.Gt.s2) Then
        t   = s2
        s2  = s1
        s1  = t
        it  = is2
        is2 = is1
        is1 = it
      End If
      Do i=1,3
        xN1(i) = v(i,is1) ! first  column
        xN2(i) = v(i,is2) ! second column
        xN3(i) = v(i,is3) ! third  column
      End Do
      Return
      End ! Eig_3
      Subroutine Eig_3a(iOpt,St,S1,S2,S3,P,Q) ! xN1,xN2,xN3,
      Dimension St(6),A(3,3)   !  V(3,3),xN1(3),xN2(3),xN3(3)
      ! Get Eigenvalues ( no Eigenvectors) for 3*3 matrix
      ! Stress vector XX, YY, ZZ, XY, YZ, ZX
      A(1,1) = St(1) ! xx
      A(2,2) = St(2) ! yy
      A(3,3) = St(3) ! zz
      abs_max_s=0.0
      Do i=1,3
        Do j=1,3
        End Do
      End Do
      If (iOpt.Eq.1) Tol = 1d-50*abs_max_s
      it=0
      itmax = 50
      Do While ( it.lt.itmax .And.&
        it=it+1
        Do k=1,3
          If (k .Eq. 1) Then
            ip=1
            iq=2
            ip=2
            iq=3
          Else
            ip=1
            iq=3
          End If
          If (a(ip,iq) .Ne. 0.0) Then         ! ongelijk nul ?
              sign_tau=1.0
            Else
              sign_tau=-1.0
            End If
            c=1.0/sqrt(1.0+t*t)
            s=t*c
            a(1,ip)=a1p
            a(2,ip)=a2p
            a(3,ip)=a3p
            a(ip,1)=ap1
            a(ip,2)=ap2
            a(ip,3)=ap3
        End Do ! k
      End Do ! While
      S1 = a(1,1)
      S2 = a(2,2)
      S3 = a(3,3)
      P = (S1+S2+S3)/3
      if (s1.Gt.s2) Then
        t   = s2
        s2  = s1
        s1  = t
      End If
      if (s2.Gt.s3) Then
        t   = s3
        s3  = s2
        s2  = t
      End If
      if (s1.Gt.s2) Then
        t   = s2
        s2  = s1
        s1  = t
      End If
      Return
      End ! Eig_3a
!C
      Logical Function LEqual(A,B,Eps)
!C
!C     Returns .TRUE.  when two real values are (almost) equal,
!C             .FALSE. otherwise
!!C
!C I   A,B  : Two real values to be compared
!C I   Eps  : Toleration (Magnitude ~= 1E-5)
      LEqual =.True.
      If (A .Eq. B) Return
      If (DAbs(A-B) .LT. 0.5D0*Eps*( DAbs(A) + DAbs(B) + Eps ) )Return
      LEqual =.False.
      Return
      End     ! function LEqual
!C
      Subroutine CrossProd(xN1,xN2,xN3)
!!C
!C     Returns cross product of xN1 and xN2
!C
!C I   xN1,xN2 : Two basic vectors
!C O   xN3     : Resulting vector
      Dimension xN1(*),xN2(*),xN3(*)
      xN3(1) = xN1(2)*xN2(3) - xN1(3)*xN2(2)
      xN3(2) = xN1(3)*xN2(1) - xN1(1)*xN2(3)
      xN3(3) = xN1(1)*xN2(2) - xN1(2)*xN2(1)
      Return
      End     ! Subroutine CrossProd
!C
      Double Precision Function ArcSin(X,ie)
!C
!C     Returns the Arc Sine of X
!C
!C I   X : Input value
!C
!C     Note : In stead of using default routine DASIN we use this one
!C            because ³X³ can be slightly beyond 1 and this will give
!C            a RTE using DASIN(X)
!C
      Ie=0
      S = (1-X*X)
!      If (S .Lt. -1E-10) Ie=1
!      If (S .Lt. -1E-10) Write(*,1) X,S
!      If (S .Lt. -1E-10) Write(2,1) X,S
    1 Format(' ArcSin(',1x,1p,e13.5e3,') , S =',1x,1p,e13.5e3)
      If (S.LT.0) S = 0
      S = DSQRT(S)
      ArcSin = DATan2(X,S)
      Return
      End     ! function ArcSin
!C
      Subroutine CarSig(S1,S2,S3,xN1,xN2,xN3,SNew)
!C
!C     Returns the Cartesian stresses using the principal stresses S1..S3
!C     and the principal directions
!C
!C I   S1..S3   : Principal stresses
!C I   xN1..xN3 : Principal directions (xNi for Si)
!C
      Dimension xN1(*),xN2(*),xN3(*),SNew(*)
      Dimension SM(3,3),T(3,3),TT(3,3),STT(3,3)
!C
!C**** Fill transformation (rotation) matrix
!C
      Do I=1,3
        T(I,1) = xN1(I)
        T(I,2) = xN2(I)
        T(I,3) = xN3(I)
        TT(1,I) = T(I,1)
        TT(2,I) = T(I,2)
        TT(3,I) = T(I,3)
      End Do
!      Call MatTranspose(T,3,TT,3,3,3)
      Call MZeroR(SM,9)
      SM(1,1) = S1
      SM(2,2) = S2
      SM(3,3) = S3
!C
!C**** SMnew = T*SM*TT
!C
      Call MatMat(SM ,3,  TT,3 , 3,3,3 ,STT,3)
      Call MatMat( T ,3, STT,3 , 3,3,3 ,SM ,3)
!     Call MatMatSq(3, SM,  TT, STT )   ! STT = SM*TT
!     Call MatMatSq(3,  T, STT, SM  )   ! SM  =  T*STT
!C
!C**** Extract cartesian stress vector from stress matrix
!C
      Do I=1,3
        SNew(I) = SM(I,I)
      End Do
      SNew(4) = SM(2,1)
      SNew(5) = SM(3,2)
      SNew(6) = SM(3,1)
      Return
      End     ! Subroutine CarSig
      subroutine setveclen(xn,n,xl)
      Dimension xN(*)
      x=0
      do i=1,n
        x=x+xn(i)**2
      end do
      if (x.Ne.0) Then
        f=xl/sqrt(x)
        do i=1,3
          xn(i)=xn(i)*f
        end do
      end if
      return
      end ! setveclen
!C End Of file
MYMODEL1.F90  (SUBROUTINE)
     Subroutine MyModel1 ( IDTask, iMod, IsUndr, &
                           X, Y, Z, &
                           Time0, dTime, &
                           dEps, D, BulkW, &
                           nStat, &
                           iAbort )
! Número de tarea IDTask 1 : Inicializar variables
!                        2 : Calcular tensiones
!                        3 : Calcular la matriz de rigidez
!                        4 : Número de variables de estado
!                        5 : Preguntar propiedades de la matriz
!                        6 : Calcular la matriz de rigidez elástica del material
! Argumentos:
!          I/O  Type
!  IDTask   I   I    : Ver arriba
!  iMod     I   I    : Número de modelo (1..10)
!  IsUndr   I   I    : =1 para no drenado, =0 en otro caso
!  iStep    I   I    : Número de paso global
!  iter     I   I    : Número de iteración global
!  iel      I   I    : Número de elemento global
!  Int      I   I    : Número de punto de integración global
!  X        I   R    : Posición X del punto de integración
!  Y        I   R    : Posición Y del punto de integración
!  Z        I   R    : Posición Z del punto de integración
!  Time0    I   R    : Tiempo al inicio del paso de cálculo
!  dTime    I   R    : Incremento de tiempo
!  Props    I   R()  : Lista con los parámetros del modelo
!  Sig0     I   R()  : Tensiones al inicio del paso de cálculo
!  Swp0     I   R    : Exceso d mme presión de poros al inicio del paso de cálculo
!  StVar0   I   R()  : Variable de estado al inicio del paso de cálculo
!  dEps     I   R()  : Incremento de deformación
!  D       I/O  R(,) : Matriz de rigidez del material
!  BulkW   I/O  R    : Módulo volumétrico del agua (sólo caso no drenado)
!  Sig      O   R()  : Tensión resultante
!  Swp      O   R    : Exceso de presión de agua resultante
!  StVar    O   R()  : Resulting values state variables
!  ipl      O   I    : Indicador plástico
!  nStat    O   I    : Número de variables de estado
!  NonSym   O   I    : Matriz D no simétrica
!  iStrsDep O   I    : =1 para matriz D dependiente de las tesniones
!  iTimeDep O   I    : =1 para matriz D dependiente del tiempo
!  iAbort   O   I    : =1 para detenr proceso de cálculo
                Sig(*), StVar(*)
!---  Variables locales
      !Prs_E        : Tensiones principales trial (compresión positiva)
      !Prs          : Tensiones principales al final del paso de cálculo (compresión positiva)
      !Si           : Tensiones principales trial (compresión negativa)
      !xN(i)        : Autocvectores de SigE (xx-yy-zz) = Prs_E (1-2-3)
      Dimension dSig(6), xN1(3), xN2(3), xN3(3), xN10(3), xN20(3), xN30(3), &
                Prs_E(3), Prs(3), Prs_0(3)
      pi        = 3.1415926535d0
      Rad       = pi/180d0
      io        = 0
      ttol      = 1d-9
      nStatV    = 2
      ideb      = 1 !para debugging
!Contenido de Props()
!                I/O  Type
! 1:   G          I    R     Módulo de corte
! 2:   nu         I    R     Coeficiente de Poisson
! 3:   E50_ref    I    R     Rigidez triaxial secante (superficie cono)
! 4:   Eoed_ref   I    R     Rigidez edométrica tangente (superficie cap)
! 5:   Eur_ref    I    R     Rigidez en descarga/recarga
! 6:   xm         I    R     Potencia de la dependencia tensional
! 7:   c          I    R     Cohesión (efectva)
! 8:   phi        I    R     Ángulo de fricción (efectiva)
! 9:   psi        I    R     Ángulo de dilatancia
! 10:  xnu_ur     I    R     Coeficiente de poisson en descarga/recarga
! 11:  p_ref      I    R     Presión de refencia para la rigidez
! 12:  xK0_nc     I    R     K0 (normalmente consolidado)
! 13:  R_f        I    R     Ratio de rotura
! 14:  Sigma_trac I    R     Máxima tensión de tracción (aplica sobre Prs, tracción +, compresión -)
! Prs_E           I    R(3) : Tensiones principales del predictor elástico S1 >= S2 >= S3
! Prs             O    R(3) : Tensiones principales resultantes
! ipl             O    I    : Indicador de punto plástico
!                             1 : Superfície límite de Coulomb (MC_plast)
!                             2 : Superficie de tracción (vertice)
!                             3 : Punto plástico en CAP (CAP_plast)
!                             4 : Punto plástico en HS_CAP (HS_CAP_plast)
!                             5 : Punto plástico en HS (HS_plast)
!Contenido de StVar0
!                I/O  Type
