29541 Discussions
Linking Fortran I/O code compiled by ifort on WSL2 to g++
Beliavsky
I can link the Fortran code
module m
use iso_c_binding, only: c_float, c_int
implicit none
contains
subroutine print_stats(n,x) bind(c)
integer(kind=c_int)  , intent(in)  :: n
real(kind=c_float)   , intent(in)  :: x(n)
if (n < 1) return
print "(a,*(1x,f0.1))","min, max, mean =",minval(x),maxval(x),sum(x)/n
end subroutine print_stats
end module m
 to the C++ code
extern "C" {
void print_stats (const int *n, const float *x);
} // prototype produced by gfortran -fc-prototypes
int main() {
   const int nx = 4;
   float x[nx] = {5.0,2.0,7.0,4.0};
   print_stats(&nx,x); // min, max, mean = 2.0 7.0 4.5
   // &nx used since argument n does not have VALUE attribute
on WSL2 with
gfortran -c print_stats.f90
g++ print_stats.o call_print_stats.cpp -lgfortran
The -lgfortran is needed because the Fortran code does I/O. Trying ifort with
ifort -c print_stats.f90
I get
/usr/bin/ld: print_stats.o: relocation R_X86_64_32 against `.rodata' can not be used when making a PIE object; recompile with -fPIE
collect2: error: ld returned 1 exit status
and trying with the suggested option
ifort -c -fPIE print_stats.f90
 gives
/usr/bin/ld: print_stats.o: in function `print_stats':
print_stats.f90:(.text+0x68): undefined reference to `for_write_seq_fmt'
/usr/bin/ld: print_stats.f90:(.text+0x15a): undefined reference to `for_write_seq_fmt_xmit'
/usr/bin/ld: print_stats.f90:(.text+0x24c): undefined reference to `for_write_seq_fmt_xmit'
/usr/bin/ld: print_stats.f90:(.text+0x326): undefined reference to `for_write_seq_fmt_xmit'
On WSL2, how can I link a C++ program compiled with g++ to Fortran code compiled with ifort that does I/O?
Ron_Green
try ifort for the final link with -nofor-main
g++ -c call_print_stats_cpp.cpp
ifort -nofor-main -o printit.exe call_print_stats.o print_stats.o
I have no idea if this will work.  Might try -static also
Ron_Green
