Latest version?
davidspurr
I have been overseas 3 weeks. In that time I received 3 Premier Support notification emails (the last simply noting that the service was down at some point).
1. 4 Dec notification that w_fc_pc_8.1.025 had been released
2. 9 Dec notification that w_fce_pc_8.1.014. Build 20041123 had been released
I presume that it is the first that is most relevant to me, since I am currently developing only for IA32.
However, on returning home & following up the links provided, the only download visible to me is the second; ie. w_fce_pc_8.1.014. Build 20041123. In the past several generations of updates have been available for download.
I presume that this in NOT a replacement for w_fc_pc_8.1.025.
Assuming that to be the case I am puzzled that w_fc_pc_8.1.025 has disappeared if it is indeed the latest build for generating IA32 code.
Am I missing something? Should I still be able to download w_fc_pc_8.1.025?
Clarification would be appreciated
David
David,
Please look under File Downloads in the left column of Premier Support. 8.1.025 isn't appearing under "What's New" at this point. You are correct that w_fce_pc_8.1.014 is not relevant to you - that is the compiler for EM64T only.
davidspurr
Thanks - found.
BTW - did something happen with passwords. I did see these notifications while in Tokyo, but was unable to access Premier Support. Followed up when I got home yesterday & have been given a new temp pw that allowed me to access Premier Support.
Pity though - was staying in a hotel with a 100MBs connection (no cap) that I was looking forward to test. Back home to 256kBs now :-(
David
davidspurr
err - make those 100Mbs & 256kbs !!
David