! 1:  gamma_p    I/O   R     Variable de endurecimiento HS
! 2:  p_p        I/O   R     Variable de endurecimiento CAP
      If (IDTask .EQ. 1) Then !Inicializo variables
        !Parámetros y variables de estado
        G          = Props(1)
        xNu        = Props(2)
        E50_ref    = Props(3)
        Eoed_ref   = Props(4)
        Eur_ref    = Props(5)
        xm         = Props(6)
        c          = Props(7)
        phi        = Props(8)*Rad
        psi        = Props(9)*Rad
        xNu_ur     = Props(10)
        p_ref      = Props(11)
        xK0_nc     = Props(12)
        R_f        = Props(13)
        sigma_trac = Props(14)
        If (iStep .EQ. 0) Then
        !Cálculo variables endurecimiento en primer passo de cálculo
        iOpt        = 0
        Call PrnSig(iOpt, Sig0, xN10, xN20, xN30, S10, S20, S30, P, Q)
        Prs_0(1)    = S10*(-1d0)
        Prs_0(2)    = S20*(-1d0)
        Prs_0(3)    = S30*(-1d0)
        !Superficie HS (StVar0(1))
        qf1         = max(c*cos(phi)/sin(phi)+Prs_0(3), max(c*cos(phi)/sin(phi)-sigma_trac, 0d0))
        qf2         = (2d0*sin(phi)/(1d0-sin(phi)))
        qf          = qf1*qf2
        qa          = qf/R_f
        E_fac1      = max(c*cos(phi)+Prs_0(3)*sin(phi), max(c*cos(phi)-sigma_trac*sin(phi), 0d0))
        E_fac2      = (c*cos(phi)+p_ref*sin(phi))
        E50         = E50_ref*(E_fac1/E_fac2)**xm
        Ei          = 2d0*E50/(2d0-R_f)
        Eur         = Eur_ref*(E_fac1/E_fac2)**xm
        If (abs(Prs_E(1)-Prs_E(3)) .LT. qf) Then
        f13_hs_fac1 = ((Prs_0(1)-Prs_0(3))/(qa-(Prs_0(1)-Prs_0(3))))
        f13_hs_fac2 = 2d0*(Prs_0(1)-Prs_0(3))/Eur
        gamma_p_0   = (2d0*qa/Ei)*f13_hs_fac1-f13_hs_fac2
        Else
        f13_hs_fac1 = qf/(qa-qf)
        f13_hs_fac2 = 2d0*qf/Eur
        End If
        !Superficie CAP (StVar0(2))
        xlam_ast    = p_ref/Eoed_ref
        xkap_ast    = 3d0*p_ref*(1-2*xNu_ur)/Eur_ref
        alfa1       = ((1d0-xK0_nc)**2d0)/((1d0+2d0*xK0_nc)**2d0)
        alfa21      = (1d0-xK0_nc)*(1d0-2d0*xNu_ur)*(xlam_ast/xkap_ast-1d0)
        alfa221     = (1d0+2d0*xK0_nc)*(1d0-2d0*xNu_ur)*(xlam_ast/xkap_ast)
        alfa222     = (1d0-xK0_nc)*(1d0+xNu_ur)
        alfa        = 3d0*(alfa1+(alfa21/(alfa221-alfa222)))**0.5d0
        delta       = (3d0+sin(phi))/(3d0-sin(phi))
        q_m_0       = Prs_0(1)+(delta-1d0)*Prs_0(2)-delta*Prs_0(3)
        p_0         = (Prs_0(1)+Prs_0(2)+Prs_0(3))/3d0
        p_p_0       = ((q_m_0**2d0)/(alfa**2d0)+p_0**2d0)**0.5d0
        !Cálculo variables en primer paso de cálculo
        StVar0(1)   = max(max(StVar0(1), gamma_p_0), 1d-10)
        StVar0(2)   = min(StVar0(2), min((-1d0)*p_p_0,(-1d0)*c*cos(phi)/sin(phi)))
        End If
        !Corrección valor xNu
        If (xNu .GT. 0.5d0-1d-6 .OR. xNu .LT. -1d-6) Then
          Call OK_MessageBox('Invalid value for "nu" (param 2)')
          iAbort    = 1
          Return
        End If
        If (xNu .LT. 0d0) Then
          xNu       = 0.0d0
          Props(2)  = xNu
        End If
        If (xNu .GT. 0.495d0) Then
          xNu       = 0.495d0
          Props(2)  = xNu
        End If
        Call CopyRVec(StVar0, StVar, nStatV) !Copio StVar0 en StVar
      End If  ! IDTask = 1
      If (IDTask .EQ. 2) Then !Cálculo de tensiones
      Write(1,*) 'IDTask:', IDTask, 'iEl:', iEl, 'Int:', Int, 'iStep:', iStep, 'iTer:', iTer
      Call WriIvl(ideb, 'IsUndr', IsUndr)
        G         = Props(1)
        xNu       = Props(2)
        E50_ref   = Props(3)
        Eoed_ref  = Props(4)
        Eur_ref   = Props(5)
        xm        = Props(6)
        c         = Props(7)
        phi       = Props(8)*Rad
        psi       = Props(9)*Rad
        xNu_ur    = Props(10)
        p_ref     = Props(11)
        xK0_nc    = Props(12)
        R_f       = Props(13)
        gamma_p_E = StVar0(1)
        p_p_E     = (-1d0)*StVar0(2)
        Call WriVal(ideb, 'gamma_p_E', gamma_p_E)
        Call WriVal(ideb, 'p_p_E', p_p_E)
        !Construcción matriz D6
        iOpt        = 0
        Call PrnSig(iOpt, Sig0, xN10, xN20, xN30, S10, S20, S30, P0, Q0)
        Call WriVec(ideb, 'Prs_0', Prs_0, 3)
        Call Matriz6(Props, Prs_0, D, IsUndr)
        Call WriMat(ideb, 'D6' , D , 6, 6, 6)
        !Paso de cálculo elástico
        Call MatVec(D, 6, dEps, 6, dSig)
        Call AddVec(Sig0, dSig, 1d0, 1d0, 6, Sig )
        Call WriVec(ideb,'dEps', dEps, 6)
        Call WriVec(ideb,'Sig0', Sig0,6)
        Call WriVec(ideb,'Sig', Sig,6)
        iOpt        = 1
        Call PrnSig(iOpt, Sig, xN1, xN2, xN3, S1, S2, S3, P, Q)
        !Sig       :  compresión negativa (S1<S2<S3)
        !Prs, Prs_E:  compresión positiva (S1>S2>S3)
        Prs_E(1)    = S1*(-1d0)
        Prs_E(2)    = S2*(-1d0)
        Prs_E(3)    = S3*(-1d0)
        p_E         = (Prs_E(1)+Prs_E(2)+Prs_E(3))/3d0
        Call WriVec(ideb, 'Prs_E', Prs_E, 3)
        !Cálculo superficies de fluencia f13_hs, f13_mc y f_cap en Prs_E
        !Cálculo f13_hs en Prs_E
        qf1         = max(c*cos(phi)/sin(phi)+Prs_E(3), max(c*cos(phi)/sin(phi)-sigma_trac, 0d0))
        qf_E        = qf1*qf2
        qa          = qf_E/R_f
        E_fac1      = max(c*cos(phi)+Prs_E(3)*sin(phi), max(c*cos(phi)-sigma_trac*sin(phi), 0d0))
        If (abs(Prs_E(1)-Prs_E(3)) .LT. qf_E) Then
        f13_hs_fac1 = ((Prs_E(1)-Prs_E(3))/(qa-(Prs_E(1)-Prs_E(3))))
        f13_hs_fac2 = 2d0*(Prs_E(1)-Prs_E(3))/Eur
        f13_hs      = (2d0*qa/Ei)*f13_hs_fac1-f13_hs_fac2-gamma_p_E
        Else
        f13_hs      = 1d0
        End If
        Call WriVal(ideb, 'Prs_E(1)-Prs_E(3)', Prs_E(1)-Prs_E(3))
        Call WriVal(ideb, 'qa', qa)
        Call WriVal(ideb, 'qa-(Prs_E(1)-Prs_E(3))', qa-(Prs_E(1)-Prs_E(3)))
        Call WriVal(ideb, 'f13_hs', f13_hs)
        !Cálculo f13_mc en PrS_E
        f13_mc_fac1 = (1d0/2d0)*(Prs_E(1)-Prs_E(3))
        f13_mc_fac2 = (1d0/2d0)*(Prs_E(1)+Prs_E(3))*sin(phi)
        f13_mc      = f13_mc_fac1-f13_mc_fac2-c*cos(phi)
        Call WriVal(ideb, 'f13_mc', f13_mc)
        !Cálculo f_cap en Prs_E
        q_m         = Prs_E(1)+(delta-1d0)*Prs_E(2)-delta*Prs_E(3)
        p           = (Prs_E(1)+Prs_E(2)+Prs_E(3))/3d0
        f_cap       = (q_m**2d0)/(alfa**2d0)+(p**2d0)-(p_p_E**2d0)
        f_cap_E     = f_cap
         Call WriVal(ideb, 'f_cap', f_cap)
 !       Call WriVal(ideb, 'xK0_nc', xK0_nc)
 !       Call WriVal(ideb, 'alfa', alfa)
 !       Call WriVal(ideb, 'xH', xH)
        !Cálculo f_trac en Prs_E
        f13_trac = sigma_trac-Prs_E(3)
        Call WriVal(ideb, 'f13_trac', f13_trac)
        !Cálculo tolerancias
        f13_hs_TOL    = ttol*abs(f13_hs)+ttol
        f13_mc_TOL    = ttol*abs(f13_mc)+ttol
        f_cap_TOL     = ttol*abs(f_cap)+ttol
        f13_trac_TOL  = ttol*abs(f13_trac)+ttol
        !Call WriVal(ideb, 'f13_hs_TOL', f13_hs_TOL)
        !Call WriVal(ideb, 'f13_mc_TOL', f13_mc_TOL)
        !Call WriVal(ideb, 'f_cap_TOL', f_cap_TOL)
        !Call WriVal(ideb, 'f13_trac_TOL', f13_trac_TOL)
        !Comprobación si el paso de scálculo es elástico
        If (f13_hs .LT. f13_hs_TOL .AND. &
            f13_mc .LT. f13_mc_TOL .AND. &
            f13_trac .LT. f13_trac_TOL .AND. &
            f_cap .LT. f_cap_TOL) Then
            write(1,*) "PASO DE CÁLCULO ELÁSTICO, DENTRO DE f13_hs, f13_mc, f_cap y f13_trac"
            Prs(1)     = Prs_E(1)
            Prs(2)     = Prs_E(2)
            Prs(3)     = Prs_E(3)
            ipl        = 0
            GOTO 800
        End If
        !Comprobación si Prs_E está fuera de f13_hs
        If (f13_hs .GE. f13_hs_TOL) Then
        write(1,*) "ESTOY FUERA DE f13_hs"
        !Cálculo Prs en superficies de HS y endurecimiento gamma_p (StVar)
          iArea=1 !Calculo en plano f13_hs
          Call HS_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
          !Comprobación cambios en el orden de las tensiones principales
          Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN HS', Prs, 3)
          If (Prs(2) .LT. Prs(3)) Then
          write(1,*) "ESTOY FUERA DE f13_hs, AREA=2"
          iArea = 2 !Tr. Compresion (estoy en eje S2=S3)
          End If
          If (Prs(1) .LT. Prs(2)) Then
          write(1,*) "ESTOY FUERA DE f13_hs, AREA=3"
          iArea = 3 !Tr. Extension (estoy en eje S1=S2)
          End If
          If (iArea .NE. 1) Then !Returning Map en eje
          Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN HS, AREA 2,3', Prs, 3)
          End If
        Else
        Prs(1)      = Prs_E(1)
        Prs(2)      = Prs_E(2)
        Prs(3)      = Prs_E(3)
        End If
          !Comprobación si nuevas tensiones Prs no superan MC
          f13_mc_fac1 = (1d0/2d0)*(Prs(1)-Prs(3))
          f13_mc_fac2 = (1d0/2d0)*(Prs(1)+Prs(3))*sin(phi)
            If (f13_mc .GE. f13_mc_TOL) Then
            !No sirve Prs anterior
            !Desendurecimiento HS adoptando StVar0 y se vuelve a aplicar a Prs_E de partida
            !Cálculo Prs en superficies MC (no tienen endurecimiento)
            iArea = 1
            write(1,*) "ESTOY FUERA DE f13_mc"
