29651 Discussions
Library Path Warning for Intel Fortran MAC OS
Scott_F_1
While linking a Fortran application, I received a library warning that refers to a missing path:
/Developer/SDKs/MacOSX10.4u.sdk/usr/lib/gcc/darwin/default
Is this a search path added by the Intel Fortran installation?
Thank you
Scott Frasier
TimP
Intel 9.x compilers add paths found by 'gcc -print-search-dirs' to the search path, as they depend on libraries provided by your gcc installation. Did you check to see if this reference is produced by that command?
