Large do loop bounds
nameiii
I have a code with a simple do loop, DO I = J,K, with I,J,K all Integer(4).
For handling exceptional situations the limits sometimes get set to large values. In particular sometimes one has J = HUGE(J) and K = - HUGE(K). The intention is that the loop won't execute in this situation. However on CVF 6.6 it is executed at least once (it fails in the first iteration so I don't know if it would try to execute a second time). I guess the number of possible iterations is calculated as K-J+1 and, while this should be negative, it overflows to give a positive number. Using HUGE(J)/4, -HUGE(K)/4 works fine.
I realise CVF 6.6 is no longer supported (I have a copy of Intel 9.0 and am intending to change soon). However I am curious to know whether this is a compiler bug or is consistent with the Fortran standard (in which case I'll have to be much more careful in using HUGE in future). Thanks for any help.
It is consistent with the standard. The standard specifies how you determine the loop count , as you say,by computing the expression (end-start)+1. If this expression cannot be computed, then the results are undefined. It falls in the category of "complexity".