            Call MC_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
            Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN MC', Prs, 3)
            write(1,*) "ESTOY FUERA DE f13_mc, AREA=2"
            End If
            write(1,*) "ESTOY FUERA DE f13_mc, AREA=3"
            End If
            Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN MC, AREA 2,3', Prs, 3)
            End If
            End If
          !Comprobación si nuevas tensiones Prs no superan TRAC
            f13_trac = sigma_trac-Prs(3)
            If (f13_trac .GE. f13_trac_TOL) Then
            !Cálculo Prs en superficie TRAC (no tienen endurecimiento)
            iArea = 1
            write(1,*) "ESTOY FUERA DE f13_trac"
            Call TRAC_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
            Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN TRAC', Prs, 3)
            write(1,*) "ESTOY FUERA DE f13_trac, AREA=2"
            iArea = 2 !Tr. Compresion (eje S2=S3)
            End If
            write(1,*) "ESTOY FUERA DE f12, AREA=3"
            iArea = 3 !Tr. Extension (eje S1=S2)
            End If
            Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN TRAC, AREA 2,3', Prs, 3)
            End If
            !Comprobación si nuevas tensiones Prs no superan HS
            qf1         = max(c*cos(phi)/sin(phi)+Prs(3), max(c*cos(phi)/sin(phi)-sigma_trac, 0d0))
            qf          = qf1*qf2
            qa          = qf/R_f
            E_fac1      = max(c*cos(phi)+Prs(3)*sin(phi), max(c*cos(phi)-sigma_trac*sin(phi), 0d0))
            If (abs(Prs(1)-Prs(3)) .LT. qf) Then
            f13_hs_fac1 = ((Prs(1)-Prs(3))/(qa-(Prs(1)-Prs(3))))
            f13_hs_fac2 = 2d0*(Prs(1)-Prs(3))/Eur
            Else
            f13_hs      = 1d0
            End  If
              !Cálculo Prs en superficies HS y TRAC (no tienen endurecimiento)
              iArea = 1
              write(1,*) "ESTOY FUERA DE f13_hs y f13_trac"
              Call HS_TRAC_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
              Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN HS Y TRAC', Prs, 3)
              write(1,*) "ESTOY FUERA DE f13_hs y f13_trac, AREA=2"
              End If
              write(1,*) "ESTOY FUERA DE f13_hs y f13_trac, AREA=3"
              End If
              Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN HS Y TRAC, AREA 2,3', Prs, 3)
              End If
              End If
                !Cálculo Prs en superficies MC y TRAC (no tienen endurecimiento)
                iArea = 1
                write(1,*) "ESTOY FUERA DE f13_mc y f13_trac"
                Call MC_TRAC_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
                Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN MC y TRAC', Prs, 3)
                End If
                write(1,*) "ESTOY FUERA DE f13_mc y f13_trac, AREA=3"
                End If
                Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN MC y TRAC, AREA 2,3', Prs, 3)
                End If
                End If
           End If
           End If
          !Compruebo que las nuevas tensiones Prs (de HS o MC) no superan f_cap (alfa calculado antes)
          q_m         = Prs(1)+(delta-1d0)*Prs(2)-delta*Prs(3)
          p           = (Prs(1)+Prs(2)+Prs(3))/3d0
          f_cap       = (q_m**2d0)/(alfa**2d0)+p**2d0-p_p_E**2d0
          If (f_cap .GE. f_cap_TOL) Then
          !Calculo Prs en superficie CAP y endurezco p_p
            write(1,*) "ESTOY FUERA DE f_cap"
            If (f_cap_E .GT. f_cap_TOL) Then
            Call CAP_plast(Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
            End If
            !Compruebo que las nuevas tensiones Prs no superan f13_hs
            qf          = qf1*qf2
            qa          = qf/R_f
            Else
            f13_hs      = 1d0
            End If
              !Mixed Return HS-CAP
              !Desendurecimiento CAP adoptando StVar0 y se vuelve a aplicar a Prs_E de partida
              !Calculo Prs en superficie HS y CAP y endurecimiento gamma_p y p_p
              iArea = 1
              write(1,*) "ESTOY FUERA DE f13_hs y f_cap"
              Call HS_CAP_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
              Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN HS y CAP', Prs, 3)
              write(1,*) "ESTOY FUERA DE f13_hs y f_cap, AREA=2"
              End If
              write(1,*) "ESTOY FUERA DE f13_hs y f_cap, AREA=3"
              End If
              Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN HS y CAP, AREA 2,3', Prs, 3)
              End If
              End If
              !Compruebo que las nuevas tensiones Prs no superan MC
              !Returning Map mixto MC-CAP
              !Desendurecimiento HS y CAP adoptando StVar0 y se vuelve a aplicar a Prs_E de partida
              !Calculo Prs en superficies CAP y MC y endurecimiento gamma_p
              iArea = 1
              write(1,*) "ESTOY FUERA DE f13_mc y f_cap"
              Call MC_CAP_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
              Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN MC y CAP', Prs, 3)
              write(1,*) "ESTOY FUERA DE f13_mc y f_cap, AREA=2"
              End If
              write(1,*) "ESTOY FUERA DE f13_mc y f_cap, AREA=3"
              End If
              Call WriVec(ideb, 'Prs TRAS RETURNING MAP EN MC y CAP, AREA 2,3', Prs, 3)
              End If
              End If
            End If
          End If
        Else
        !Compruebo si Prs_E está fuera de f_cap (alfa calculado antes)
        q_m       = Prs_E(1)+(delta-1)*Prs_E(2)-delta*Prs_E(3)
            qf          = qf1*qf2
            qa          = qf/R_f
            Else
            f13_hs      = 1d0
            End If
              !Returning Map mixto HS-CAP
              iArea = 1
              End If
              End If
              End If
              End If
              End If
              iArea = 1
              End If
              End If
              End If
            End If
          End If
        End If
        !Cálculo f13_trac, f13_hs, f_cap y f13_mc con Prs_E
        qf_E        = qf1*qf2
        qa          = qf_E/R_f
        Else
        f13_hs      = 1d0
        End If
        If (f13_trac .GE. f13_trac_TOL .AND. &
            f13_hs .LT. f13_hs_TOL) Then
        !Calculo Prs en superficies TRAC
        iArea = 1
        End If
        End If
        End If
        End If
        If (p .LT. (-1d0)*sigma_trac) Then  !Si p<-sigma_trac quiere decir que se ha hecho
                                            !returning map en cono complementario
            Prs(1) = (-1d0)*sigma_trac
            Prs(2) = (-1d0)*sigma_trac
            Prs(3) = (-1d0)*sigma_trac
            ipl=2
        End If
800     Continue
        Write(1,*) "Las tensiones ppales al final de este paso de cálculo son Prs="
        Call WriVec(1, 'Prs', Prs, 3)
        Call WriVal(ideb, 'gamma_p_E', StVar0(1))
        Call WriVal(ideb, 'gamma_p', StVar(1))
        Call WriVal(ideb, 'p_p_E', (-1d0)*StVar0(2))
        Call WriVal(ideb, 'p_p', (-1d0)*StVar(2))
        !Se vuelve a las tensiones en coordenadas cartesianas
        !Prs: tracción negativa, compresión positiva
        S1 = (-1d0)*Prs(1)
        S2 = (-1d0)*Prs(2)
        S3 = (-1d0)*Prs(3)
        Call CarSig(S1, S2, S3, xN1, xN2, xN3, Sig)
        !Sig: tracción positiva, compresión negativa
 !       Write(1,*) "Las tensiones al final de este paso de cálculo son Sig"
 !       Call WriVec(ideb, 'Sig', Sig, 6)
        G           = Eur/(2d0*(1d0+xNu_ur))
        xNu_U       = 0.495d0
        Fac         = (1d0+xNu_U)/(1d0-2d0*xNu_U)-(1d0+xNu_ur)/(1d0-2d0*xNu_ur)
        If (IsUndr .EQ. 1) Then
        BulkW       = 2d0*G/3d0*Fac
        Else
        BulkW       = 0d0
        End If
        !Caso no drenado
          dEpsV     = dEps(1)+dEps(2)+dEps(3)
          dSwp      = BulkW*dEpsV
          Swp       = Swp0+dSwp
        Else
          Swp       = Swp0
        End If
      End If  ! IDTask = 2
      If (IDTask .EQ. 3 .OR. &
         IDTask .EQ. 6 ) Then ! Cálculo de la matriz D
        iOpt        = 1
        Call PrnSig(iOpt, Sig0, xN1, xN2, xN3, S10, S20, S30, P0, Q0)
        BulkW = 0
          ! BulkW = ...
          xNu_U   = 0.495d0
          Fac     = 2d0*G/3d0*Fac
          BulkW   = Fac
        End If
      End If  ! IDTask = 3, 6
      If (IDTask .EQ. 4) Then !Número de variables de estado
        nStat    = nStatV
      End If  ! IDTask = 4
      If (IDTask .Eq. 5) Then !Tipo de matriz
        NonSym   = 0  ! 1 para matrices D no simétricas
        iStrsDep = 1  ! 1 para matrices D que dependen de las tensiones
        iTang    = 0  ! 1 para matrices D tangentes
        iTimeDep = 0  ! 1 para matrices D que dependen del tiempo
      End If  ! IDTask = 5
      End ! MyModel1
HS_CAP.F90  (SUBROUTINE)
      Subroutine HS_CAP_plast(iArea, Props, Prs_E, Prs, StVar0, StVar, ipl, IsUndr)
! Rutina para el Returning Map en superficie HS
! Tensión de compresión positiva!
