Link failure
michaelgreen1
Hi All,
I have reorganized a fairly large solution (47 projects, currently 32 bits - though that will change). On rebuilding with IFORT compiler I have no problems until the linker kicks in, then I get hundreds of repeating errors, most of them like this:
libifcoremt.lib(for_need_lf.obj) : error LNK2001: unresolved external symbol __alloca_probe
AnaTrack.obj : error LNK2001: unresolved external symbol __alloca_probe
libifcoremt.lib(for_f90str.obj) : error LNK2001: unresolved external symbol _memmove
AnaPlot.obj : error LNK2001: unresolved external symbol _memmove
That's just a few examples chosen at random. I have not changed any settings in the linker properties dialog.
Any comments or insights most gratefully received.
Many thanks
Mike
andrew_4619
Probably a problem with library paths in VS configuration for Ifort. For a start show the link command that is being used.
