Linking Parallel Studio XE 2013
Rafael_P_
I’m trying to install Parallel Studio XE 2013 but it is not linking with Visual Studio. I tried VS2012.5 and VS2012_WDX_ENU but doesn’t work. Does anyone know what version supports Parallel Studio XE 2013?
TimP
Read your release notes, e.g. https://software.intel.com/en-us/articles/intel-parallel-studio-xe-2013-release-notes ; As noted there, you ought to be using an SP1 update, but the requirements on VS2012 are much the same.  Note that the later updates also support VS2013, presumably including the Community version.
Rafael_P_
Problem solved.
It was VS Professional 2012.
Thank you !!