!        I/O  Tipo
! iArea   I    I  1 : Superficie f13_hs             Prs_E(1) > Prs_E(2) > Prs_E(3)
!                 2 : Eje entre f13_hs y f12_hs     Prs_E(1) > Prs_E(2) = Prs_E(3)
!                 3 : Eje entre f13_hs y f23_hs     Prs_E(1) = Prs_E(2) > Prs_E(3)
! Local:
!       f13_hs            : superficie HS para         Prs_E(1) > Prs_E(2) > Prs_E(3)
!       f12_hs            : superficie HS para         Prs_E(1) > Prs_E(2) = Prs_E(3)
!       f23_hs            : superficie HS para         Prs_E(1) = Prs_E(2) > Prs_E(3)
!       xLam13_hs         : multiplicador plástico f13_hs
!       xLam12_hs         : multiplicador plástico f12_hs
!       xLam23_hs         : multiplicador plástico f23_hs
!       xLam_cap          : multiplicador plástico f_cap
!       D                 : matriz elástica
!       df13_hsmdS(3)     : Primera derivada función de fluencia f13_hs/dS
!       df12_hsmdS(3)     : Primera derivada función de fluencia f12_hs/dS
!       df23_hsmdS(3)     : Primera derivada función de fluencia f23_hs/dS
!       df_capmdS(3)      : Primera derivada función de fluencia f_cap/dS
!       df13_hsmdq        : Primera derivada función de fluencia f13_hs/dq
!       df12_hsmdq        : Primera derivada función de fluencia f12_hs/dq
!       df23_hsmdq        : Primera derivada función de fluencia f23_hs/dq
!       df_capmdq         : Primera derivada función de fluencia f_cap/dq
!       dg13_hsmdS(3)     : Primera derivada potencial plástico g13_hs/dS
!       dg12_hsmdS(3)     : Primera derivada potencial plástico g12_hs/dS
!       dg23_hsmdS(3)     : Primera derivada potencial plástico g23_hs/dS
!       dg_capmdS(3)      : Primera derivada potencial plástico g_cap/dS
!       d2g13_hsmdS2(3,3) : Segunda derivada potencial plástico g13_hs/dS2
!       d2g12_hsmdS2(3,3) : Segunda derivada potencial plástico g12_hs/dS2
!       d2g23_hsmdS2(3,3) : Segunda derivada potencial plástico g23_hs/dS2
!       d2g_capmdS2(3,3)  : Segunda derivada potencial plástico g_cap/dS2
!       d2g13_hsmdSdq(3)  : Derivada dS y dq del potencial plástico g13_hs
!       d2g12_hsmdSdq(3)  : Derivada dS y dq del potencial plástico g12_hs
!       d2g23_hsmdSdq(3)  : Derivada dS y dq del potencial plástico g23_hs
!       d2g_capmdSdq(3)   : Derivada dS y dq del potencial plástico g_cap
!       D_dgij            : Producto de D por dgij_hs/dS
!       D_dgij_2          : Producto de D por d2gij_hs/dS2
!       HH_dfij           : Producto de D por dfij_hs/dS
!       thetaij           : Operación dgij_hs/dS+d2gij_hs/dS2*xLamij_hs*xh_hs
!       D_thetaij         : Productor de D por thetaij
!       HH                : Inversa de la matriz Unity+xLamij_hs*D_gij_2
      Dimension Prs_E(3), Prs(3), Prs_res1(3), Prs_res2(3), Prs_res3(3), Prs_0(3), xN10(3), xN20(3), xN30(3)
      Dimension Prs_2sup(3), Prs_3sup(3), r(3)
      Dimension Props(*)
      Dimension StVar0(*), StVar(*)
      Dimension df13_hsmdS(3), df12_hsmdS(3), df23_hsmdS(3), df_capmdS(3)
      Dimension dg13_hsmdS(3), dg12_hsmdS(3), dg23_hsmdS(3),  dg_capmdS(3)
      Dimension d2g13_hsmdS2(3,3), d2g12_hsmdS2(3,3), d2g23_hsmdS2(3,3), d2g_capmdS2(3,3)
      Dimension d2g13_hsmdSdq(3), d2g12_hsmdSdq(3), d2g23_hsmdSdq(3), d2g_capmdSdq(3)
      Dimension D_dg13(3), D_dg12(3), D_dg23(3), D_dgcap(3)
      Dimension D_dg13_2(3,3), D_dg12_2(3,3), D_dg23_2(3,3), D_dgcap_2(3,3)
      Dimension HH_df13(3), HH_df12(3), HH_df23(3), HH_dfcap(3)
      Dimension theta13(3), theta12(3), theta23(3), thetacap(3)
      Dimension D_theta13(3), D_theta12(3), D_theta23(3), D_thetacap(3)
      Dimension Unity(3,3), D(3,3), HH(3,3), HH_inv(3,3), xMat(3,3), xMat_inv(3,3), f_b(3), d_lam(3)
      Call MZeroR(Prs_res1, 3)
      Call MZeroR(Prs_res2, 3)
      Call MZeroR(Prs_res3, 3)
      Call MZeroR(Prs_2sup, 3)
      Call MZeroR(Prs_3sup, 3)
      Call MZeroR(df13_hsmdS, 3)
      Call MZeroR(dg13_hsmdS, 3)
      Call MZeroR(d2g13_hsmdS2, 9)
      Call MZeroR(d2g13_hsmdSdq, 3)
      Call MZeroR(df12_hsmdS, 3)
      Call MZeroR(dg12_hsmdS, 3)
      Call MZeroR(d2g12_hsmdS2, 9)
      Call MZeroR(d2g12_hsmdSdq, 3)
      Call MZeroR(df23_hsmdS, 3)
      Call MZeroR(dg23_hsmdS, 3)
      Call MZeroR(d2g23_hsmdS2, 9)
      Call MZeroR(d2g23_hsmdSdq, 3)
      Call MZeroR(df_capmdS, 3)
      Call MZeroR(dg_capmdS, 3)
      Call MZeroR(d2g_capmdS2, 9)
      Call MZeroR(d2g_capmdSdq, 3)
      Call MZeroR(D_dg13_2, 9)
      Call MZeroR(D_dg12_2, 9)
      Call MZeroR(D_dg23_2, 9)
      Call MZeroR(D_dgcap_2, 9)
      Call MZeroR(D_dg13, 3)
      Call MZeroR(D_dg12, 3)
      Call MZeroR(D_dg23, 3)
      Call MZeroR(D_dgcap, 3)
      Call MZeroR(HH_df13, 3)
      Call MZeroR(HH_df12, 3)
      Call MZeroR(HH_df23, 3)
      Call MZeroR(HH_dfcap, 3)
      Call MZeroR(theta13, 3)
      Call MZeroR(theta12, 3)
      Call MZeroR(theta23, 3)
      Call MZeroR(thetacap, 3)
      Call MZeroR(D_theta13, 3)
      Call MZeroR(D_theta12, 3)
      Call MZeroR(D_theta23, 3)
      Call MZeroR(D_thetacap, 3)
      Call MZeroR(HH, 3)
      Call MZeroR(HH_inv, 3)
      Call MZeroR(xMat, 9)
      Call MZeroR(xMat_inv, 9)
      Call MZeroR(f_b, 3)
      Call MZeroR(d_lam, 3)
      ipl       = 5
      it        = 0
      itmax     = 20
      ttol      = 1d-9
      pi        = 3.1415926535d0
      Rad       = pi/180d0
      ideb      = -1 !para debugging
      Call MZeroR(Unity, 9)
      Unity(1,1) = 1d0
      Unity(2,2) = 1d0
      Unity(3,3) = 1d0
      G         = Props(1)
      xNu       = Props(2)
      E50_ref   = Props(3)
      Eoed_ref  = Props(4)
      Eur_ref   = Props(5)
      xm        = Props(6)
      c         = Props(7)
      phi       = Props(8)*Rad
      psi       = Props(9)*Rad
      xNu_ur    = Props(10)
      p_ref     = Props(11)
      xK0_nc    = Props(12)
      R_f       = Props(13)
      sigma_trac= Props(14)
      xKs        = Eur_ref/((3d0*(1d0-2d0*xNu_ur)))
      xKsmKc     = (Eur_ref/Eoed_ref)*(xK0_nc/((1d0+2d0*xK0_nc)*(1d0-2d0*xNu_ur)))
      xH         = xKs/(xKsmKc-1d0)
      dxLam13_hs = 0d0
      dxLam12_hs = 0d0
      dxLam23_hs = 0d0
      dxLam_cap  = 0d0
      xLam13_hs = 0d0
      xLam12_hs = 0d0
      xLam23_hs = 0d0
      xLam_cap  = 0d0
      iOpt        = 0
      Call Matriz3(Props, Prs_0, D, IsUndr)
      Select Case (IArea)
      Case (1) ! 1 : Superficie f13_hs y f_cap (Sig1 > Sig2 > Sig3)
         !STARTING POINT
         !Cálculo valor de f13_hs y f_cap en Prs_E
         qf1         = max(c*cos(phi)/sin(phi)+Prs_E(3), max(c*cos(phi)/sin(phi)-sigma_trac, 0d0))!OJO, Prs(3) debe ser mayor que c*cos(phi)/sin(phi) para que E sean reales
         qf          = qf1*qf2
         qa          = qf/R_f
         E_fac1      = max(c*cos(phi)+Prs_E(3)*sin(phi), c*cos(phi))
         Call WriVal(ideb, 'qf', qf)
         !Cálculo tolerancia de f13_hs y f_cap
         !Calculo df13_hs/dS y df_cap/dS en Prs_E
         df13_hsmdS(1)    = ((2d0*(qa**2d0))/Ei)/((qa-(Prs_E(1)-Prs_E(3)))**2d0)-2d0/Eur
         df13_hsmdS(2)    = 0d0
         df13_hsmdS(3)    = -((2d0*(qa**2d0))/Ei)/((qa-(Prs_E(1)-Prs_E(3)))**2d0)+2d0/Eur
         df_capmdS(1)    = 2d0*(q_m/(alfa**2d0)+(1d0/3d0)*p)
         df_capmdS(2)    = 2d0*(q_m*(delta-1d0)/(alfa**2d0)+(1d0/3d0)*p)
         df_capmdS(3)    = 2d0*(-q_m*delta/(alfa**2d0)+(1d0/3d0)*p)
         Call WriVec(ideb, 'df13_hsmdS', df13_hsmdS, 3)
         Call WriVec(ideb, 'df_capmdS', df_capmdS, 3)
         !Cálculo df13_hs/dq en Prs_E (q1=gamma_p, q2=p_p)
         df13_hsmdq      = -1d0
         df_capmdq       = -2d0*p_p_E
         !Cálculo h en Prs_E (dq1=dgamma_p=dlam1*h1, dq2=dp_p=dlam2*h2)
         xh_hs           = 1d0
         xh_cap          = 2d0*xH*p*(max(Prs_E(3)+c*cos(phi)/sin(phi),c*cos(phi)/sin(phi))/(p_ref+c*cos(phi)/sin(phi)))**xm
         !Cálculo dg13_hs/dS y dg_cap/dS en Prs_E
         sin_phi_m        = (Prs_E(1)-Prs_E(3))/(Prs_E(1)+Prs_E(3)-2d0*c*cos(phi)/sin(phi))
         sin_phi_cv       = (sin(phi)-sin(psi))/(1d0-(sin(phi))*(sin(psi)))
           If (sin_phi_m .LT. (3d0/4d0)*sin(phi)) Then
                sin_psi_m = 0d0
           ElseIf (sin_phi_m .GE. (3d0/4d0)*sin(phi) .AND. psi .GT. 0d0) Then
