Libraries again - v9.1 vs 9.0
scitec
Hello, Group
I have been wrestling with a mysterious problem that only seems to appear in release mode, not while using the IDE/debugger.
I think that I now can see at least part of the problem. Although I am compiling with the IDE option set to verison 9.1, my DLLs are referencing the v9.0 run-time libraries. Since the installer is installing the v9.1 libraries, this seems to cause a conflict. In my environment path setting the v9.0 folders come first, so I suppose this is why I don't see the problem in development mode. Perhaps it is also why the v9.0 libraries get referenced when I build my DLLs.
I'm guessing that this may be another aspect of the problems of v9.1 not integrating with the VS-2003 IDE correctly. Is there an easy fix here that will ensure that my DLLs will reference the v9.1 libraries when I build? Is there some trick that will allow the path to be automatically modified when I change the Fortran version in the IDE options? (Is modifying the path sufficient, or are other changes required as well?)
Any guidanceor insights will be gratefully received.
Cheers,
Randy
The problem is, as you note, that the 9.0 DLLs are first in PATH. This will make them the ones Windows finds when your program runs. I suggest changing PATH to reference the 9.1 BIN folder. For compiling, if you do it in VS or use the "Build Environment" shortcut to start a command session, you'll get the right files.
What problem are you having with the IDE integration?
