/libpath specifies only additional library directories. You still have to specify the name of the library on Linker/Input/Additional dependencies (/link option of ifort).
Alternatively, you can spell out full path to your library in /link; in this case, you don't need /libpath.
Hope this helps,
Jugoslav
Pozdrav (i hvala) Jugoslave,
It works like Jugoslav suggested it, in both variants (i.e. with /libpath and /link), and in both CVF and VS2003.
I specify libraries in CVF under the Object/Library Modules option, with an added benefit of the wildcard specification. The latter, however, doesn't work in VS.
Thanks for help!
Dear all,
I am new to the Intel Fortran 9 compiler and to VS2003, so maybe I'm a bit clumsy, but... I still don't see how to find a static library when linking. What must I specify in VS2003, and where? If the only way is via the command line, where do I find access to this line?
Yours sincerely,
Niels H. Veldhuijzen
Cito, Arnhem, The Netherlands
Method 2a):
Project->Properties->Linker->General->Additional library directories->add "C:DirectoryOfYourLib"
Project->Properties->Linker->Input->Additional dependencies; append "Yourlib.lib"
Method 2b):
Project->Properties->Linker->Input->Additional dependencies; append "C:DirectoryOfYourLibYourlib.lib"
Method 2c):
Tools->Options->Intel Fortran->Libraries->add "C:DirectoryOfYourLib"
Method 1 is simplest (but I'm not positive if it works). Method 2a) is better than 2b) when you have more than one .lib file to work with. Method 2c) is suitable when you e.g. have a directory full of .libs which you reuse in several solutions; it adds
the directory permanently to the search path.
Tip: When specifying directories, it's always better to use paths relative to .vfproj file (e.g. ..LibProjectDebug) than absolute paths (C:WhereverProjectRootLibProjectDebug) where available. In this way, you can move the entire solution to another location/computer without recreating entire tree.
HTH,
Jugoslav
Dear Jugoslav,
I tried your method 2b, and it works fine. Now I ran into other trouble (symbols in the library are unresolved), but I won't bother you with it.
I knew about "Properties->Linker->General->Additional library directories", but that wasn't enough. So thank you very much for your help!
Best wishes,
Hello Niels,
Method 1 as spelled out by Jugoslav works fine - this was my solution at the time of submitting this item to the forum. Method 2a is my current solution, with a couple of paths in libpath, and the libraries needed under Additional Dependencies.
Cheers,
Dobrivoje