                sin_psi_m = max((sin_phi_m-sin_phi_cv)/(1d0-sin_phi_m*sin_phi_cv),0d0)
           ElseIf (sin_phi_m .GE. (3d0/4d0)*sin(phi) .AND. psi .LE. 0d0) Then
                psi_m = psi
                sin_psi_m = sin(psi_m)
           ElseIf (phi .EQ. 0d0) Then
                sin_psi_m = 0d0
           End If
         dg13_hsmdS(1)   = (1d0/2d0)*(1d0-sin_psi_m)
         dg13_hsmdS(2)   = 0d0
         dg13_hsmdS(3)   = -(1d0/2d0)*(1d0+sin_psi_m)
         dg_capmdS(1)   = df_capmdS(1)
         dg_capmdS(2)   = df_capmdS(2)
         dg_capmdS(3)   = df_capmdS(3)
         Call WriVec(ideb, 'dg13_hsmdS', dg13_hsmdS, 3)
         Call WriVec(ideb, 'dg_capmdS', dg_capmdS, 3)
         !Cálculo d2g13_hs/dS2 y d2gcap/dS2 en Prs_E
         d2g_capmdS2(1,1) = 2d0*(1d0/(alfa**2d0)+1d0/9d0)
         d2g_capmdS2(1,2) = 2d0*((delta-1d0)/(alfa**2d0)+1d0/9d0)
         d2g_capmdS2(1,3) = -2d0*(delta/(alfa**2d0)-1d0/9d0)
         d2g_capmdS2(2,1) = d2g_capmdS2(1,2)
         d2g_capmdS2(2,2) = 2d0*(((delta-1d0)**2d0)/(alfa**2d0)+1d0/9d0)
         d2g_capmdS2(2,3) = -2d0*(((delta-1d0)*delta)/(alfa**2d0)-1d0/9d0)
         d2g_capmdS2(3,1) = d2g_capmdS2(1,3)
         d2g_capmdS2(3,2) = d2g_capmdS2(2,3)
         d2g_capmdS2(3,3) = 2d0*((delta**2d0)/(alfa**2d0)+1d0/9d0)
         !Cálculo d2g13_hs/dSdq en Prs_E
        !Cálculo de los multiplicadores plásticos
         Call MatMat(D, 3, dg13_hsmdS, 3, 3, 1, 3, D_dg13, 3)
         Call DInProd(df13_hsmdS, D_dg13, 3, df13_D_dg13)
         xOmega11 = df13_D_dg13-df13_hsmdq*xh_hs
         Call MatMat(D, 3, dg_capmdS, 3, 3, 1, 3, D_dgcap, 3)
         Call DInProd(df13_hsmdS, D_dgcap, 3, df13_D_dgcap)
         xOmega12 = df13_D_dgcap
         Call DInProd(df_capmdS, D_dg13,3, dfcap_D_dg13)
         xOmega21 = dfcap_D_dg13
         Call DInProd(df_capmdS, D_dgcap,3, dfcap_D_dgcap)
         xOmega22 = dfcap_D_dgcap-df_capmdq*xh_cap
!         Call WriVal(ideb, 'df13_D_dg13', df13_D_dg13)
!         Call WriVal(ideb, 'df13_hsmdq', df13_hsmdq)
!         Call WriVal(ideb, 'xh_hs', xh_hs)
!         Call WriVal(ideb, 'xOmega11 = df13_D_dg13-df13_hsmdq*xh_hs', df13_D_dg13-df13_hsmdq*xh_hs)
!         Call WriVal(ideb, 'xOmega12 = df13_D_dgcap', df13_D_dgcap)
!         Call WriVal(ideb, 'xOmega21 = dfcap_D_dg13p', dfcap_D_dg13)
!         Call WriVal(ideb, 'dfcap_D_dgcap', dfcap_D_dgcap)
!         Call WriVal(ideb, 'df_capmdq', df_capmdq)
!         Call WriVal(ideb, 'xh_cap', xh_cap)
!         Call WriVal(ideb, 'xOmega22 = dfcap_D_dgcap-df_capmdq*xh_cap ', dfcap_D_dgcap-df_capmdq*xh_cap)
         !Resuolución sistema y cálculo dxLam13_hs y dxLam_cap
         dxLam13_hs = (f13_hs*xOmega22-f_cap*xOmega12)/(xOmega11*xOmega22-xOmega12*xOmega21)
         dxLam_cap = (f_cap*xOmega11-f13_hs*xOmega21)/(xOmega11*xOmega22-xOmega12*xOmega21)
         xLam13_hs = dxLam13_hs
         xLam_cap = dxLam_cap
         Call WriVal(ideb, 'dxLam13_hs', dxLam13_hs)
         Call WriVal(ideb, 'dxLam_cap', dxLam_cap)
         Call WriVal(ideb, 'xLam13_hs', xLam13_hs)
         Call WriVal(ideb, 'xLam_cap', xLam_cap)
         !Actualizo variables
         Call AddVec(D_dg13, D_dgcap, -xLam13_hs, -xLam_cap, 3, Prs_2sup)
         Call AddVec(Prs_E, Prs_2sup, 1d0, 1d0, 3, Prs)
         gamma_p = gamma_p_E + xLam13_hs*xh_hs
         p_p = p_p_E + xLam_cap*xh_cap
         !Cálculo valor de f13_hs y f_cap con la nueva Prs
         qf1         = max(c*cos(phi)/sin(phi)+Prs(3), max(c*cos(phi)/sin(phi)-sigma_trac, 0d0))  !OJO, Prs(3) debe ser mayor que c*cos(phi)/sin(phi) para que E sean reales
         qf          = qf1*qf2
         qa          = qf/R_f
         E_fac1      = max(c*cos(phi)+Prs(3)*sin(phi), c*cos(phi))
         f_cap       = (q_m**2d0)/(alfa**2d0)+p**2d0-p_p**2d0
         !EULER BACKWARD
         Do while ((abs(f13_hs) .GT. f13_hs_TOL .OR. &
                   abs(f_cap) .GT. f_cap_TOL) .AND. &
                   it .LE. itmax)
             !Call Matriz3(Props, Prs, D, IsUndr)
             Call WriVal(ideb, 'Prs(1)-Prs(3)', Prs(1)-Prs(3))
             Call WriVal(ideb, 'qa-(Prs(1)-Prs(3))', qa-(Prs(1)-Prs(3)))
             df13_hsmdS(1)    = ((2d0*(qa**2d0))/Ei)*(1/((qa-(Prs(1)-Prs(3)))**2d0))-2d0/Eur
             df13_hsmdS(2)    = 0d0
             df13_hsmdS(3)    = -((2d0*(qa**2d0))/Ei)*(1/((qa-(Prs(1)-Prs(3)))**2d0))+2d0/Eur
             !Cálculo df13_hs/dq en Prs (q1=gamma_p, q2=p_p)
             df13_hsmdq      = -1d0
             !Cálculo h en Prs (dq=dlam1*h1 y dq2=dlam2*h2)
             xh_hs           = 1d0
             xh_cap          = 2d0*xH*p*(max(Prs(3)+c*cos(phi)/sin(phi), c*cos(phi)/sin(phi))/(p_ref+c*cos(phi)/sin(phi)))**xm
             sin_phi_m        = (Prs(1)-Prs(3))/(Prs(1)+Prs(3)-2d0*c*cos(phi)/sin(phi))
                 sin_psi_m = 0d0
                 psi_m = psi
                 sin_psi_m = 0d0
             End If
             dg13_hsmdS(2)   = 0d0
             !Cálculo d2g13_hs/dS2 y d2g_cap/dS2 en Prs
             !Cálculo del multiplicador plástico
             Call MatMat(D, 3, d2g13_hsmdS2, 3, 3, 3, 3, D_dg13_2, 3)
             Call MatMat(D, 3, d2g_capmdS2, 3, 3, 3, 3, D_dgcap_2, 3)
             HH_inv = Unity + xLam13_hs*D_dg13_2 + xLam_cap*D_dgcap_2
             Call MatInvPiv(HH_inv, HH, 3)
             Call AddVec(dg13_hsmdS, d2g13_hsmdSdq, 1d0, xLam13_hs*xh_hs, 3, theta13)
             Call AddVec(dg_capmdS, d2g_capmdSdq, 1d0, xLam_cap*xh_cap, 3, thetacap)
             Call MatMat(HH, 3, df13_hsmdS, 3, 3, 1, 3, HH_df13,3)
             Call MatMat(HH, 3, df_capmdS, 3, 3, 1, 3, HH_dfcap,3)
             Call MatMat(D, 3, theta13, 3, 3, 1, 3, D_theta13,3)
             Call MatMat(D, 3, thetacap, 3, 3, 1, 3, D_thetacap,3)
             Call DInProd(D_theta13, HH_df13, 3, D_theta13_HH_df13)
             Call DInProd(D_thetacap, HH_df13, 3, D_thetacap_HH_df13)
             Call DInProd(D_theta13, HH_dfcap, 3, D_theta13_HH_dfcap)
             Call DInProd(D_thetacap, HH_dfcap, 3, D_thetacap_HH_dfcap)
             xOmega11  = D_theta13_HH_df13-df13_hsmdq*xh_hs
             xOmega12  = D_thetacap_HH_df13
             xOmega21  = D_theta13_HH_dfcap
             xOmega22  = D_thetacap_HH_dfcap-df_capmdq*xh_cap
             !Call WriMat(1, 'HH', HH, 3, 3, 3)
             Call AddVec(D_dg13, D_dgcap, -xLam13_hs, -xLam_cap, 3, Prs_res1)
             Call AddVec(Prs_E, Prs_res1, 1d0, 1d0, 3, Prs_res2)
             Call AddVec(Prs, Prs_res2, 1d0, -1d0, 3, r)
             Call DInProd(HH_df13, r, 3, r_HH_df13)
             Call DInProd(HH_dfcap, r, 3, r_HH_dfcap)
             xOmegaf13 = f13_hs - r_HH_df13
             xOmegafcap = f_cap - r_HH_dfcap
             !Resolución sistema y cálculo dxLam13_hs y dxLam_cap
             dxLam13_hs = (xOmegaf13*xOmega22-xOmegafcap*xOmega12)/(xOmega11*xOmega22-xOmega12*xOmega21)
             dxLam_cap  = (xOmegafcap*xOmega11-xOmegaf13*xOmega21)/(xOmega11*xOmega22-xOmega12*xOmega21)
             xLam13_hs = xLam13_hs + dxLam13_hs
             xLam_cap  = xLam_cap + dxLam_cap
             !Actualización variables
             Call WriVal(ideb, 'gamma_p', gamma_p)
             Call WriVal(ideb, 'p_p', p_p)
             Call WriVal(ideb, 'Ei', Ei)
             Call WriVal(ideb, 'Eur', Eur)
             Call WriVal(ideb, '(qa-(Prs(1)-Prs(3)))**2d0', (qa-(Prs(1)-Prs(3)))**2d0)
             Call WriVec(ideb, 'Prs durante iteración', Prs, 3)
             !Cálculo valor de f13_hs en (k+1)
             qf1         = max(c*cos(phi)/sin(phi)+Prs(3), max(c*cos(phi)/sin(phi)-sigma_trac, 0d0))!OJO, Prs(3) debe ser mayor que c*cos(phi)/sin(phi) para que E sean reales
             qf          = qf1*qf2
             qa          = qf/R_f
            Call WriIvl(ideb, 'it', it)
             !Actualizo iteración
             it = it+1
         End do
         !Actualizo variables de estado
         StVar(1) = gamma_p
         StVar(2) = min((-1d0)*p_p, (-1d0)*p_p_E)
         If (xLam13_hs .GT. (-1d0)*ttol .AND. &
             xLam_cap .GT. (-1d0)*ttol .AND. &
             it .LE. itmax) Then
             write(1,*)'Return mapping Ok!'
