I installed OneAPI on VS2022 and all was OK. Suddenly I got the 1104 error: mkl_intel_c_lib
can not be found. I use /Qmkl:static in the mpifort bat file. I tried to find the lib under intel/oneAPI/mkl/..., but I did not find it there.
What to do?
Best regards
Anders S
I have erronously used the IA32 command line! When I correctly choose the Intel64 command line the error disappeared!
Best regards
Anders S
MKL is in the oneAPI Base Toolkit. If you didn't install that, go do so, or you can install MKL separately.
Hi Steve,
Thanks for a quick response!
I reinstalled MKL, but still I can't see the missing library (see attachment). Am I looking at the wrong place?
Best regards
Anders S
The library that you seek is part of the 32-bit MKL package. If you want that, you can download and install the 32-bit OneMKL package . Select "Windows" and "Online" and then look for the link titled "Intel oneAPI Base Toolkit for Windows (32 bit).
Hi Steve,
Rapid reply again, thanks!
Now everything is clear! You can't dismiss 32-bits even when you run 64-bits, can you?
Best regards
Anders S
Best regards
Anders S
