License error
Citlalli
Hi everyone, I got this error when trying to compile with ifort
ifort: error #10052: could not checkout FLEXlm license
I have read that the newest version of Intel fortran compiler, does not need any license so I have installed Intel OneAPI, then I tried to compile my code and I got the same error.  What do i need to do?.
Thank you in advance
DavidWhite
Valued Contributor II
Are you definitely using the new compiler?  You didn't indicate whether you are using Windows or Linux.  For example in Visual Studio, there can be multiple versions of the compiler integrated with VS.  You might still be trying to use the old version.
To make sure, you may want to uninstall the old version and reinstall/repair the OneAPI version.
DavidWhite
Citlalli
I'm using Linux, I will uninstall the old version as you suggest and reinstall the OneAPI version.
Thank you so much for your reply.