         Else
             write(1,*)'Numerical problem'
         End If
      Case (2) !  2 : Eje entre f13_hs, f12_hs y f_cap (Prs(1) > Prs(2) = Prs(3))
         !STARTING POINT
         !Cálculo el valor de f13_hs, f12_hs y f_cap en Prs_E
         qf          = qf1*qf2
         qa          = qf/R_f
         f12_hs_fac1 = ((Prs_E(1)-Prs_E(2))/(qa-(Prs_E(1)-Prs_E(2))))
         f12_hs_fac2 = 2d0*(Prs_E(1)-Prs_E(2))/Eur
         f12_hs      = (2d0*qa/Ei)*f12_hs_fac1-f12_hs_fac2-gamma_p_E
         !Cálculo tolerancia f13_hs, f12_hs y f_cap en Prs_E
         f12_hs_TOL = ttol*abs(f12_hs)+ttol
         !Calculo df13_hs/dS, df12_hs/dS y df_cap/dS en Prs_E
         df13_hsmdS(2)    = 0d0
         df12_hsmdS(1)    = ((2d0*(qa**2d0))/Ei)/((qa-(Prs_E(1)-Prs_E(2)))**2d0)-2d0/Eur
         df12_hsmdS(2)    = -((2d0*(qa**2d0))/Ei)/((qa-(Prs_E(1)-Prs_E(2)))**2d0)+2d0/Eur
         df12_hsmdS(3)    = 0d0
         Call WriVec(ideb, 'df12_hsmdS', df12_hsmdS, 3)
         !Cálculo df13_hs/dq, df12_hs/dq y df_cap/dS en Prs_E (q1=gamma_p  -para f13_hs y f12_hs-, q2=p_p)
         df13_hsmdq      = -1d0
         df12_hsmdq      = -1d0
         Call WriVal(ideb, 'df12_hsmdq', df12_hsmdq)
         !Cálculo h en Prs_E (dq=dlam1*h1 -para f13_hs y f12_hs- y dq2=dlam2*h2)
         xh_hs           = 1d0
         xh_cap          = 2d0*xH*p*(max(Prs_E(3)+c*cos(phi)/sin(phi), c*cos(phi)/sin(phi))/(p_ref+c*cos(phi)/sin(phi)))**xm
         !Cálculo dg13_hs/dS, dg12_hs/dS y dg_cap/dS en Prs_E
                sin_psi_m = 0d0
                psi_m = psi
                sin_psi_m = 0d0
           End If
         dg13_hsmdS(2)   = 0d0
         dg12_hsmdS(1)   = (1d0/2d0)*(1d0-sin_psi_m)
         dg12_hsmdS(2)   = -(1d0/2d0)*(1d0+sin_psi_m)
         dg12_hsmdS(3)   = 0d0
         Call WriVec(ideb, 'dg12_hsmdS', dg12_hsmdS, 3)
         !Cálculo d2g13_hs/dS2, d2g12_hs/dS2 y d2g_cap/dS2 en Prs_E
         !Cálculo d2g13_hs/dSdq, d2g12_hs/dSdq y d2g_cap/dSdq en Prs_E
         Call DInProd(df13_hsmdS, D_dg13,3, df13_D_dg13)
         Call MatMat(D,3,dg12_hsmdS,3,3,1,3,D_dg12,3)
         Call DInProd(df13_hsmdS, D_dg12,3, df13_D_dg12)
         xOmega12 = df13_D_dg12
         Call MatMat(D,3,dg_capmdS,3,3,1,3,D_dgcap,3)
         Call DInProd(df13_hsmdS, D_dgcap,3, df13_D_dgcap)
         xOmega13 = df13_D_dgcap
         Call DInProd(df12_hsmdS, D_dg13,3, df12_D_dg13)
         xOmega21 = df12_D_dg13
         Call DInProd(df12_hsmdS, D_dg12,3, df12_D_dg12)
         xOmega22 = df12_D_dg12-df12_hsmdq*xh_hs
         Call DInProd(df12_hsmdS, D_dgcap,3, df12_D_dgcap)
         xOmega23 = df12_D_dgcap
         xOmega31 = dfcap_D_dg13
         Call DInProd(df_capmdS, D_dg12,3, dfcap_D_dg12)
         xOmega32 = dfcap_D_dg12
         xOmega33 = dfcap_D_dgcap-df_capmdq*xh_cap
         !Resolución sistema y calculo dxLam13_hs, dxLam12_hs y dxLam_cap
         xMat(1,1) = xOmega11
         xMat(1,2) = xOmega12
         xMat(1,3) = xOmega13
         xMat(2,1) = xOmega21
         xMat(2,2) = xOmega22
         xMat(2,3) = xOmega23
         xMat(3,1) = xOmega31
         xMat(3,2) = xOmega32
         xMat(3,3) = xOmega33
         f_b(1) = f13_hs
         f_b(2) = f12_hs
         f_b(3) = f_cap
         Call MatInvPiv(xMat, xMat_inv, 3)
         Call MatMat(xMat_inv, 3, f_b, 3, 3, 1, 3, d_lam, 3)
         dxLam13_hs = d_lam(1)
         dxLam12_hs = d_lam(2)
         dxLam_cap  = d_lam(3)
         xLam12_hs = dxLam12_hs
         Call WriVal(ideb, 'dxLam12_hs', dxLam12_hs)
         Call WriVal(ideb, 'xLam12_hs', xLam12_hs)
         Call AddVec(D_dg13, D_dg12, -xLam13_hs, -xLam12_hs, 3, Prs_2sup)
         Call AddVec(Prs_2sup, D_dgcap, 1d0, -xLam_cap, 3, Prs_3sup)
         Call AddVec(Prs_E, Prs_3sup, 1d0, 1d0, 3, Prs)
         !Cálculo valor de f13_hs, f12_hs y f_cap con la nueva Prs
         qf          = qf1*qf2
         qa          = qf/R_f
         E_fac1      = (c*cos(phi)+Prs(3)*sin(phi))
         E_fac2      = max(c*cos(phi)+p_ref*sin(phi), c*cos(phi))
         f12_hs_fac1 = ((Prs(1)-Prs(2))/(qa-(Prs(1)-Prs(2))))
         f12_hs_fac2 = 2d0*(Prs(1)-Prs(2))/Eur
         !EULER BACKWARD
                   abs(f12_hs) .GT. f12_hs_TOL .OR. &
                   it .LE. itmax)
             !Cálculo df13_hs/dS, df12_hs/dS y df_cap/dS en Prs
             df13_hsmdS(1)    = ((2d0*(qa**2d0))/Ei)/((qa-(Prs(1)-Prs(3)))**2d0)-2d0/Eur
             df13_hsmdS(2)    = 0d0
             df13_hsmdS(3)    = -((2d0*(qa**2d0))/Ei)/((qa-(Prs(1)-Prs(3)))**2d0)+2d0/Eur
             df12_hsmdS(1)    = ((2d0*(qa**2d0))/Ei)/((qa-(Prs(1)-Prs(2)))**2d0)-2d0/Eur
             df12_hsmdS(2)    = -((2d0*(qa**2d0))/Ei)/((qa-(Prs(1)-Prs(2)))**2d0)+2d0/Eur
             df12_hsmdS(3)    = 0d0
             !Cálculo df13_hs/dq, df12_hs/dq y df_cap/dq en Prs (q1=gamma_p  -para f13_hs y f12_hs-, q2=p_p)
             df13_hsmdq      = -1d0
             df12_hsmdq      = -1d0
             !Cálculo h en Prs (dq=dlam1*h1 -para f13_hs y f12_hs- y dq2=dlam2*h2)
             xh_hs            = 1d0
                 sin_psi_m = 0d0
                 psi_m = psi
                 sin_psi_m = 0d0
             End If
             dg13_hsmdS(2)   = 0d0
             dg12_hsmdS(3)   = 0d0
             Call MatMat(D, 3, d2g12_hsmdS2, 3, 3, 3, 3, D_dg12_2, 3)
             HH_inv = Unity + xLam13_hs*D_dg13_2 + xLam12_hs*D_dg12_2 + xLam_cap*D_dgcap_2
             Call AddVec(dg12_hsmdS, d2g12_hsmdSdq, 1d0, xLam12_hs*xh_hs, 3, theta12)
             Call MatMat(HH, 3, df12_hsmdS, 3, 3, 1, 3, HH_df12,3)
             Call MatMat(D, 3, theta12, 3, 3, 1, 3, D_theta12,3)
             Call DInProd(D_theta12, HH_df13, 3, D_theta12_HH_df13)
             Call DInProd(D_theta13, HH_df12, 3, D_theta13_HH_df12)
             Call DInProd(D_theta12, HH_df12, 3, D_theta12_HH_df12)
             Call DInProd(D_thetacap, HH_df12, 3, D_thetacap_HH_df12)
             Call DInProd(D_theta12, HH_dfcap, 3, D_theta12_HH_dfcap)
             xOmega12  = D_theta12_HH_df13
             xOmega13  = D_thetacap_HH_df13
             xOmega21  = D_theta13_HH_df12
             xOmega22  = D_theta12_HH_df12-df12_hsmdq*xh_hs
             xOmega23  = D_thetacap_HH_df12
             xOmega31  = D_theta13_HH_dfcap
             xOmega32  = D_theta12_HH_dfcap
             xOmega33  = D_thetacap_HH_dfcap-df_capmdq*xh_cap
             Call MatMat(D, 3, dg12_hsmdS, 3, 3, 1, 3, D_dg12, 3)
             Call AddVec(D_dg13, D_dg12, -xLam13_hs, -xLam12_hs, 3, Prs_res1)
             Call AddVec(Prs_res1, D_dgcap, 1d0, -xLam_cap, 3, Prs_res2)
             Call AddVec(Prs_E, Prs_res2, 1d0, 1d0, 3, Prs_res3)
             Call AddVec(Prs, Prs_res3, 1d0,-1d0, 3, r)
             Call DInProd(HH_df12, r, 3, r_HH_df12)
             xOmegaf12  = f12_hs - r_HH_df12
             !Resolución sistema y calculo dxLam13_hs y dxLam12_hs
             f_b(1) = xOmegaf13
             f_b(2) = xOmegaf12
             f_b(3) = xOmegafcap
             xLam12_hs = xLam12_hs + dxLam12_hs
             !Calculo el valor de f13_hs, f12_hs y f_cap en (k+1) en Prs
             qf          = qf1*qf2
             qa          = qf/R_f
             !Actualización iteración
             it = it+1
         End do
         !Actualización variables de estado
         StVar(1) = gamma_p
             xLam12_hs .GT. (-1d0)*ttol .AND. &
             it .LE. itmax) Then
         Else
         End If
      Case (3) ! 3 : Eje entre f13_hs y f23_hs (Prs(1) = Prs(2) > Prs(3))
         !STARTING POINT
         !Cálculo valor de f13_hs, f23_hs y f_cap en Prs_E
         qf          = qf1*qf2
         qa          = qf/R_f
         f23_hs_fac1 = ((Prs_E(2)-Prs_E(3))/(qa-(Prs_E(2)-Prs_E(3))))
         f23_hs_fac2 = 2d0*(Prs_E(2)-Prs_E(3))/Eur
         f23_hs      = (2d0*qa/Ei)*f23_hs_fac1-f23_hs_fac2-gamma_p_E
         !Cálculo tolerancia f13_hs, f23_hs y f_cap en Prs_E
         f23_hs_TOL = ttol*abs(f23_hs)+ttol
         !Cálculo df13_hs/dS, df23_hs/dS y df_cap/dS en Prs_E
         df13_hsmdS(2)    = 0d0
         df23_hsmdS(1)    = 0d0
         df23_hsmdS(2)    = ((2d0*(qa**2d0))/Ei)/((qa-(Prs_E(1)-Prs_E(3)))**2d0)-2d0/Eur
         df23_hsmdS(3)    = -((2d0*(qa**2d0))/Ei)/((qa-(Prs_E(1)-Prs_E(3)))**2d0)+2d0/Eur
         !Cálculo df13_hs/dq, df23_hs/dq y df_cap/dq en Prs_E (q1=gamma_p  -para f13_hs y f23_hs-, q2=p_p)
         df13_hsmdq      = -1d0
         df23_hsmdq      = -1d0
         !Cálculo h en Prs_E (dq=dlam1*h1 -para f13_hs y f23_hs- y dq2=dlam2*h2)
         xh_hs           = 1d0
         !Cálculo dg13_hs/dS, dg23_hs/dS y dg_cap/dS en Prs_E
                sin_psi_m = 0d0
                psi_m = psi
                sin_psi_m = 0d0
           End If
         dg13_hsmdS(2)   = 0d0
         dg23_hsmdS(1)   = 0d0
         dg23_hsmdS(2)   = (1d0/2d0)*(1d0-sin_psi_m)
         dg23_hsmdS(3)   = -(1d0/2d0)*(1d0+sin_psi_m)
         !Cálculo d2g13_hs/dS2, d2g23_hs/dS2 y d2g_cap/dS2 en Prs_E
         !Cálculo d2g13_hs/dSdq, d2g23_hs/dSdq y d2g_cap/dSdq en Prs_E
         Call MatMat(D,3,dg23_hsmdS,3,3,1,3,D_dg23,3)
         Call DInProd(df13_hsmdS, D_dg23,3, df13_D_dg23)
         xOmega12 = df13_D_dg23
         Call DInProd(df23_hsmdS, D_dg13,3, df23_D_dg13)
         xOmega21 = df23_D_dg13
         Call DInProd(df23_hsmdS, D_dg23,3, df23_D_dg23)
         xOmega22 = df23_D_dg23-df23_hsmdq*xh_hs
         Call DInProd(df23_hsmdS, D_dgcap,3, df23_D_dgcap)
         xOmega23 = df23_D_dgcap
         Call DInProd(df_capmdS, D_dg23,3, dfcap_D_dg23)
         xOmega32 = dfcap_D_dg23
         !Resolución sistema y cálculo dxLam13_hs, dxLam23_hs y dxLam_cap
         f_b(1) = f13_hs
         f_b(2) = f23_hs
         f_b(3) = f_cap
         dxLam23_hs = d_lam(2)
         xLam23_hs = dxLam23_hs
         Call AddVec(D_dg13, D_dg23, -xLam13_hs, -xLam23_hs, 3, Prs_2sup)
         !Cálculo valor de f13_hs, f23_hs y f_cap con la nueva Prs
         qf          = qf1*qf2
         qa          = qf/R_f
         f23_hs_fac1 = ((Prs(2)-Prs(3))/(qa-(Prs(2)-Prs(3))))
         f23_hs_fac2 = 2d0*(Prs(2)-Prs(3))/Eur
         !EULER BACKWARD
                   abs(f23_hs) .GT. f23_hs_TOL .OR. &
                   it .LE. itmax)
             df13_hsmdS(2)    = 0d0
             df23_hsmdS(1)    = 0d0
             df23_hsmdS(2)    = ((2d0*(qa**2d0))/Ei)/((qa-(Prs(1)-Prs(2)))**2d0)-2d0/Eur
             df23_hsmdS(3)    = -((2d0*(qa**2d0))/Ei)/((qa-(Prs(1)-Prs(3)))**2d0)+2d0/Eur
            !Cálculo df13_hs/dq, df23_hs/dq y df_cap/dq en Prs (q1=gamma_p  -para f13_hs y f23_hs-, q2=p_p)
             df13_hsmdq      = -1d0
             df23_hsmdq      = -1d0
            !Cálculo h en Prs (dq=dlam1*h1 -para f13_hs y f23_hs- y dq2=dlam2*h2)
             xh_hs            = 1d0
                 sin_psi_m = 0d0
                 psi_m = psi
                 sin_psi_m = 0d0
             End If
             dg13_hsmdS(2)   = 0d0
             dg23_hsmdS(1)   = 0d0
             Call MatMat(D, 3, d2g23_hsmdS2, 3, 3, 3, 3, D_dg23_2, 3)
             HH_inv = Unity + xLam13_hs*D_dg13_2 + xLam23_hs*D_dg23_2 + xLam_cap*D_dgcap_2
             Call AddVec(dg23_hsmdS, d2g23_hsmdSdq, 1d0, xLam23_hs*xh_hs, 3, theta23)
             Call MatMat(HH, 3, df23_hsmdS, 3, 3, 1, 3, HH_df23,3)
             Call MatMat(D, 3, theta23, 3, 3, 1, 3, D_theta23,3)
             Call DInProd(D_theta23, HH_df13, 3, D_theta23_HH_df13)
             Call DInProd(D_theta13, HH_df23, 3, D_theta13_HH_df23)
             Call DInProd(D_theta23, HH_df23, 3, D_theta23_HH_df23)
             Call DInProd(D_thetacap, HH_df23, 3, D_thetacap_HH_df23)
             Call DInProd(D_theta23, HH_dfcap, 3, D_theta23_HH_dfcap)
             xOmega12  = D_theta23_HH_df13
             xOmega21  = D_theta13_HH_df23
             xOmega22  = D_theta23_HH_df23-df23_hsmdq*xh_hs
             xOmega23  = D_thetacap_HH_df23
             xOmega32  = D_theta23_HH_dfcap
             Call MatMat(D, 3, dg13_hsmdS, 3, 3, 1, 3, D_dg13,3)
             Call MatMat(D, 3, dg23_hsmdS, 3, 3, 1, 3, D_dg23, 3)
             Call AddVec(D_dg13, D_dg23, -xLam13_hs, -xLam23_hs, 3, Prs_res1)
             Call AddVec(Prs, Prs_res3, 1d0, -1d0, 3, r)
             Call DInProd(HH_df23, r, 3, r_HH_df23)
             xOmegaf23  = f23_hs - r_HH_df23
             !Resolución sistema y cálculo dxLam13_hs y dxLam23_hs
             f_b(1) = xOmegaf13
             f_b(2) = xOmegaf23
             f_b(3) = xOmegafcap
             xLam23_hs = xLam23_hs + dxLam23_hs
             !Cálculo valor de f13_hs, f23_hs y f_cap en (k+1) en Prs
             qf          = qf1*qf2
             qa          = qf/R_f
             it = it+1
         End do
         StVar(1) = gamma_p
        Call WriVal(ideb, 'xLam23_hs', xLam23_hs)
             xLam23_hs .GT. (-1d0)*ttol .AND. &
             it .LE. itmax) Then
         Else
         End If
      Case Default
             write(1,*) ' incorrect iArea in HS_plast'
             Stop
      End Select
      End ! HS_CAP_plast
CAP_PLAST.F90 , HS_PLAST.F90, HS_TRAC_PLAST.F90, MATRIZ6.f90,  ETC... (OTHER SUBROUTINES)
ETC...
ETC...
ETC...
mecej4
OK, using the link that you gave in the second paragraph of #5, I downloaded the Zip file http://kb.plaxis.nl/sites/kb.plaxis.nl/files/kb-downloads/udsm_examples_2012.zip. I built the 32-bit DLL using Intel Fortran 16 (32-bit) after fixing a couple of errors in the batch and options files that were in the Zip:
  • In file ifcomp.bat, surround the replace > by ">", i.e., surround the > character with double quotes.
  • In file comp_rel, change /optimize:4 to /O2
What they have done is to have the batch file first put the compiler-specific directive/declarations for the DLL entry point user_mod into a one-line file (impexp)using the echo command in the batch file. This line is then included in the source file usrmod.for. You do not have this INCLUDE statement in your source file in #5. Without it, the exported name will not be correctly seen when Plaxis attempts to load the DLL.
Everything that I have seen about Plaxis today tells me that they expect users to use one compiler to build the DLL. All that they care about is that the DLL routine be callable by Delphi calling protocol. Therefore, you can use the batch file ifcomp.bat to build the DLL (assuming that your copy of Plaxis wants to call a 32-bit DLL), and ignore the other batch files.
Javier_C_3
As I'm using Plaxis in a 64 bit environtment, it's necessary to compile the corresponding 64-bit .dll file too (using ifcomp64.bat).
I've done what you pointed in the previous post, but Plaxis still not worrking (I mean Plaxis can't read all necessary information from the .dll's, because it doesn't let me to introduce model parameters in its input page).
In 64 bit dll compilation appeared next message:
">copy impivf impexp
System cannot find the file specified"
(however, this message has appeared always since I started compiling weeks ago)
Yes, I erased "include 'impexp'" statement, as you can see in my Usemod.f90 (copy in #5). What I do to compile using Intel is to activate the line:  !DEC$ ATTRIBUTES DLLExport, StdCall, Reference :: User_Mod  in Usermod.f90.
I think that until now, there were some necessary information for Plaxis missed in the dynamic libraries example_ivf.dll and example_ivf64.dll (due an error in compilation? maybe the error I pointed out before in 64bit dll compilation?).
And  maybe Plaxis found this information in the dynamic library example_lah.dll (compiled with LF95).
I guess this because once add example_lah.dll to Plaxis folder, it work well (I mean that let me introduce the model parameters; this is the only thing that change adding example_lah.dll, but i'ts primordial). T
hat's why I initially thoght that both compilers were necessary.
This supposed missed information in example_ivf.dll and example_ivf64.dll due to a possible error in compilation, might be related with user_add.f90 / useradddf.f90 , which are the responsible of parameter input in Plaxis. I've copy user_add.f90 and useradddf.f90 code (and others .f90) in my last post.
Now, I have the following orders in make files, but still not working:
IFCOMP.BAT
echo !DEC$ ATTRIBUTES DLLExport, StdCall, reference :: User_Mod">"impexp
ifort @comp_rel  UsrMod.f90 UsrAddDF.f90 usrlib.f90 okmsgivf.f90 /dll /exe:example_ivf
IMPEXP
: User_Mod
COMP_REL
/real_size:64
/fpconstant
/O2
/static
/assume:noaccuracy_sensitive
/assume:byterecl
/assume:buffered_io
/notraceback
/debug:none
/check:none
/heap-arrays:1
/fpp
/recursive
IFCOMP64.BAT
REM compile 64-bit DLL: make sure you're in a 64-bit development environment
copy impivf impexp
ifort /static  UsrMod.f90 usrlib.f90 okmsgivf.f90 /dll /exe:example_ivf64
And, as I said before, there must be some error/missed orders in the previous files (IFCOMP.BAT, IMPEXP, COMP_REL, IFCOMP64.BAT) that is contained in the next one:
LFCOMP.BAT
echo       DLL_Export User_Mod
lf95 -c usrlib.f90
lib /out:lfusrlib.lib usrlib.obj
lf95 -c -ml winapi okmsglah.f90
lf95 -win -dll  UsrMod.f90 Usr_Add.f90 okmsglah.obj -lib lfusrlib.lib -ml bd -out:example_lah.dll
Thank you so much for your support.
mecej4
Page 175 of http://www.plaxis.nl/files/files/2D-3-Material-Models.pdf says:
In order to compile as 64-bit, you need both a 32-bit compiled 'USRMOD.DLL' and a
64-bit compiled ' USRMOD64.DLL' file in the usdm folder under the PLAXIS program
directory. The last one only needs to contain the 'User_Mod' subroutine.
I take this to imply that you should produce two versions of your DLL, one 32-bit and the other 64-bit. For the example code provided in http://kb.plaxis.nl/sites/kb.plaxis.nl/files/kb-downloads/udsm_examples_2012.zip, all that I had to do was
Open a 32-bit IFort command window, create a new directory and extract the examples zip file and correct comp_rel  as in #6. Delete the extracted DLLs or put them into a different directory. Issue the commands
echo !DEC$ ATTRIBUTES DLLExport, StdCall, reference :: User_Mod > impexp
ifort @comp_rel  UsrMod.for UsrAddDF.for usrlib.for okmsgivf.for /dll /exe:example_ivf
Open a 64-bit IFort command window, change to the same working directory as in the previous step, and issue the commands
echo !DEC$ ATTRIBUTES DLLExport :: User_Mod > impexp
ifort @comp_rel  UsrMod.for usrlib.for okmsgivf.for /dll /exe:example_ivf64
Note that I did not use the troublesome batch files with their redirected echo commands, nor did I use the one-line file impivf that is in the Plaxis examples zip but you do not have (or have erased).
The two DLLs were produced. They are not the same as the DLLs in the Plaxis examples zip, probably because they used an older version of the compiler.
To avoid confusion, I suggest that you re-do what I have described in #8 in a separate directory into which you have extracted the Zip file from Plaxis. Once this works on your system, you can move to the directory with your own sources and repeat the procedure but with your sources instead.
Javier_C_3
I did what you post on #8 with Plaxis Zip (erasing the line with " include 'impexp' " in usrmod.for, changing optimize:4 to O2 in comp_rel, and issuing the comands you've written in #8 in my IA-32 and IA-64 command windows
Dll's are created, but Plaxis still not working, because it doesn't let me introduce model parameters once opened Plaxis Console and selected "Used-defined model" in Material Model type.
As it's explained in the manual (pp. 172-174), Plaxis uses the procedures in UsrAddDF.for to activate user-interface functions (this is need for model parameters input and its recognition). I think that something is going wrong related with this.
Each procedure has it's own directive (I guess all is correct ¿?):
I've tried also some variations of what you've told me to do:
- Activate the following line in UsrMod.for  !DEC$ ATTRIBUTES DLLExport, StdCall, Reference :: User_Mod . Try compilation.
- Activate the following line in UsrMod.for: include 'usr_add.for' ! give parameter names and units and erase UsrAddDF.for from issue commands. Try compilation.
But none of them fix the problem.
mecej4
Javier C. wrote:
I did what you post on #8 with Plaxis Zip (erasing the line with " include 'impexp' " in usrmod.for, changing optimize:4 to O2 in comp_rel, and issuing the comands you've written in #8 in my IA-32 and IA-64 command windows)
You should not do that. The include 'impexp' line is essential for making the Plaxis-DLL interface work. What gets included (just one line) has to be different for 32-bit and 64-bit, because the calling conventions are different.
If you prefer, you could make two copies of usrmod.for, say usrmod32.for and usrmod64.for, in which you replace the include 'impexp' line by
in usrmod32.for and by
in usrmod64.for. When you build the DLLs, use usrmod32.for for the 32-bit DLL, and usrmod64.for for the 64-bit DLL.
Beyond that, I cannot comment about the !DEC$ lines that you showed in #9 for the other routines because I do not have Plaxis and I do not know what its requirements are. The documentation seems to indicate that those routines are not needed in the 64-bit DLL, when it says "The last one (USRMOD64.DLL) only needs to contain the 'User_Mod' subroutine.".
Javier_C_3
Oh, ok, I'm Sorry.
Now I have two copies of UsrMod (UsrMod32.for and UsrMod64.for) with its corresponding lines (post #10) containing !DEC$ directives in substitution of include 'impexp' (I understand now which was the function of line include 'ìmpexp' UsrMod.for, thank you).
Then, I write issues commands:
ifort @comp_rel  UsrMod32.for UsrAddDF.for usrlib.for okmsgivf.for /dll /exe:example_ivf
for UsrMod32.for for 32-bit DLL and
ifort @comp_rel  UsrMod64.for usrlib.for okmsgivf.for /dll /exe:example_ivf64
for UsrMod64.for for 64-bit DLL
Then two .dll are created (example_ivf.dll and example_ivf64.dll). I have copy them in Plaxis Folder.
After that, I open Plaxis, but when I'm going to introduce Model Input Parameters, Plaxis doesn't shown anything.
If all was correct, in the table of Input Parameters of the Model (while executing Plaxis) it should appear the name of the .dll that contains this information, the name of the model, the name of the parameters, their units, etc. All this information is provided by UsrAddDF.for.
UsrAddDF.for contains the code and directives that let Plaxis "read" how many parameters have the model/s that we are defining, what are their names and units, etc. (I don't know much more about UsrAddDF.for; in my code, I just adapted UsrAddDF from the one in Plaxis ZIP).
How I said before, I solved this using LF95 (now I can't, since License has expired). To compile with LF95, I only changed nex line
in UsrMod by
 DLL_Export User_Mod
Then, after execute lfcomp.bat with LF95, the file example_lah.dll was created and once added together with the files example_ivf.dll and example_ivf64.dll (compiled with Intel) in Plaxis Folder, all works well (Plaxis could read parameters, etc.)
Maybe some clue is in lfcomp.bat (used in LF95 compilation).
Thank you for all your time and comments, and sorry for my ignorance in this issue.
Javier_C_3
I think I was wrong in one thing. What made Plaxis run until now when using the option of User Soil Defined Model was example_lah.dll compiled with LF95. I've tried to put and old version of this dll alone in Plaxis Folder (without example_ivf.dll and example_ivf64.dll), and it works well.
In any case, I'm sure that two dll compiled with Intel will finally works.
